Toshiba 65QA4C63DG 17MB170E - solid red LED, need 10104693 eMMC dump
emfe2000 369 2
  • Request for 10104693-specific eMMC dump and recovery firmware
    #1 21939919
    emfe2000
    I am looking for the exact original USB recovery firmware, MstarUpgrade.bin,
    or a verified full eMMC dump for this television:
    Brand / Model: Toshiba 65QA4C63DG
    Product Code: 10104693
    Production Variant: 2201
    Serial Number: 1060923 200062
    Mainboard: Vestel 17MB170E, PCB revision 070720R2
    Panel: VES650QNTL-P2-Z01
    LCD: LG LC650EQQUB-F70(SM)(A3)
    Panel Vestel Code: 23796681
    Region: EU
    Operating System: Android TV
    Fault:
    When AC power is connected, the LED flashes green for less than one second
    and then remains solid red. The television does not respond to the remote
    control or the physical joystick. There is no boot logo, backlight or sound.
    I need one of the following, specifically matching Product Code 10104693
    and panel VES650QNTL-P2-Z01:
    1. upgrade_loader.pkg
    2. upgrade_loader_no_tvcertificate.pkg
    3. MstarUpgrade.bin for M-Boot recovery
    4. Verified full eMMC dump
    5. A safe read-only USB or UART diagnostic method to confirm whether
    M-Boot can detect and read the eMMC
    6. UART / service test-point pinout for the 17MB170E 070720R2 board
    Please do not send a generic 17MB170E firmware or firmware for Product
    Code 10132711, because this television is the 10104693 / 2201 variant.
    I can provide photographs of the rear label, mainboard and panel label.
    Thank you.
  • #2 21940480
    rob1
    Help: 68
    Rate: 140
    Or why not have a go yourself and find the UART pins??
    It’s
    not that difficult; you can use a similar board as a basis
    As for MstarUpgrade.bin, you won’t be able to get hold of that file, just like the EMCC dump
  • #3 21941975
    blackhill
    Do not try a generic 17MB170E package because the panel configuration and product code must match. For diagnostics, use only a 3.3 V USB-to-TTL adapter on the board’s UART pads with ground and RX connected first and monitor the boot log without writing anything.
