Will Polsat Digital Work in England on Sky Dish or What Dish to Buy for Hot Bird 13E?
luck78 41261 5
  • #1 4846115
    luck78
    Will Polsat digital work in England on Sky antennas and if not what to buy. thanks and regards
  • #2 4846211
    krzysiek12sos
    Help: 51
    Rate: 85
    It should work normally, of course, the polsat decoder and the antenna set to Hotbird
  • #3 4849479
    bogi
    Help: 103
    Rate: 244
    You need to move the antenna, i.e. lift it up, turn it clockwise about 15 degrees.
    and reduce the bevel of the converter by half. You have everything in the pictures below.
    Here are the hot bird settings
    http://www.satlex.de/pl/azel_calc-params.html...&lo=-1.38&country_code=uk&diam_w=75&diam_h=80
    and so they have in the area
    Good luck.
  • #4 5641263
    d3mpsey
    Need to change the converter ?? I have the same problem, I haven't tried it yet, but before "combining" I want to make sure it's worth it - sky antenna and converter, Polsat echostar decoder.
    best regards
  • #5 5642167
    trzy8
    Help: 27
    Rate: 128
    There is no such need, unless damaged.
  • #6 5643416
    szycha
    Help: 13
    Rate: 49
    look at the position of adjacent SKY antennas, they are set to 28.2 degrees E, and your antenna should be set to 13 degrees E. In other words, if you were looking at the antenna from the converter side (from the front), drive the antenna to the left.
