Frequent Minsk Glacier Refrigerator Cycling: Causes & Solutions for Increased Energy Use
loppy 47309 9
Why does my old Minsk Glacier refrigerator turn on every 5–7 minutes and use much more electricity, even though the thermostat was replaced last year?
Frequent cycling can come from a bad door seal, a thermostat/capillary problem, high room temperature, or a cooling-system fault such as refrigerant loss or a worn compressor. Check whether the door closes tightly, because a leaking seal makes the fridge start more often, especially in hot weather [#2843676] Also verify the thermostat setting, whether the capillary tube is still correctly mounted on the evaporator, and measure the actual switch-on/switch-off temperatures with an accurate electronic thermometer [#2843828][#2845991] In old Minsk refrigerators, a lack of refrigerant or a leak is a common suspect if the thermostat itself is working, and simply topping up may not last if the system is not tight [#2844795][#2844878] An empty refrigerator can also cycle more often, so the load inside matters too [#2843686]
  • #1 2843662
    loppy
    Please help what can be the reason for the fridge turning on very often. Every 5-7 minutes the compressor turns on. My energy consumption has tripled. This is the old Minsk glacier. The thermostat was replaced last year.
  • #2 2843676
    jesta19
    Help: 56
    Rate: 69
    check the tightness of the seal in the door, it is currently high temperature and the refrigerator needs to maintain the right temperature, so it turns on more often
  • #3 2843686
    gamafino
    Rate: 18
    also check the temperature at the time of switching on and off the refrigerator 2, the refrigerator should be full (does not suggest anything) because it turns on more often when empty
  • #4 2843828
    nokia 3650
    Help: 17
    Rate: 87
    Write this thermostat to what extent it is set, maybe to the max. And then it works like that. Have you not pulled out the plate under the freezer. Are there no dishes evaporating water, e.g. jelly. As for the thermostat, I say [I had a chimara myself] that the thermostat had to be set to minimum because she worked longer and froze quickly
  • #5 2844600
    loppy
    The plate under the freezer is there, and the thermostat is at minimum.
  • #6 2844761
    lukaszmichal
    Rate: 9
    dude, it's simple
    buy a thermostat for PLN 30 and replace it, if it doesn't help, throw away the equipment in the trash or you have gas leaked and you have enlarged the ozone hole or your circuit is clogged and it is not efficient and of course in these hot weather you can increase the thermostat setting and what you keep inside is also important such frozen ones can keep the temperature longer :) which makes the arrangement of eastern friends more economical :) I would also check the arrangement of the thermostat capillary, it may have moved or fell off the evaporator handle, which does not collect the temperature
  • #7 2844795
    HONDAS
    User under supervision
    Help: 40
    Rate: 26
    most likely, it will be the lack of coolant, if the thermostat is functional, replacing the fluid costs me from PLN 70 to PLN 100
  • #8 2844878
    rambler_
    Help: 5
    As others have already written - I bet the lack of cooling factor, but the supplement itself is not enough. I still suspect a lack of tightness - but the filling people will check it - but watch them otherwise in two months you will be filling again.
  • #9 2845885
    lukaszmichal
    Rate: 9
    I am young because I am 25 years old but I have not heard that the law will change and you can fill with r12 factor :) minsk bar on this factor i guess :) age may explain it a bit :) once I replaced the sprezare in minsk I gave him r134a and in a month the tubes opened because they were corroded since then I am asking people not to load money into the mud :)
    Amica for only PLN 699 Media markt :) :) It's slowly starting to become unbearable :)
  • #10 2845991
    jmk
    Help: 101
    Rate: 328
    the reasons for this condition are:
    -worn compressor - this leads to rapid pressure equalization in the system and an increase in temperature in the refrigerator
    - current high external temperatures - you describe only after how many minutes it turns on, so it has to work much longer.
    - thermostat whose hysteresis has changed (narrowed).
    What to do next - it's hard to tell without a precise measurement of the compressor's stop and start temperature - it's not easy, but some accurate ELECTRONIC thermometer would "prompt" something - don't even do it with an ordinary "outdoor". waste of time.
The discussion revolves around the frequent cycling of a Minsk Glacier refrigerator, with the compressor activating every 5-7 minutes, leading to increased energy consumption. Possible causes identified include a faulty door seal, inadequate cooling due to low coolant levels, and issues with the thermostat settings. Users suggest checking the tightness of the door seal, ensuring the refrigerator is adequately filled, and verifying the thermostat's calibration. Other potential problems include a worn compressor and high external temperatures affecting performance. Recommendations include replacing the thermostat if necessary and checking for leaks in the cooling system.
