Removing Gridlines in Microsoft Word 2000: Diploma Writing Disturbance Solution
Strzała 48361 13
How do I turn off the grid lines that are showing while editing a document in Microsoft Word 2000?
Turn off the document grid in Word 2000 by opening the Drawing/Grid settings and unchecking “Display grid lines on screen.” This is the option that controls the visible grid while editing, and it does not affect printing [#2846738][#18516292]
  • #1 2839421
    Strzała
    Rate: 20
    Hello! My girlfriend is in the process of writing her diploma, unfortunately someone was playing with the computer on which she is writing her diploma and turned on the grids in the word, they do not print, but they are very disturbing when writing and I cannot get rid of this trash! I will only add that it uses word 2000.
  • #2 2839469
    august_
    Help: 70
    Rate: 47
    Take a screenshot because I don't really know what grids are going on.
    Maybe choose a different option in the view menu?
  • #3 2839584
    Maly
    Help: 195
    Rate: 336
    Maybe you have the display of special characters turned on, ie enter spaces, etc. This is a bar icon like the number "Pi". Or:
    View; Toolbars; Customize; (View; Show All)
  • #4 2840172
    Strzała
    Rate: 20
    When writing in the word, we see a blank page and we write on it, while in the case of the Girl the "page" of the document looks just like a page from a squared notebook. And I will take a screenshot in the near future because this computer is not at my place :(
  • #5 2840310
    md
    Help: 681
    Rate: 791
    It is a shame not to know such basic options of the program.
    You choose from the menu: FORMAT> BACKGROUND and there No fill, and no fill is a problem out of your head ;)
  • #6 2840576
    Strzała
    Rate: 20
    Well, I don't have to be ashamed because this option does not remove these boxes!
    When selecting a view: there are no grids as a page, and when selecting a page layout view, there are no grids :(
    And it looks like this:
    [/ img]
    • Removing Gridlines in Microsoft Word 2000: Diploma Writing Disturbance Solution 11111.jpg (48.38 KB) You must be logged in to download this attachment.
  • #7 2840680
    md
    Help: 681
    Rate: 791
    See the drawing. In the background a grid, in the foreground a window with filling effects. The background can also be a texture, but the problem is the background and it is in this place, which I wrote about earlier, that you set or remove the background. If not, then you have to turn off FORMAT> BACKGROUND> "printed watermark" or FORMAT> "theme"
    • Removing Gridlines in Microsoft Word 2000: Diploma Writing Disturbance Solution Word kratka.gif (19.28 KB) You must be logged in to download this attachment.
  • #8 2846655
    Strzała
    Rate: 20
    And unfortunately all the combinations don't help, probably the best solution is to uninstall and install word :(
  • #9 2846706
    md
    Help: 681
    Rate: 791
    I don't know if it will help. Take a screenshot, it is very difficult to diagnose so blind. If not a screenshot, maybe insert a piece of text saved in your program so that we can find out about the problem.
    You definitely have something to do with the background or other additional effects.
  • #10 2846735
    Strzała
    Rate: 20
    the screenshot is taken 3 posts above
    LtLog
    Level 30  
    Help: 165
    Rate: 39
    It seems to me that this is neither the background nor the pattern, buddy md since they don't respect margins while working, the answer is in my colleague's screenshot, just the gridline function in drawing options has been turned on.
    My friend Arrow in the drawing options (you have it turned on, judging by the screenshot), go to the "grid" menu and uncheck the "Display grid lines on screen" option there.
    Screen for ease of use
    Regards Lt.
    • Removing Gridlines in Microsoft Word 2000: Diploma Writing Disturbance Solution Clipboard01.jpg (17.17 KB) You must be logged in to download this attachment.
  • #12 2847126
    md
    Help: 681
    Rate: 791
    The fact, I admit without beating, was not looking at the posts up and the author of the question posted a screen much later, hence in my reply a request to upload a screenshot or a file excerpt.
    A little note. If the author of the question translated a bit and asked it properly with the screenshot attached, the matter would be finished in the second post and so we have 10 posts.
  • #13 2847780
    Strzała
    Rate: 20
    And finally got rid of that net! Thank you to everyone who tried to help me, especially LtLog!
  • #14 18516292
    grimelectro
    So the matter is very simple, namely at the top of the word there is the last tab view, you click on it and check the grid lines and that's it
    the mesh disappears
The discussion revolves around a user seeking assistance to remove gridlines in Microsoft Word 2000, which are causing distractions while writing a diploma. Various suggestions were made, including checking the display of special characters, adjusting background settings, and disabling gridlines in the drawing options. Ultimately, the solution involved unchecking the "Display grid lines on screen" option in the drawing settings, which successfully resolved the issue. The user expressed gratitude for the help received, particularly from a contributor who provided the correct solution.
