Telefunken TE55660G56U4QA 17MB185 - black screen and no space left USB firmware
UnsignedSource 483 5
  • Requesting 17MB185 firmware dump for USB recovery
    #1 21941207
    UnsignedSource
    need a dump of the firmware for the Telefunken TV TE55660G56U4QA with motherboard chassis Vestel 17MB185 to put in an USB flash drive cause my TV shows a black screen with a no space left message on the top right
    AI: Can you post the full stickers from the back cover, the panel label, and the 17MB185 board barcode/version numbers?
    no
    AI: Does the TV react to USB update/recovery method or remote buttons, and did you already try any firmware file before this happened?
    no
  • #2 21941402
    yokoono51
    Help: 172
    Rate: 316
    VES550QNDB-N2-N43 panel ???.
  • #3 21941595
    UnsignedSource
    >>21941402 Yes
  • #4 21941625
    yokoono51
    Help: 172
    Rate: 316
    Ihave this:
    17MB185 panel VES550QNDB-N2-N43 Daewoo
  • #5 21943046
    UnsignedSource
    >>21941625 Should be good if the motherboard is the same.
