Satellite Broadcasting: Are CYFROWY POLSAT, CYFRA+ & English SKY on Same Satellite?
infra 110120 7
  • #1 3146045
    infra
    Help: 11
    Rate: 10
    Hello, I would like to know if CYFROWY POLSAT or CYFRA PLUS are broadcast from the same satellite as the English SKY. I have access to the antenna set to SKY but without the possibility of moving it and I would like to know if I connect any of the Polish POLSAT or CYFRA decoders it will be picked up correctly.
  • #2 3146083
    Hirek2
    Help: 93
    Rate: 62
    The SKY Digital package broadcasts from the Astra 2A / 2B / 2D (28.2 ° E) a, C + and Polsat satellite with Hotbird 2/6 / 7A / 8 (13 ° E) so it will not work.
  • #3 3148292
    infra
    Help: 11
    Rate: 10
    no way??? hmmm, it's a pity, and if you connected some ordinary satellite decoder, could you find any Polish programs on this satellite?
  • #4 3148884
    jezrdna
    Help: 46
    Rate: 68
    Put on the second converter in the "squint"
  • #5 6825633
    michal_wichita
    I also want to change my antenna to c +
    please, the exact parameters, I want to see, maybe they have something not coded, I'm going to buy a decoder, but I want to check if I can handle the antenna setting, thanks
  • #6 6825849
    zabbii
    Help: 16
    Rate: 26
    As the previous speaker wrote - make a "squint" on the air (topic tortured many times, so you will find on the forum how to do it.
    Hot Bird has strong beams and even with small antennas the reception should be correct no matter from which satellite (C + and CP programs are broadcast from these three Hot Birds): Hot Bird 6 , Hot Bird 8 if Hot Bird 9 .
    If you set the converter precisely, there should be no problem with HB reception.
  • #7 6825858
    KazekTP
    Help: 5
    Rate: 10
    HotBird. Through him, the platforms send permissions to the card, etc.
  • #8 6825878
    zabbii
    Help: 16
    Rate: 26
    @michal_wichita
    If you want to watch free programs from Hot Bird, there are even a lot of them on Leaves in many languages. If you want to watch Polish, there are only a few of them and it's such a niche. Here you have it List with all free channels on all satellites (mainly HB and A) you can set the satka for whatever you want. You can always buy a C +, CP or N decoder because all these platforms broadcast from Hot Bird.
The discussion centers on the compatibility of satellite broadcasting between Polish platforms CYFROWY POLSAT and CYFRA+ with the English SKY service. It is clarified that SKY broadcasts from Astra satellites (28.2° E), while CYFRA+ and CYFROWY POLSAT are transmitted via Hotbird satellites (13° E). Therefore, a SKY antenna cannot receive Polish channels without adjustments. Suggestions include using a second LNB for "squinting" to capture signals from both satellites, as Hotbird has strong beams that can facilitate reception of Polish channels if the antenna is properly aligned. Additionally, there are free Polish programs available on Hotbird, although they are limited in number.
