EPSON EMP-S1H – desktop visible, black movie window from ASUS A6VA?
makq 50761 5
  • #1 2427205
    makq
    I wanted to watch a movie on my laptop by projecting the image through the projector on the wall and I have a problem. Well, the projector casts an image of everything but the movie window, i.e. you can see my desktop, mouse cursor movement, etc. but you can't see the movie. Where the movie should be displayed is a black rectangle, only the subtitles are displayed. I tried different programs like allplayer, subedit, wmp but the same thing everywhere. Can anyone guess why? It looks like the projector does not see the area of the screen where the program displays the movie. The projector is definitely working because I checked it on the Pc and the movies fly like in multiplex :)
    The projector is an EPSON EMP-S1H (connected via a "monitor cable" d-sub)
    Laptop ASUS A6VA Q039, graphics ATi Mobility Radeon X700 128MB VRAM
    If anyone has an idea what I need to change, or. install in order to make the laptop work with the projector then please make suggestions.
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    You need to turn on the clone in the card and transfer the image to the d-sub output. In the screen properties of the laptop, go to settings -> advanced -> screen[s] -> and there you have the choice of what is to be displayed where, that is, you must turn on the monitor (because that is how the projector is seen) and choose to be "first". - then the laptop desktop will be as "second" but it will fully display what you are doing in addition to the image of the movie you want to watch.
    Greetings
  • #3 2427321
    makq
    Quick answer :)
    U me a little differently it is set up so I could not choose the order but you guided me to the right thinking. It helped to set the graphics so that the laptop only projected an image on the projector (lcd off) and beautifully see everything.
    Great thanks gabik
  • #4 2445841
    kasia19
    Rate: 10
    great thanks also helped me :) but I have a question why is it like this ?
    this is the active content if I'm not mistaken how to make it work on two monitors?
    thanks
  • #5 10883604
    tomo_s
    I have the same problem but with a projector connected via USB with a desktop computer, graphics card integrated. In the DVD player window there is a black background on the image projected from the projector, on the monitor everything is ok. In the graphics card settings it sees only one monitor
  • #6 12580437
    WIESLAW2211
    Rate: 27
    I have a problem with displaying on the screen from the projector all the icons that are on the desktop of a dell mini laptop. And I would like the icons not to be seen only a black background on the screen from the projector, and a preview on the laptop monitor.... Admittedly, connecting the laptop + projector via VGA cable, I have set everything in the options of the card, etc. and everything works correctly.Only that the problem is that I want to connect it wirelessly,the projector with a wireless manager WGA310 and the laptop has Wifi distance of about 30m.The laptop communicates with this device and switches everything as expected, except that everything is shown on the screen from the projector. The system in the laptop Xp. I am asking experts in this field for help.
