[Solved] Title: Risco GTX One Switchboard & Solid Security - Adding Watch, Installer Code Issues, DIY Fixes
king kong 18954 19
How can I add another detector to a Risco GTX One alarm panel when the installer code no longer works?
You can reset the master and service/installer passwords yourself with the second DIP switch from the left, which restores access without erasing the panel settings [#17268742][#17274224] Power the panel down, change that switch, power it back up, verify that the factory passwords are restored, and then return the switch to its original position so it does not keep resetting on later power-offs [#17274224] If you still have free lines/zones in the system, you may be able to connect the new detector there without needing the installer password at all [#17260333] Programming from a PC appears to require service mode, so it is not a simple bypass if you cannot enter service access first [#17258815]
  • #1 17257194
    king kong
    I have a risco gtx one switchboard at home, founded by the previous owner. The control panel is connected to solid (contract with solid). Due to the fact that I am playing with electronics a little, I would like to add another watch. However, the problem is the installer code, the one in the instructions does not work (that's fine :) . Solid, due to the fact that the warranty on the system has already expired, wants PLN 150 net for driving up and changing the code to the factory. What do you suggest Connect with a computer and try to do something by yourself, reset to factory settings ??
    Thanks in advance for your answer.
  • #2 17258815
    szymon122
    Help: 302
    Rate: 762
    In my opinion, programming mode (connection with PC) can only be started from the service mode. I don't know this system, but it seems a bit obvious.
  • #3 17258879
  • #4 17259800
    Gutek1512
    Help: 39
    Rate: 37
    And why the company after the warranty period did not come alone and restored the factory installer code? The system is theirs or yours. This can buy an apartment, give the keys to the intervention group and pay for each entrance to the OWN apartment to an external company. I would not give up, ordered them to restore the code in writing, and so on the subject.
  • #5 17259847
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    And why would they do it for free? If you buy a TV set, if you want to unscrew it, you call the manufacturer to remove the warranty seals or come with a screwdriver because he just used some unusual screws ??
  • #6 17259896
    Gutek1512
    Help: 39
    Rate: 37
    You only buy a TV set with the possibility of configuration, you do not call the service for that.
  • #7 17260068
    kood
    Help: 259
    Rate: 443
    The alarm also allows you to configure as much as you need for everyday use, just like on the TV. Go ask the TV manufacturer for the processor charge, preferably with a request that it come and make it available to you for free. Good luck.
  • #8 17260277
  • #9 17260333
    kood
    Help: 259
    Rate: 443
    krolik2 wrote:
    The truth is that the client should know the installer code from the very beginning.
    I think that installers do not mind, the customer signs the cancellation of the warranty and that he takes full responsibility for the system and probably every installer will provide the client with the installer code.
    Just like in the case of a broken warranty seal, the customer looked and rummaged where it should not be there is no guarantee or liability of the manufacturer.
    I suggest first checking if you still have free lines in the system, it is still possible to connect to any of the detectors that are installed, then it can be done without the installer's password.
  • #10 17267179
    king kong
    Thank you all for your reply.
    There are still 2 free lines in the system and I want to connect to them.
    I read somewhere that even a reset does not restore the factory password, so it's bad. If it resets and the service password remains unchanged, unfortunately, but I will remain without an alarm.
    The solid position is that it changes the password for free at the end of the warranty, if the warranty has already expired they want PLN 150 net of tax. I think I need to change the security company.
  • #11 17268374
    suworow
    Help: 650
    Rate: 1278
    don't be afraid "How can you restart it and give you access to programming. Otherwise what would it make sense?
    I am not a fan of this security company (which I have expressed many times), but I think my colleague expects too much from them. If I were to assess the sense of cooperation with a given AO, I would take other considerations into account.
    best regards
  • #12 17268742
    howaitofurasshu
    Rate: 11
    The second dip from the left only resets passwords (master and service). You won't lose the settings so you can do it yourself.
