MSI K7T266 Pro2, Radeon 9600 Pro, Athlon 1700: PC Won't Boot, No LEDs or Fans
Epitaph_PL 90053 20
Why won’t my PC power on at all — with no LEDs, no fan spin, and no beeps — even though the PSU and graphics card seem to work?
The most likely fault is the motherboard or CPU, not the power supply, because the machine stays completely dead even in a minimal setup and the thread ends with replacing the motherboard and processor fixing it [#3319448][#3319678][#3322559][#3384373] Start with only the motherboard, CPU, a known-good PSU, and the system speaker, with all drives, cards, and RAM removed; clear the BIOS and test again [#3319448][#3319714] If the board is alive, you should get memory-related beep codes; if there is still total silence, the suspect list narrows to the board, CPU, wiring, or switch [#3319448][#3319464] Also verify the PSU by shorting the green wire to a black wire on the ATX plug, or borrow a better PSU for comparison [#3319678][#3319714] In this case, the later report that the PC worked after changing the motherboard and CPU strongly points to one of those parts failing [#3384373]
  • #1 3319388
    Epitaph_PL
    Rate: 8
    I'd like to know what could be causing the computer to not turn on. After pressing the button from the start, there is no reaction, the LEDs are off, the fans are not spinning, the monitor is black, the speaker is not beeping. The equipment started to break down for me some time ago, sometimes it did not turn on, when it turned on, artifacts popped up in games and basically that's it. The power supply is definitely working (I connected another one from a working computer), the graphics card works, I left the frame, one in the slot, the other pulled out and vice versa, and there were no signs of life (nothing beeps etc. etc.), I have no way to check the processor. I would like to know your opinion because I do not want to buy in vain. to replace the motherboard ?? or maybe something else ??
    Motherboard - MSI K7T266 Pro 2
    Graphics Card - Radeon 9600 Pro
    Ram -2x256 400MHZ
    Processor - 1700 Athlon
    Power supply - Tracker 350W ATX P3 / P4
  • #2 3319398
    wiezlak
    Help: 278
    Rate: 37
    Are the capacitors around the processor socket swollen or spilled? You connected a second power supply, but is it with enough power?
  • #3 3319428
    Epitaph_PL
    Rate: 8
    the capacitors are intact, the power supply was of the same power, I do not remember which company, I only know that it was standard with a tracer or mustang housing.
  • #4 3319448
    Figi
    Level 37  
    Help: 306
    Rate: 82
    Please start the computer in the configuration: motherboard + processor + power supply (but better than the standard one) + system speaker. Nothing more! Cards, memories, tapes taken from the disc.
    If there is no signal from system speaker, please reset BIOS settings and reboot in above configuration.
    You should hear a beep from the speaker, indicating a memory error. If it is not there, the group of "suspects" will narrow.
  • #5 3319464
    ion-tichy
    Help: 147
    Rate: 145
    you can try to run a bare disc without a memory processor etc. etc.
    if it does not start then:
    damaged switch or any element such as connector, path
    damaged power supply
    damaged motherboard
  • #6 3319587
    Epitaph_PL
    Rate: 8
    The bios reset did not do anything, no reaction, I started the computer in the above configurations and the same, the switch is rather good but I tried to run it "briefly" and nothing.
  • #7 3319612
    Figi
    Level 37  
    Help: 306
    Rate: 82
    What power supply did my friend start with?
    Epitaph_PL wrote:
    [...] I tried to run it "briefly" [...]
    It means?
  • #8 3319645
    Epitaph_PL
    Rate: 8
    Power supply - Tracker 350W ATX P3 / P4 (the one on which the computer ran before)
    briefly, i.e. the computer is connected to the network, the power supply is on and I was touching both wires with a screwdriver (powerfully)
  • #9 3319678
    Figi
    Level 37  
    Help: 306
    Rate: 82
    Epitaph_PL wrote:
    Power supply - Tracker 350W ATX P3 / P4 (the one on which the computer ran earlier) [...]
    After all, I asked to check on some better power supply ...
    Epitaph_PL wrote:
    [...] briefly, i.e. the computer is connected to the network, the power supply is on and I was touching both wires with a screwdriver (powerfully)
    Please try to start the computer by shorting (with the ATX plug plugged into the board) the green wire with the black wire.
    Is the computer unresponsive at all, or will it turn on the LEDs, spin the fan and turn off?
