MSI B150M PRO-VDH - no image, EZ DEBUG LED + D LEDs do not light on the board
4d696368616c 12360 8
  • #1 16203238
    4d696368616c
    Processor: i5 6400 2.7GHz
    Memory: Kingston HyperX FURY 8GB (2x4GB)
    Power supply: Corsair VS Series 450W
    BIOS: I installed the last one about 2 months ago
    System: Windows 10 Home constantly updated
    Symptoms as in the title. Today I turn on the computer and all I see is a black screen. I open the case and see that two of the three LEDs on the motherboard are off. I took a close look at the album and didn't notice anything special. All parts are 14 months old. Please help. What can be the reason and can it be removed without unnecessary expenses?
    E: These are + DRAM and + CPU LEDs. The short description has apparently been cut off.
    E2: So the + VGA diode is on and it means that the problem is in the graphics system, right? I will add that I use integrated processor graphics.
    melanchel
    Help: 154
    Rate: 380
    I suggest replacing the power supply.
    310artur
    Help: 980
    Rate: 670
    It is worth to reset the BIOS to start with. Remove RAM, run without seeing if the status of the LEDs changes. Run RAM on one dice and see how it will be. At the moment it is hard to say.
  • #4 16205929
    4d696368616c
    Strange thing. Last night the computer turned on normally, not today again.
    After the BIOS reset and RAM removal, the + DRAM LED lights up. After testing each memory, the + VGA LED lights up separately.
    There will be a problem with the replacement of the power supply. I don't have access to any.
    melanchel
    Help: 154
    Rate: 380
    Look at the connectors for the sockets on the motherboard, especially the 4-pin processor power supply.
    You can measure the power supply voltage, as you can do with a multimeter.
    Attach a screenshot from the main window (SIV, Status).
    • SIV 5.14.zip (5.66 MB) You must be logged in to download this attachment.
  • #6 16206079
    4d696368616c
    I can't see anything there.
    As soon as I get a meter, I will measure it.
    How would I do that if the system did not boot?
    melanchel
    Help: 154
    Rate: 380
    How will it probably start again.
    And when starting up, no symbols (A2?) Are displayed on the black screen, bottom right corner?
  • #8 16206104
    4d696368616c
    Nothing but a black screen.
    EDIT
    I have successfully turned on the computer. At first this diode on the board was lit, but I left the room for about 2 minutes and after returning I saw that it took off. So I made screenshots of this program.
    I merged. RADU23
  • #9 17799028
    Kapi443
    And how did the action end? Because I have the same problem.
The user reports a black screen issue with their MSI B150M PRO-VDH motherboard, where the EZ DEBUG LED and D LEDs do not light up. The system includes an Intel i5 6400 processor, Kingston HyperX FURY RAM, and a Corsair VS Series 450W power supply. Initial troubleshooting steps suggested include replacing the power supply, resetting the BIOS, and testing the RAM modules individually. The user experienced intermittent success in booting the system, with the DRAM and VGA LEDs indicating potential issues with memory and graphics. Further advice includes checking motherboard power connectors and measuring power supply voltage with a multimeter.
