After pressing a key, you need to hold it longer for something to appear.
01dalton 37914 5
  • #1 3287241
    01dalton
    Rate: 16
    Hello. I have a strange problem with the keyboard for 2 days, after pressing any key I have to hold it for more than 1 second for the key to appear. I looked at the keyboard settings - but it did not help. Where may the problem be. In advance for advice. Regards Wojtek.
  • #2 3288021
    Leot
    Rate: 9
    Hello, and such symptoms are only under windows or no difference?
    Fiercio
    Help: 5
    Rate: 47
    Press the right Shift for about eight seconds and see if the system still behaves like this.
  • #4 3288201
    01dalton
    Rate: 16
    Hello. Thanks a lot, Fiercio, your advice has been successful - everything is already OK :D :D :D . What could be the cause? Thank you again . Regards Wojtek
  • #5 3288252
    Fiercio
    Help: 5
    Rate: 47
    This is called the FilterKeys feature - it just blocks fast repetitive keystrokes.
    Open "Accessibility options" in the control panel and read about the Filter keys - it will be described there.
    (And a long press of the right Shift is a shortcut to quickly turn this function on / off)
  • #6 3288437
    01dalton
    Rate: 16
    Hello . Thanks again, I already get what's going on. Unfortunately, this is how a person does not know the exact device on which he works. Thank you again and best regards Wojtek.