  • #10 3319714
    CZAPLIK
    Help: 5
    Rate: 18
    1 Remove the power supply from the motherboard and short the black (ground) to green (it should be next to the black). If the power supply starts, it is functional (disconnect other receivers, drives, disks, etc.)
    2 check the bios battery, although so far I have only encountered a disc that did not start on a weak battery so far, but it will not hurt
    3 connect the power supply if it turned out to be in working order - the frame plate. If all the game should (I think) give out 4 short beeps - no graphics
    4 if it did not start, disconnect the RAM should squeal when starting - no frame and graphics, I do not remember how many times
    5 if silence, take out the prock, connect only a fan to see that something is happening.
    6 if silence is either there is a disc or there is no bios in the bone (once the Chernobyl virus was cleaning the content of the bios)
    If at some point it gives signs of life - slowly attach the elements to the CD [/ img]
  • #11 3319929
    Epitaph_PL
    Rate: 8
    nothing silence, only the fan from the power supply was spinning, nothing more, neither diodes, nor the rest of the fans, nor the loudspeakers; silence. As for the power supply, I have no other one, but I can borrow from a friend the one I wrote about earlier.
  • #12 3321929
    ion-tichy
    Help: 147
    Rate: 145
    And does the colleague have a voltage meter - it is a very useful tool in diagnostics. If the power supply starts, it can be checked if it has all the voltage.
  • #13 3322559
    Figi
    Level 37  
    Help: 306
    Rate: 82
    Epitaph_PL wrote:
    [...] As for the power supply, I have no other one, but I can borrow from my friend the one I wrote about earlier.
    Due to the lack of better solutions, it can be, just write what the power supply is.
    If it is the same on the new power supply, the colleague has a damaged motherboard and / or processor.
  • #14 3326938
    Epitaph_PL
    Rate: 8
    I do not have a voltage meter, but I put the power supply into my friend's computer and the computer starts, so it seems to me that the power supply is good, I am forced to change the motherboard and processor for Christmas, if it turns out that the other parts were out of order, I will add it. (next week at the latest)
    thank you for helping everyone.
  • #15 3327083
    Figi
    Level 37  
    Help: 306
    Rate: 82
    Epitaph_PL wrote:
    [...] I transferred the power supply to my friend's computer and the computer starts, so it seems to me that the power supply is good [...]
    That doesn't mean anything.
    As for the rest of the ... well, you can anyway.
  • #16 3327102
    keychi
    Rate: 26
    artifacts are the result of overclocking / burnout of the graphics card modules ...
    but this may result in uneven voltage across the motherboard ...
    The fans do not spin, this may be the reason - too low power supply on the prock, too high clocking on it, or vice versa, an IDE / FDD ribbon attached
  • #17 3343150
    Epitaph_PL
    Rate: 8
    as for the artifacts, in fact, more of them popped up and faster than usual after increasing the CPU clock speed. After tomorrow, I go for new components, I will write if the card has not been damaged ... the tape is inserted well :)
  • #18 3343579
    Damnian
    Help: 193
    Rate: 89
    first, the motherboard will not start without a processor.
    Epitaph_PL do you have diagnostic diodes connected to the motherboard?
  • #19 3384373
    Epitaph_PL
    Rate: 8
    I replaced the processor and motherboard, the power supply is what it was, but I plan to replace it in the near future, everything smiga = D
    ps I had no diagnostic LEDs
    Thank you and best regards
  • #20 5890098
    A-S-U-S
    Hello !! I have a similar problem, my computer does not start, but the green diode is lit on the motherboard.
    it is good, I thought that I changed the switch to another one and so it does not even turn on the fan.
    GREETING IN advance.
  • #21 5890828
    fajny
    Help: 38
    Rate: 38
    Friend, not only that you "hooked up" to the topic, you also dug it up! Can't see the date of the last post?
The discussion revolves around a PC that fails to boot, showing no signs of life such as LED activity or fan movement. The user has already tested the power supply with a known working unit and confirmed that the graphics card operates correctly. Suggestions from responders include checking for swollen capacitors, testing the system with minimal components (motherboard, processor, power supply, and speaker), and resetting the BIOS. Despite attempts to diagnose the issue, including shorting the power supply and checking connections, the user ultimately replaced the motherboard and processor, which resolved the problem. The issue may have been exacerbated by previous overclocking, leading to artifacts in graphics performance.
