Best BISSELL Little Green - worth it for upholstery, spills and regular use?
xara11 486 1
  • #1 21932054
    xara11
    Hey everyone,
    I’m currently looking for the best option related to the BISSELL Little Green Multi-Purpose Portable Carpet and Upholstery Cleaner. I’m not promoting anything at all-just want honest opinions from people who’ve actually used these kinds of cleaners.
    Here are two products I’m considering:
    Portable cleaners seem convenient for quick spills and upholstery, but I’m unsure about suction power, tank size, and long-term reliability with regular use.
    Thanks in advance!
    https://www.amazon.com/dp/B0016HF5GK?lv=shuf&...3d099&language=en_US&ref_=as_li_ss_tl
  • Little Green suits upholstery and quick stain removal
    #2 21932270
    256
    Help: 5
    Rate: 9
    I’ve also checked user reviews myself, and after going through numerous reviews and forum discussions (particularly on Reddit), a fairly consistent picture emerges. The biggest advantage of this device is that it works very well for quickly removing stains from sofas, armchairs, mattresses, and car upholstery. It is lightweight, handy, and easy to store. Many pet owners praise it for its ability to quickly clean up fresh messes without having to get the large wet vacuum out. As for suction power, you need to have realistic expectations. This is not a professional-grade appliance. It extracts dirty water quite well, but the upholstery usually remains damp after cleaning and needs time to dry. For tougher stains, you often need to go over the area several times. Another downside is the capacity of the tanks. To clean an entire sofa or a car’s interior, you usually need to change the water several times. When removing individual stains, this isn’t a major problem. When it comes to durability, opinions are divided. Many people use the Little Green for several years without any problems, but there are also reports of leaks, worn seals, or problems with the nozzle. Much depends on how often it is used and whether the machine is cleaned regularly after use. My conclusion, having read many reviews, is that this is a very good machine for upholstery, cars, and quick stain removal; however, I wouldn’t regard it as a replacement for a full-size carpet cleaner for the regular cleaning of large carpets. In my view, if the main uses are upholstery, furniture, and the car, then it’s a sensible purchase. However, if you plan to clean large carpeted areas frequently, it’s worth considering a larger model with more powerful suction and bigger tanks.
