Boss Audio RIP 240 DVC – good 38 cm subwoofer for a sealed box?
StanislawB 2174 1
  • #1 2833306
    StanislawB
    Hello!
    Recently I bought a Boss radio and because I'm very happy with it, I would like to make a subik from this company too. I found a 2-watt loudspeaker with a diameter of 38 cm :)
    http://www.audiosklep.pl/product_info.php?cPath=27_59&products_id=294
    I would like to ask if anyone of you had anything to do with him?
    I was attracted by surprisingly high efficiency of 96 dB!
    Despite the fact that he has high Vas, I would like to risk and "close" the closed housing. What do you think about it?
  • #2 2833531
    raveland
    Help: 62
    Rate: 46
    spl probably can be given before 2.83v so it's so high
    coil quite large magnet quite heavy (although they could use some inferior quality, but if it can not have as much watts as they give)
    only qts is high
    only fits closed and what is more likely to be the case of a large size but the bass should be too much and even a lot of it can be debauchery
