Opel Corsa D 1.2 (86) Check Engine Light: Recurring Coil Issues or Electrical Problem?
Nulkag 14997 10
Why does my Opel Corsa D 1.2 keep flashing the check engine light and showing coil failures again after the coil was already replaced?
The recurring misfire is not necessarily only a bad coil; you should first verify that the spark plugs are the correct type and still in good condition, because unsuitable plugs can kill coils [#17008548] [#17008435] If the plugs are fine, check for another cause of ignition loss such as low compression on the cylinder or a faulty injector [#17008879] One user also reported a similar case where the problem disappeared only after replacing the plugs, the coil, and the gas rail/strip, plus checking the installation settings and vacuum [#17011240] Coils on these cars do fail, but not normally every six months unless something else is damaging them [#17008435] [#17007865]
  • #1 17000088
    Nulkag
    I own an Opel Corsa D 1.2 86. In August candles were changed. After visiting the plant moss. the engine started to jerk and the check engine icon was flashing. A damaged coil was found. Half a year later, the situation pleases, the icon flashes again and the coil changes again. I'm afraid the problem will come again. Is this really a problem with the coil. Maybe something with electrics ???
    patrix20
    Help: 12
    Rate: 129
    Coils were replaced with new ones?
  • #3 17007640
    Nulkag
    Both coils were new
    helmud7543
    Help: 1216
    Rate: 1564
    If replacing the coil helps for at least a few weeks, it is either faulty coils (maybe some hopeless substitutes?) Or something ends these coils (cables, candles), I just forgot whether the coil is more short-circuited or a complete lack of connection. Do you have gas in the car?
    tzok
    Help: 3174
    Rate: 6529
    Damage (loss of ignition) on the same cylinder as last time? Coil - original or replacement used?
    helmud7543 wrote:
    or something ends those coils (cables
    There are no cables, there is a module with 4 coils, mounted on candles:
    MikeC
    Level 32  
    Help: 201
    Rate: 971
    Coils fall in these cars quite often, but not every six months, unless someone drives on burned candles (too much distance), it is also worth checking if they are well selected ...
    przemek25l
    Help: 124
    Rate: 372
    I would check carefully if good candles are installed. I had a case that 2 coils died because of inappropriate candles.
    migmig85
    Help: 85
    Rate: 336
    Buddy and you checked out the ignition loss may also be lack of compression on the cylinder or damaged fuel injection ;) .
    QCoo
    Help: 5
    Rate: 33
    First of all, let the author of the post specify what engine and what fuel to supply. I had a very similar situation. First, the candles were replaced, then the coil, and finally the gas strip was replaced. And the problem disappeared
  • #10 17048802
    Nulkag
    That's it: petrol 1.2 80 horses. Candles replaced the day before the first coil replacement / fault. Case?!
    This injection can also be because I feel something when I warm up the engine when adding gas but they said not to worry. Be smart here and write poems ...
  • #11 17048892
    QCoo
    Help: 5
    Rate: 33
    What error does it show you?
    I regularly jumped P0420 every 40km - like something wrong with the catalyst. In addition, I had a situation with a flashing check engine 2 times - ignition loss. As I mentioned above, I came across a good gas burner, which in addition to adjusting the installation (including vacuum) replaced the gas injection rail. I've traveled several thousand kilometers since the repair and nothing happens.
✨ The discussion revolves around recurring issues with the check engine light on an Opel Corsa D 1.2 (86) after coil replacements. The user reports that after changing the spark plugs and a damaged coil, the check engine light began flashing again after six months. Responses suggest that the problem may not solely be with the coils, as faulty spark plugs or electrical issues could also be contributing factors. Several participants recommend checking the compatibility and quality of the spark plugs, as well as potential issues with fuel injection or compression in the engine. The importance of identifying the specific error codes and ensuring proper installation of components is emphasized.
