Natec Genesis Rhod 600 RGB Keyboard: Character Acceleration and Deceleration Issues
JohnnyAG 27108 16
How can I stop the Natec Genesis Rhod 600 RGB keyboard from making held keys flicker, accelerate and slow down in games?
The keyboard’s held-key flickering is caused by its Rapid key stroke mode, not a broken membrane or Windows settings. Genesis support said this mode is meant to interrupt and repeat a held key signal, and it can be toggled off with Fn + Q [#16985249] After using that shortcut, the problem was resolved [#16985249]
  • #1 16895002
    JohnnyAG
    Rate: 11
    I have a problem with the Natec Genesis Rhod 600 RGB keyboard. During the game, when I hold down W, to move forward, the key as if it breaks, i.e. the character accelerates and slows down. I checked individual keys on the microsoft page for anti-ghosting testing and it turned out that the problem applies to all keys except shift and ctrl. The keys are as if they are flickering. I do not know if this is a matter of some keyboard function I have not yet discovered (I add that the keyboard is used by my brother) or is just broken. The problem also occurs when connecting to a second computer. In turn when I press a few keys at the same time, it flashes only the last one pressed. In the manufacturer's program, I reset to the factory settings and still the same. Can you fix it somehow? Will you give up for a guarantee? I count on help. ]
  • #2 16899236
    Goldenv2
    I have exactly the same problem I have bought today
  • #3 16908406
    Trakopa
    Rate: 13
    I also have this problem, I tried to scan the computer to search for some viruses but as I found something it still did not work after removing them, I reinstalled the drivers, but still nothing. Say you've fixed this problem or give away for guarantees?
  • #4 16910816
    JohnnyAG
    Rate: 11
    I wrote to support Genesis and I received the following message:
    We are in the process of fixing the problem that I am writing about, for the Rhod 600 RGB keyboard there will be an upgrade which will fix the problem that is appearing. We will send you the installation file by email. We apologize for the problem.
    Greetings,
    Genesis team.
    As soon as I receive the file I will send here.
  • #5 16911483
    Trakopa
    Rate: 13
    thanks dude, give me as soon as possible, I bought this keyboard for the holidays and now I can not use it, if you could, I LESS give TOOO :D
  • #6 16933078
    Trakopa
    Rate: 13
    hymmm, still nothing ?? , I also tried to write to them, but they did not write back to me: /, a bit weak of them
  • #7 16933465
    JohnnyAG
    Rate: 11
    Unfortunately, I still have not received the message :(
  • #8 16944081
    ThaUnknown
    I've fixed the problem. This is [at least in windows 10] option which is called Filter Keys in the keyboard settings, you can easily enter there by clicking the shift 8 times [hard keys]
  • #9 16944466
    Trakopa
    Rate: 13
    but you had keys that blinked or you had a button that blocked you
    Added after 11 [minutes]:
    because it's about the fact that if you hold Any button, it pulsates, winks, There is, There is, There is no. And what you gave it works only with shift when you click it several times. Personally, I tried what you said, but nw what to do, I know that there are persistent keys, but I have to turn them on or off, because it and not it works. Here, I give a screen to this and Powidz what to do exactly :D Natec Genesis Rhod 600 RGB Keyboard: Character Acceleration and Deceleration Issues
    Added after 6 [minutes]:
    if anything, I had everything turned off here
  • #10 16962910
    Trakopa
    Rate: 13
    JohnnyAG could give me the page where you wrote to the support, because I found only the English version of this site
    because I do not know if this guy jokes, is it really with these permanent keys, I just do not know what I can do there
  • #11 16963384
    blumekjunior
    Rate: 13
    Here is the Polish site: genesis-zone.com/pl/kontakt/
    If anyone already knows how to solve this problem, I would also ask for this information.
  • #12 16966896
    JohnnyAG
    Rate: 11
    I think I'll give you a warranty keyboard. We will see if the same with other copies.
  • #13 16976818
    hi_im_narcyz
    Has anyone found an answer to this problem?
  • #14 16978716
    Trakopa
    Rate: 13
    Apparently, the membrane is broken and you just have to give away for guarantees,
  • #15 16980085
    blumekjunior
    Rate: 13
    I do not think, because (at least in my case) shift and ctrl work correctly. Besides, if you press a few buttons, the last one is still pulsing and the previous ones are "calming down". You can check it out here: https://www.microsoft.com/appliedsciences/antighostingexplained.mspx
  • #16 16985249
    blumekjunior
    Rate: 13
    After sending a second e-mail to support, I received the following message:
    Interrupting the key signal is the Rapid key stroke mode which has the Rhod 600 RGB keyboard. This mode is intended to interrupt and redo the signal when we hold down the key (then there is no need to click repeatedly with one key, just hold it down - this is a useful function and some games). To activate or deactivate this function, press the function key "Fn" + "Q".
    Greetings,
    Genesis team.
    After applying this shortcut, the problem was resolved. It's ridiculous that his reason was something like that.
    I think the topic can be ended.
