Toshiba 32W2431D V28A001434C1 L2300 REV1.03A USB firmware scan loop
PollOffset 585 1
  • Request for USB firmware to fix blue-screen scan loop
    #1 21896418
    PollOffset
    I have a Toshiba 32W2431D TV stuck in an infinite scan loop on a blue screen. The scan bar reaches 100% and restarts endlessly.
    Mainboard details:
    - Model: Toshiba 32W2431D
    - Board reference: V28A001434C1
    - Board revision: L2300 REV.1.03A
    - Main chip: MSD8841BX-VW
    - Manufacturing date: 19.09.2014
    I believe the firmware is corrupted. I am looking for a USB auto-update firmware file (.zip or folder) to flash via USB stick (FAT32).
    If anyone has this file or can point me to the right source, I would be very grateful.
    Thank you!
    Have you already tried any recovery steps (different USB sticks, forced USB update procedure, factory/service reset, or any firmware files found online), and if so, what exactly happened?
    I have not tried any recovery steps yet. The TV boots directly into the blue scan loop and I cannot access any menu.
    Can you share the full model code and all sticker details from the back of the TV/panel label (including any suffix, chassis, serial, or region/version code), plus a photo if possible?
    Full model: Toshiba 32W2431D
    Serial number: 82C27442
    Mainboard: V28A001434C1 / L2300 REV.1.03A
    Assembled in Poland
  • #2 21908773
    asenikonomov301
    You should also provide the panel number, without it, chances to find firmware are even slimmer. @ElektrodaBot
