AUNA ACTIVE CAR SUBWOOFER 25cm AMPLIFIER: Seeking Feedback on Performance and Value
Kofffaniutka1 4863 5
  • #1 16830812
    Kofffaniutka1
    Hello, I am asking you for help. I don't know each other and you do. I want to buy her husband:
    AUNA ACTIVE CAR SUBWOOFER 25CM AMPLIFIER.
    Technical parameters:
    Connections: 1 x stereo RCA line input, 1 x RJ45 pilot connector
    Power: 60 W RMS
    Frequency range: 20 Hz - 150 Hz
    Impedance: 2 + 2 Ohm
    THD (Total Harmonic Distortion): 0.08%
    Signal to noise ratio: 85 dB
    Construction: closed
    Mounting Type: Horizontal, Vertical
    Variable low-pass filter: 50 - 100 Hz
    Phase inversion: 0 - 180 ° (Normal, Reverse)
    Gain control (gain)
    Metal loudspeaker grille
    PWM Mosfet power supply
    Fuse: overheating, short circuit
    Power supply: DC 14.4 V.
    Please advise worth it? 560 PLN. Is this equipment good or not? Many thanks in advance for your answers.
  • #2 16830921
    powalla
    Moderator of CarAudio
    Help: 847
    Rate: 737
    Kofffaniutka1 wrote:
    AUNA
    This is mediocre equipment and if something is active, maybe the Blaupunkt GTB 8200 A is better.
  • #3 16831373
    Kofffaniutka1
    I was hoping for something that fits under the seat, but if you say that it's not that good, maybe it is.
  • #4 16831412
    powalla
    Help: 847
    Rate: 737
    Well, the amplifier itself should be mounted under the seat, and a passive box in the trunk, and if there is a need for space in the trunk, it can be detached and removed (of course, I recommend securing the disconnected wires).
  • #5 16838209
    gagaga93
    Rate: 9
    AUNA
    I strongly do not recommend it. I don't know if it has any value at all, once I fell for an amplifier from this company, which despite the huge 2400watt inscription was weaker than the old car radio because it had 16 watts per channel .. I do not recommend anything from this company. Here is a little support for my words http://amp-performance.de/995-Auna.html
  • #6 16848142
    Kofffaniutka1
    Thanks for the help, however, I bought one like my friend advised above. Greetings.
