[Solved] Understanding CT and DCS Features in Baofeng UV82 Radio for Effective Communication
K3FIR14 13116 8
  • #1 17034735
    K3FIR14
    Hello, I have a baofeng uv82. I have the same frequencies as the rest of my friends who own this radio. There is only one difference. For channels 1 2 3 4 5 6 it says CT to the right and for channels 7 8 9 10 11 12 13 it says DCS. Someone told me that this is not a PMR but some factory test channels or something similar. Will the fact that CT and DCS are written not interfere with communication between radios ??? And maybe someone knows how to make these CT and DCS appear there? I have had a radio for several days and this is the first radio I have.
    I will add that there are ALL channels 21
    belzebub24
    Help: 16
    Rate: 28
    First of all - Baofeng UV82, in accordance with applicable law, should not be used in the PMR band (power, replaceable antenna) Secondly, read about CTCSS tones here https://pl.wikipedia.org/wiki/CTCSS Third - answering your question : if the radio is set to the same tones or is completely turned off, it will not interfere with communication between radios. Enclosed is the menu list, please read this.
    • UV-82 Baofeng.pdf (377.33 KB) You must be logged in to download this attachment.
  • #3 17063476
    K3FIR14
    Thank you for your help. I will add that the radio is not used in PMR
  • #4 17063607
  • #5 17063626
    belzebub24
    Help: 16
    Rate: 28
    If you do not have a radio license and do not want to operate in the PMR band, you can buy a personal radio license on Allegro authorizing you to broadcast only on a specific frequency.
    @ cristal2242 - I think you need to explain, not scare :) 73!
  • #6 17063659
    K3FIR14
    As I said, it is used on factory test channels
  • #7 17063884
  • #8 17064003
    K3FIR14
    I want to use it for walking in the woods. I don't always have phone coverage.
  • #9 17323072
    K3FIR14
    It turned out that the symbols CT and DCS do not interfere with anything
✨ The discussion revolves around the Baofeng UV82 radio, specifically addressing the presence of CTCSS (CT) and DCS tones on certain channels. Users clarify that these tones do not interfere with communication as long as all radios are set to the same tones or are turned off. The conversation highlights the legal implications of using the Baofeng UV82 outside of PMR bands and the necessity of having appropriate licenses for operation. The original poster intends to use the radio for outdoor activities where mobile coverage is limited. Ultimately, it is confirmed that the CT and DCS indicators do not hinder communication between radios.