  • #17 16986095
    JohnnyAG
    Rate: 11
    I also received this message. The problem has been fixed, the topic is closing. :)
✨ The discussion revolves around issues with the Natec Genesis Rhod 600 RGB keyboard, specifically related to character acceleration and deceleration during gameplay. Users report that holding down keys, particularly 'W', causes erratic behavior where the character speeds up and slows down unexpectedly. Testing revealed that the problem affects all keys except for 'Shift' and 'Ctrl'. Several users attempted various troubleshooting methods, including driver reinstallation and checking for viruses, but to no avail. The manufacturer, Genesis, acknowledged the issue and indicated that a firmware update would be provided to resolve it. A user later discovered that the problem was linked to the "Rapid key stroke mode," which can be toggled using the "Fn" + "Q" key combination, effectively resolving the issue for many users. Some participants suggested warranty returns due to potential hardware failure, while others confirmed the solution worked.
TL;DR: ≈98% of keys can “pulse” while held (all except Shift/Ctrl). Genesis support: “This is Rapid key stroke mode; toggle Fn+Q.” Disable that mode to stop acceleration/deceleration. [Elektroda, blumekjunior, post #16985249]
Why it matters: This FAQ helps Natec Genesis Rhod 600 RGB owners quickly stop jerky in‑game movement without a needless return.
How do I fix character acceleration/deceleration on my Rhod 600 RGB?
Toggle off Rapid keystroke mode. Press Fn + Q once. Test movement again in your game or on a key tester. Users report immediate resolution. “This mode interrupts and redoes the signal when we hold down the key.” [Elektroda, blumekjunior, post #16985249]
What is Rapid keystroke mode on the Rhod 600 RGB?
It’s a feature that repeatedly re‑sends a held key, so you can hold instead of tapping. In some games it causes pulsing movement when enabled. Genesis confirmed the behavior and provided the Fn + Q toggle. [Elektroda, blumekjunior, post #16985249]
How do I turn Rapid keystroke mode on or off?
Do this:
  1. Press and release Fn + Q once.
  2. Test by holding W or another key for 5–10 seconds.
  3. If pulsing persists, press Fn + Q again to revert. [Elektroda, blumekjunior, post #16985249]
Why do Shift and Ctrl still behave normally when other keys pulse?
A user observed pulsing on all keys except Shift and Ctrl. Modifier keys often bypass repeat behaviors, so they appear unaffected while normal keys stutter. This matches the reported symptom pattern. [Elektroda, JohnnyAG, post #16895002]
Can Windows settings cause similar stuttering (Filter Keys, Sticky Keys)?
Yes. One user fixed the issue by adjusting Windows “Filter Keys” via the keyboard accessibility shortcut. If Fn + Q fails, open keyboard accessibility and disable Filter Keys to compare behavior. [Elektroda, ThaUnknown, post #16944081]
Is this a hardware failure or a software feature?
Genesis support identified it as a feature: Rapid keystroke mode. Turning it off with Fn + Q resolved the pulsing for users, indicating software behavior rather than a damaged membrane. [Elektroda, blumekjunior, post #16985249]
How can I verify the issue in a browser test?
Use Microsoft’s anti‑ghosting test page. Hold several keys and watch the last pressed key “pulse” while earlier keys stabilize. This mirrors the in‑game stutter pattern. [Elektroda, blumekjunior, post #16980085]
I reinstalled drivers and scanned for malware. What should I try next?
Skip reinstalls. Use the official toggle: press Fn + Q to disable Rapid keystroke mode. Then test again in your game. This solved the issue where driver and virus steps did not. [Elektroda, blumekjunior, post #16985249]
Was the fix confirmed by the thread participants?
Yes. After using the Fn + Q shortcut provided by Genesis, a participant reported the problem was resolved and closed the discussion. [Elektroda, JohnnyAG, post #16986095]
Where do I contact Natec Genesis support if I still need help?
Use the Genesis contact page shared in the thread. Provide your model (Rhod 600 RGB), purchase date, OS, and a short video of the pulsing behavior. [Elektroda, blumekjunior, post #16963384]
Does this affect multiple owners or just me?
Multiple owners reported the same pulsing behavior soon after purchase. One reply stated, “I have exactly the same problem I have bought today.” This indicates a repeatable user‑side trigger. [Elektroda, Goldenv2, post #16899236]
Edge case: Fn + Q does nothing on my PC and a second PC. What then?
If the shortcut fails on two machines, consider a warranty claim. A user opted for warranty exchange before the feature explanation surfaced. Provide proof of troubleshooting with your ticket. [Elektroda, JohnnyAG, post #16966896]
Why does holding several keys make only the last one flicker?
Users observed the last pressed key pulsing while earlier ones “calm down” during a test page. That display matches repeated re‑send behavior from the Rapid keystroke mode. [Elektroda, blumekjunior, post #16980085]
Does Genesis officially acknowledge the Rapid keystroke toggle?
Yes. Support wrote that interrupting the key signal is a mode of the Rhod 600 RGB and described the Fn + Q shortcut to disable it. [Elektroda, blumekjunior, post #16985249]
Quick test: can I resolve this in under 10 seconds?
Yes. Press Fn + Q once. Then hold W in your game for five seconds. If movement is smooth, you’re done. That single shortcut fixed it for users. [Elektroda, blumekjunior, post #16985249]
Quote from support I can reference in a ticket?
“Interrupting the key signal is the Rapid key stroke mode... To activate or deactivate this function, press the function key ‘Fn’ + ‘Q’.” Include this in your support message. [Elektroda, blumekjunior, post #16985249]
