Integra 32 - blocking the service mode after violation of the LCD keypad
savero 22383 9
How can I unblock service mode on an Integra 32 after a keypad tamper, and do I need a pin reset or just a waiting period?
You need to enable Service access from the administrator/user level first: enter the code, press * (not #), find “Service access”, set the time, and confirm it, then enter TS/service mode [#16482587][#16515937] Once service access is active, the tamper/sabotage message is cleared by entering the service code and confirming with # [#16482621][#16515482] If service access is still blocked and you do not know the service password, the thread says a reset “from pins” may be necessary [#16515482] The replies do not describe this as a simple time block; they point to missing/disabled service access instead [#16482587][#16515937]
  • Service mode may be time-blocked after tamper violation
    #1 16482577
    savero
    For Integra 32 Satel
    Such a matter. During painting, I violated the reconstruction of the LCD keypad. It began to howl. I pressed the cover back in, entered the user's password and the alarm stopped. A tamper message appeared on the display. I tried to enter the service mode to clear the message. Unfortunately no access - service mode blocked. Is the reset "from pins" waiting for me in the given case, or is it possible that it is a time block?
    Regards
    Wojtek
  • #2 16482587
    sosarek
    Help: 9320
    Rate: 15532
    Enter the Administrator password, press *, look for Service access # enter time #, enter the TS.
    Z
    Pka, Poznań, 60-850
  • #3 16482621
    dariusz.bembenek
    Stationary Alarms specialist
    Help: 455
    Rate: 615
    What colleague Sosarek wrote:
    If you start the service access, then clearing the message: "There was sabotage, call the service" (I assume that this is the message, but a colleague has not written it) is done by the following sequence:
    Service code + # (not *).
  • #4 16482631
    savero
    Entering the service password and # throws me no access to TS or something like that and the message about sabotage hangs on.
  • #6 16482644
    dariusz.bembenek
    Help: 455
    Rate: 615
    I think my friend is making balls. After all, a colleague got a message from a colleague sosarka to start the service access first ...
  • #7 16482670
    savero
    Sorry, gentlemen. This is new to me, I am still in the dark in this topic. Is the administrator and service password one and the same? I bought a house with this alarm and the former owner only left me the user code and service code.
  • #8 16482674
    sosarek
    Help: 9320
    Rate: 15532
    No - as the name suggests.
    Enter the code you are arming, end it with * instead of #, check if you have Service Access on the list of options.
    Z
    Pka, Poznań, 60-850
  • #9 16515482
    indeshi
    My friend.
    After entering the service code (by default 12345) and confirming # the tamper message should be cleared.
    If you do not know the service password and you do not have access to the service, then you need to reset "from pins".
    By the way, I find it a bit strange that the previous owner did not provide the colleague with an administrator password, it is best to connect the control panel to the computer and manage users according to your needs.
  • #10 16515937
    sosarek
    Help: 9320
    Rate: 15532
    If the service access is blocked, it will not do it this way only as described above:
    Z
    Pka, Poznań, 60-850
The discussion revolves around a user experiencing issues with the Integra 32 alarm system after a tamper event caused by a damaged LCD keypad. The user is unable to access the service mode to clear a tamper message, leading to inquiries about potential resets or time blocks. Responses suggest entering the correct service code, confirming access through the administrator level, and clarifying the difference between user and service passwords. If access remains blocked, a reset "from pins" may be necessary. The importance of obtaining the administrator password from the previous owner is also highlighted.
