Honda Jazz 1.4 DSI check engine light after changing all 8 spark plugs
BidagaRitted 618 4
  • #1 21830603
    BidagaRitted
    Hello. I have 1.4 L DSI Honda Jazz. Check engine after 8 spark plugs changed on service. Thanks in advance for help
    AI: Do you know what error code is showing for the check engine light? If yes, please share the code.
    No. The service said no error is present.
    AI: After changing the spark plugs, did you notice any other symptoms like rough idling, misfire, or loss of power?
    No, power is good.
  • #2 21830740
    danielzy
    Help: 168
    Rate: 323
    The check light on the dashboard is always associated with a fault code and it is definitely stored. Either the mechanic is trying to sell you or he has the wrong equipment to read it. I think either the ignition is out or the lambda probe is reporting an error.
  • #3 21831154
  • #4 21831432
    arturlom
    Help: 48
    Rate: 86
    A 1.4 engine and as many as 8 spark plugs ?
  • #5 21831483
    borba
    Help: 14
    Rate: 32
    >>21831432 Yes. The Honda Jazz (perhaps other models, but as an owner of two JAZZs I can only speak of this) has two plugs per cylinder.
