Ford P1000 Fault Code Meaning on Ford Vehicles—What Does P1000 Indicate?
vvaldek 85786 6
  • #1 2159902
    vvaldek
    Help: 81
    Rate: 386
    what does fault P1000 mean in Ford?
  • #2 2159933
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    There is no such fault wrongly read code?
    Jacek79
    Level 37  
    Help: 233
    Rate: 1132
    Is
    this means that the road test is not fully carried out after erasing the errors
  • #4 2160195
    vvaldek
    Help: 81
    Rate: 386
    the error appeared by itself without deleting. and by the way, what is this test?
    ponar
    Help: 23
    Rate: 124
    Don't worry, the error will disappear when you perform the obd road test, i.e. you need to drive a dozen or so kilometers at a constant speed, brake the engine in advance, etc.
    lapek
    this error arises after removing the clamp, it will disappear after passing the road test, as colleagues write above
  • #7 2163316
    vvaldek
    Help: 81
    Rate: 386
    okay i know everything
The P1000 fault code in Ford vehicles typically indicates that the onboard diagnostic (OBD) system has not completed its readiness tests after a fault code has been cleared or the battery has been disconnected. This error often resolves itself after performing a road test, which involves driving the vehicle for a certain distance at a constant speed and allowing the engine to operate under various conditions. The error may appear spontaneously without prior deletion of codes, but it is generally not a cause for concern as it will disappear once the necessary driving conditions are met.
