Toshiba 32LL3B63DG V.3.33.21.0 reboot on Skylink Live TV, downgrade?
ardescz 471 2
  • #1 21875875
    ardescz
    I have a Toshiba 32LL3B63DG TV and, after updating the software to V.3.33.21.0, when I use some streaming applications, I get something like a kernel panic and the TV is auto-rebooting.
    Can I please get some firmware for downgrade, probably V.3.28.10.1 or older?
    mother board 17MB211
    panel 32_VESUNGHN41J_L3FHD_D_X_FO_V_211_XX
    BOOTLOADER: MB211-0303
    Thank you
    AI: Which streaming apps are causing this reboot, and does it happen on all streaming apps or only some of them?
    Usually it happens after using the Skylink Live TV app.
    AI: Did you already try a factory reset or reinstall/clear data of the apps after the update to V.3.33.21.0?
    Yes, I did, and it's not working. I found that this version uses more RAM memory than the old one.
  • #2 21875959
    yokoono51
    Help: 154
    Rate: 286
    I have this: V.3.33.17.4. It installs with MENU 1505. Try at your own risk.
    • MB211S_QuiToshiba V.3.33.17.4.zip (170.88 MB) You must be logged in to download this attachment.
  • #3 21876207
    ardescz
    Hello, thank you for your quick reply. I'll give it a try.
