Vidicon Power Wave 8 Stuck in Standby Mode - How to Exit Without User Code
biczu1014 6780 5
  • Exiting standby mode without the user code
    #1 3439535
    biczu1014
    I recently came across a control panel as per the title (used). Everything was ok until I didn't press the arm button before changing the user code and the alarm went into standby mode without asking for the user code. Now, despite knowing the installer code, I cannot enter programming mode because even after powering down for 8 hours, standby mode remains. The manual doesn't say anything about a hard reset but I don't think it's possible not to? So my question is how to do it. In control units such as DSC you make a short circuit and everything is explained in the installer's manual. For this control unit I am looking and looking for this and cannot find anything on the internet.
    Regards
  • #2 3440224
    gigi-44
    Help: 97
    Rate: 99
    http://www.vidicon.pl/baza/upload/files/instrPW8.pdf page 6, at the bottom in the frame. It is true that I do not know how it will be in the vigil.
    • Power Wave 4-8-16-64 obs.pdf (419.58 KB) You must be logged in to download this attachment.
    • Power Wawe 4-8 inst.pdf (265.58 KB) You must be logged in to download this attachment.
  • #3 3440847
    biczu1014
    I've already done it ... with all lines with bridged and broken tmp and with all disconnected ... just the encryption itself. And that's how it turns on, it will show an alarm from the tamper line, but then the standby mode is on and you can not enter the programming mode: /
  • #4 3441031
    gigi-44
    Help: 97
    Rate: 99
    Yes, I know that it shows the alarm but after plugging it into the power supply, keep the program and enter keys pressed for 2 seconds and enter the installer mode and then reset the program address 620. Try again sabotage the keypad switch D, give it OFF, turn off the power, connect after a while and then program and enter. Write yet whether the control panel was divided into subsystems?
  • Questions about tamper behavior and default access codes
    #5 3444587
    biczu1014
    and other lines connect or should they trigger an alarm ?? because so-far everything is disconnected and went in NC mode so I have an alarm with 4 lines (because it was configured only for 4) and with tamper. In the cipherter, the tamper is on off. So far I have failed to enter the installer program :(
    I still have A and B on the encryptor but I think there was only one partition. No subcentral was there, it was just this one scrambler.
    Or maybe there is some user code that I could go back to the standby mode ?? Because after switching it on for the first time I pressed the program and without the enter code and entered the installer's file. The second time you had to enter the standard code 000000. Maybe it is also default for the user ?? Because the installer code from standby mode can not be out: /
    I have yet noticed such a thing that I have bridged 4 lines; resistor in the tmp line and on the encoder switch D to ON, after switching on the AC on the encoder, I have A B and MAINS lit and BATTERY flashes and MEMORY momentarily. However, when I have bridged the 4 lines resistor in the tmp line and on the encoder switch D dam to OFF then immediately after switching AC on the encoder I have MAINS, MEMORY (right away) BATTERY flashes as it was because it just does not have :) and TAMPER :| So how is it with this tamperer in the ciphers with how it gives on he does not call him, how about calling him off ??
  • Installer methods to recover forgotten user codes
    #6 3446664
    biczu1014
    What can the installer do when the user forgets its user code ?
    Answer : when the user forget his user code there are several things that the installer can do :
    - If the system is disarmed and direct access to installer mode is enabled then get into installer mode and check the
    code
    - If the system is armed you can use the upload/download software and then disarm , get the code and if needed
    change it.
    - If the system is armed there is a second possibility , in the default configuration the key-switch is enabled , so you
    can simulate a key-switch by adding a 4.7K ohm resistor to the tamper input . This way you can disarm the system
    - Another way to reach installer mode is the “back door “ option . If the installer enabled the back door option then
    you have to open the tamper , power up the system with a tamper opened and press “PROGRAM” than “ENTER”
    and the system enters installer mode
