Electrolux EES69310L dishwasher, error i30/i44/i11
BatchBalancer 234 3
  • i11 cycle runs drain pump without water inlet
    #1 21950150
    BatchBalancer
    I am seeking good advice here.
    - 5-year-old Electrolux EES69310L dishwasher with PNC 911434586.
    - Overflooded with error i30, dried, turned on again, showed error i44 or i11 in the first 2-3 minutes with no water inside.
    1. I changed pressure switch 140000554083, powered on and started a cycle. 3 minutes of draining with no error. So I opened the door, put 2 liters of water inside from a bucket, reset the cycle, started it again, and closed the door. The water was drained off, and the cycle ran perfectly. It was a 30-minute quick one.
    2. After a few hours, we filled up the dishwasher and started a new cycle. After 10 minutes, there was an i11 error code again.
    Can someone lead me to a solution, please?
    AI: Is the bottom anti-flood tray completely dry now, and can you see any new water/leak in the base after the dishwasher runs for those 10 minutes?[/i]
    Completely dry now. No leak after 30 minutes of quick wash.
    AI: During the failed cycle, does the dishwasher actually take water in? Please describe: inlet water sound, water level inside after opening the door, drain pump running or not, and whether inlet hose/filter/tap were checked.[/i]
    Only the drain pump is running, with no water inlet. The tap has good pressure all the time.
  • #3 21950686
    BatchBalancer
    >>21950207 Yes sir, the valve is working.
  • Checking water-flow blockage, hydrostat debris, and drain pump timing
    #4 21950705
    Kenworth 18
    Help: 2448
    Rate: 3761
    Could a stone have become lodged somewhere in the casing and be blocking the flow?: https://north.pl/karta/8581170481874-plaszcz-wodny-do-zmywarki,704-WH-3109.html
    Next, check that there is no debris at the hydrostat connection: https://north.pl/karta/140000554083-hydrostat-do-zmywarki,513-WE-0008.html
    Here is a detailed explanation of the error code: https://www.elektroda.pl/rtvforum/topic3900069.html
    Does the drain pump start working immediately after switching on the dishwasher?
