[Solved] Telefunken TE32554G54V4DA Vestel 17MB171 Android TV USB Recovery Firmware Request
tomasialessio586 2007 13
How can I recover a Telefunken TE32554G54V4DA with a Vestel 17MB171 Android board and a black screen/storage-space error using USB firmware?
Try the Toshiba USB recovery package shared in the thread: it uses panel VES315WNGH-2D-N51, but the important part is the same PT320AT02-2 cell, and it may at least change the startup logo [#21815111] Download the firmware from the provided Google Drive link and use it at your own risk [#21815117] Copy the file `upgrade_no_tvcertificate.pkg` to an empty USB stick, insert the stick into the TV, then plug in the power cord; the USB recovery should start automatically [#21815131]
  • Hard reset failed on black-screen storage warning
    #1 21814584
    tomasialessio586
    I need firmware for:
    TV: Telefunken TE32554G54V4DA
    Mainboard: Vestel 17MB171
    System: Android TV
    Panel: PT320AT02-2
    TV shows "storage space running out" and black screen.
    I need USB recovery firmware.
    Thanks.
    AI: Do you know the current software or firmware version installed on your TV, or can you access the settings to check it?
    No purtroppo no
    AI: Have you already tried any recovery steps, such as a factory reset or installing other firmware via USB? If so, what was the result?
    Non vedo nulla nello schermo, sono un avviso che appare e scompare in cui mi viene detto spazio archiviazione in esaurimento. Ho provato l hard reset tenendo premuto tasto power e poi collegando di nuovo la corrente, ma non succede nulla
  • #2 21814654
    fadili
    Help: 11
    Rate: 454
    Hello. If you have a chance, please provide the panel label notes which start with Ves.....
  • #3 21814783
    tomasialessio586
    >>21814654
    Pannello: PT320AT02-2
  • #4 21814797
    fadili
    Help: 11
    Rate: 454
    I told you to look for a label on the panel that says ves315....
  • #5 21814810
    tomasialessio586
    >>21814654
    Mainboard Vestel 17MB171 Android
    Added after 10 [hours] 13 [minutes]:
    >>21814797
    Scusa hai ragione:
    pannello VES315WNDB-2D-N21
    Added after 1 [hours] 24 [minutes]:
    >>21814797
    Scusa hai ragione:
    billobirillo
    Help: 338
    Rate: 798
    I have a software from a Toshiba
    with panel VES315WNGH-2D-N51 but, most important thing, cell PT320AT02-2
    same remote control
    it will only change the logo at startup
    do you want to try it?
  • #7 21815113
    tomasialessio586
    >>21814797
    Scusa, hai ragione:
    pannello VES315WNDB-2D-N21.
    >>21815111
    Sì, posso provarlo, lo metto poi in una chiave USB, inserisco la chiave USB a corrente spenta e tengo premuto tasto power sulla TV e nel mentre inserisco la corrente? Nel caso non sia così puoi dirmi la procedura esatta?
  • #9 21815123
    tomasialessio586
    >>21815117
    Ok, grazie, lo proverò.
  • #10 21815131
    billobirillo
    Help: 338
    Rate: 798
    sw from Toshiba link
    copy the file upgrade_no_tvcertificate.pkg on an empty usb stick
    insert the usb stick in the tv
    then plug the power cord: the usb recovery will start automatically
  • #11 21815143
    tomasialessio586
    >>21815117
  • #12 21816500
    tomasialessio586
    >>21815117
  • #13 21817186
    tomasialessio586
    >>21815131
    Ho provato però, ora dopo finita l'installazione, il pannello della TV risulta acceso e illuminato ma tutto nero e si sente una musica di sottofondo. Io ci ho provato prima di buttare la TV; volevo comunque ringraziarti per avermi aiutato a provarci.
  • #14 21818242
    tomasialessio586
    Risolto
Telefunken Android TV with Vestel 17MB171 mainboard and PT320AT02-2 / VES315WNDB-2D-N21 panel had a black screen and repeated “storage space running out” warning. The user could not access the menu or read the firmware version and an attempted hard reset did not help. A recovery firmware package for a Toshiba set with compatible panel/remote was shared, with instructions to copy upgrade_no_tvcertificate.pkg to an empty USB stick, insert it into the TV, and reconnect power to trigger automatic USB recovery. After flashing, the TV powered on with backlight and audio but still showed a black image; the issue was later marked as resolved.
TL;DR: Fix a soft‑bricked Telefunken TE32554G54V4DA (Vestel 17MB171) by copying 1 file to USB; “the usb recovery will start automatically.” [Elektroda, billobirillo, post #21815131]
Why it matters: This FAQ helps owners recover picture and usability when the TV only shows a storage warning and goes black.
How do I run USB recovery on a Vestel 17MB171 Android TV?
Copy upgrade_no_tvcertificate.pkg to an empty USB stick. Insert the USB into the TV. Plug in the power cord; recovery starts automatically. This is a 3‑step process and needs only one file on the USB. [Elektroda, billobirillo, post #21815131]
Do I need to hold the TV power button during USB recovery?
No. Insert the USB, then plug in the power. The TV should auto‑start the USB recovery without pressing any buttons. [Elektroda, billobirillo, post #21815131]
Which exact panel code should I match before flashing?
Match the panel label starting with VES…, for example VES315WNDB-2D-N21. Using the precise VES code reduces mismatch risk. [Elektroda, tomasialessio586, post #21814810]
What if my TV only shows “storage space running out” and then a black screen?
This symptom was reported for TE32554G54V4DA with 17MB171. USB recovery is the recommended next step when the screen goes black afterward. [Elektroda, tomasialessio586, post #21814584]
Where do I find the VES panel label and why does it matter?
Look on the panel label for a code like ves315…. Helpers requested this to ensure firmware matches the exact display hardware. [Elektroda, fadili, post #21814797]
Can I use Toshiba firmware on this Telefunken model?
A helper shared Toshiba software with the same PT320AT02-2 cell. Expect only a different startup logo; remote stays compatible. [Elektroda, billobirillo, post #21815111]
What single file should be on my USB stick?
Place only upgrade_no_tvcertificate.pkg in the USB root. Do not add other files or folders to avoid detection issues. [Elektroda, billobirillo, post #21815131]
What’s the exact 3‑step How‑To for recovery?
  1. Copy upgrade_no_tvcertificate.pkg to an empty USB stick.
  2. Insert the USB into the TV.
  3. Plug in the power cord; recovery starts automatically. [Elektroda, billobirillo, post #21815131]
Is there any risk in trying shared firmware links?
Yes. A helper stated the firmware is provided entirely at your own risk. Flashing mismatched firmware can cause faults. [Elektroda, fadili, post #21815117]
Will the remote control still work after installing the shared firmware?
Yes. The contributor noted the same remote control works even though the boot logo changes to Toshiba. [Elektroda, billobirillo, post #21815111]
What is the PT320AT02-2 “cell” mentioned in the thread?
It refers to the panel cell model. A shared package targeted PT320AT02-2, which influenced compatibility and the startup logo. [Elektroda, billobirillo, post #21815111]
What if recovery doesn’t start after plugging power with the USB inserted?
Recheck that only the correct .pkg file is on the USB and it’s fully seated. Recovery should start automatically on power. [Elektroda, billobirillo, post #21815131]
Why did helpers insist on the exact VES code again?
Because the VES code identifies the specific panel variant. A wrong match increases failure risk during flashing. [Elektroda, fadili, post #21814797]
