Where to Download Firmware for F&U FLA5520UH 17MB170 VES550QNDS-2D-N41 TV?
kyriakakismathia 1560 19
Where can I download firmware for the F&U FLA5520UH TV with 17MB170 / VES550QNDS-2D-N41 board and panel?
You can use the firmware/software from a Toshiba 55UA3A63DB, which was reported to work perfectly on the F&U FLA5520UH; the only noted difference is that the startup logo becomes Toshiba [#21824192] A download link was later shared in the thread and confirmed working by another user [#21824339][#21866483][#21867385] To install it, copy the file `upgrade_no_tvcertificate.pkg` to an empty USB stick, insert it into the TV, then plug in the power cord so recovery starts automatically [#21824339]
  • #1 21824033
    kyriakakismathia
    Hello, everybody,
    I need the firmware for my F&U TV.
    Model: F&UFLA5520UH
    17MB170
    VES550QNDS-2D-N41
    Thanks!
    billobirillo
    Help: 338
    Rate: 798
    I can provide you the software from a Toshiba 55UA3A63DB
    it works perfectly on your F&U FLA5520UH
    just one difference: the startup logo will change in Toshiba
  • #3 21824197
    kyriakakismathia
    >>21824192
    Thanks a lot, billobirillo!
    I will give a try!
    Where could I download it?
    billobirillo
    Help: 338
    Rate: 798
    here is the software link
    link valid for 7 days
    copy the file upgrade_no_tvcertificate.pkg on an empty usb stick
    insert the usb stick in the tv
    then plug the power cord: the recovery will start automatically
  • #6 21824383
    kyriakakismathia
    >>21824339
    Billobirillo, you are a pro!
    My TV looks like new!
    The only difference is the TOSHIBA startup logo!
    Thank you so much for your help!
  • #7 21831884
    elhadilaz
    Hello everyone... Please, I need the same software for my TV Tucson, the same panel VES550QNDS-2D-N41... Thank you
  • #8 21834954
    eliasbennacer
    I wish I could get the firmware as well. I'm stuck with split screen since I changed the 17MB170.
    I have the exact same panel board and model of TV
    >>21824192 Can I get it as well, please? 🙏🙏🙏
  • #9 21835494
    billobirillo
    Help: 338
    Rate: 798
    @elhadilaz @eliasbennacer
    download it here link
  • #10 21854895
    robertkozina69
    soft please again, thanks
  • #11 21863966
    bigwolf13
    Hi @billobirillo. Could you please share the link again? I have the same TV with the same issue.
    Thanks
  • #13 21866138
    bigwolf13
    @elhadilaz @eliasbennacer could you kindly share the firmware if you have it from @billobirillo ?
    I'm not sure @billobirillo could help us here this time!
    thank you very much
  • #15 21867385
    bigwolf13
    >>21866483 It worked! Thank you so much!
  • #16 21938897
    flamarasklasos
    Hi everyone, new here. Can someone provide a working link for the FW? Thank you
  • #17 21938933
    billobirillo
    Help: 338
    Rate: 798
    >>21938897
    with vestel tvs, post always the photo of the sticker on the back of the tv: product code and serial number required
  • #18 21938935
    flamarasklasos
    Hi billobirillo, it's a Hitachi with the same panel and mainboard as the thread 17MB170 VES550QNDS-2D-N41. The unit's model is Hitachi 55HAK5750.
  • #19 21939001
    billobirillo
    Help: 338
    Rate: 798
    @flamarasklasos
    here is the software for Hitachi 55HAK5750 link
The discussion is about finding firmware for an F&U FLA5520UH TV using the 17MB170 main board and VES550QNDS-2D-N41 panel. A compatible firmware package from a Toshiba 55UA3A63DB was shared and reported to work on the F&U set, with the only visible change being the Toshiba startup logo. The firmware was distributed as an upgrade package for USB recovery, using the file upgrade_no_tvcertificate.pkg on an empty USB stick and powering on the TV to trigger automatic recovery. Several follow-up posts requested the same software for similar TVs and panels, and later a Google Drive link was shared and confirmed working.