  • #13 17274121
    king kong
    Are you sure it only resets passwords?
  • #14 17274224
    howaitofurasshu
    Rate: 11
    Yes, the settings are restarted in the software settings.
    Turn off the power, change the state of the switch and turn it on, check that it has returned to its factory passwords and peace of mind.
    Before you finish, switch the switch back for a simple reason, so that when you switch off the control panel, do not reset the passwords again ;)
  • #15 17923321
    pawelkunik
    Gentlemen, what is the default installer code for GTX One? Thanks in advance for your answer
  • #16 17923364
    howaitofurasshu
    Rate: 11
    You know the rhyme for:
    Blonde code is ...
    Four ones.
  • #17 17951695
    rolniksam
    Security companies intentionally change the installer code to hinder the transition to competition. You terminate the contract and request that the factory codes be restored.
  • #18 17951718
    pawelkunik
    Can anyone else tell me how to find this Dip Switch? I haven't rummaged inside it yet. Forgive me if the question seems trivial ...
  • #19 17951719
    suworow
    Help: 650
    Rate: 1278
    And I thought so far that the code changes primarily to prevent an unauthorized person from changing the system settings. I understand that a colleague does not change?
    When you open the case, everything will become clear :) I would look on the right side of the record :)
  • #20 17951763
    howaitofurasshu
    Rate: 11
    No, the dips are in the center of the board a bit above the casing tamper spring, even nicely labeled ?
The discussion revolves around issues faced by a user with a Risco GTX One switchboard, particularly regarding the installer code needed to add a new watch to the system. The user is unable to use the provided installer code and is considering a factory reset or connecting to a PC for programming. Responses suggest various approaches, including resetting DIP switches to restore factory settings, checking for free lines in the system, and the implications of warranty expiration on service costs. Some participants express frustration with security companies for not providing the installer code after warranty expiration, while others discuss the technical aspects of accessing and resetting the system without professional help.
TL;DR: Default GTX One installer code is 1111; "Four ones." If it was changed, restore factory passwords and then wire your new sensor to a free line, rather than wiping the whole setup. [Elektroda, howaitofurasshu, post #17923364]
Why it matters: This helps homeowners with Risco GTX One panels locked by installer codes add sensors and regain control without unnecessary service calls.
How do I reset only the installer and master passwords (not the whole panel)?
Use the onboard password-reset DIP.
  1. Power off the control panel.
  2. Change the reset DIP’s state, then power on.
  3. Confirm factory passwords work, then return the DIP to normal. This process doesn’t erase other settings. [Elektroda, howaitofurasshu, post #17274224]
Can I program the GTX One from a PC without the installer/service code?
No. Programming mode starts from service mode. Without the installer code, you cannot enter that mode. [Elektroda, szymon122, post #17258815]
What does Solid charge to restore factory codes after warranty?
One user reports Solid restores for free at warranty end. After expiry, Solid quoted PLN 150 net to reset. [Elektroda, king kong, post #17267179]
Can I add another detector/zone without knowing the installer code?
Yes, if spare lines exist. Connect the detector to an unused zone input. This basic wiring can be done without the installer password. [Elektroda, kood, post #17260333]
Should I perform a full factory reset to regain access?
Avoid it unless you plan to reconfigure everything. A factory reset wipes setup and requires complete programming again. [Elektroda, Anonymous, post #17258879]
Why do installers change the installer code?
To prevent unauthorized changes to critical settings. As one pro notes, it’s “to prevent an unauthorized person from changing the system settings.” [Elektroda, suworow, post #17951719]
Will a reset grant me access to programming mode?
Yes. After a restart, you can program with factory passwords. “Don’t be afraid... restart it and give you access to programming.” [Elektroda, suworow, post #17268374]
How do I locate free lines to add a sensor?
Inspect the zone terminals for unused positions. If you have free lines, you can connect a new detector there. [Elektroda, kood, post #17260333]
