Integra64 Displays Set Clock After Startup, Keyboard Unresponsive to Admin Codes
marszma4 27249 9
Why does an Integra 64 show "set clock" after power loss and refuse admin/service codes even though the keypad responds?
This is usually caused by a dead or poorly contacting 3.3 V backup battery on the Integra control board, because the panel stores passwords in battery-backed memory [#13042745] [#13026594] [#13027871] Check that the battery is seated correctly and replace it if needed; if the problem still persists, the board may need service [#13042745] If you can get into service mode, the clock can be set from the keypad or through DloadX after using the emergency startup procedure [#13041683] One user also reported that uploading new software solved the issue [#13760411]
  • #1 13026193
    marszma4
    Rate: 11
    As in the topic, after starting the message set the clock, the keyboard responds but I cannot enter the menu with the password 1111 administrator or service 12345. The service from the pins was successful at some point, restarted the settings and everything works. After disconnecting the power supply, the message setting the clock again and no response to passwords.reboot from pins not possible.
    Has anyone had a similar problem?
    new plate
    Regards
    Announcement
    Read also:
    Satel Integra - system configuration - selected issues Selected most interesting topics regarding the configuration of the Satel Integra system
    Outputs (programmable and more) of alarm control panels
    How the control panel alarm outputs work
    Connecting any detector to any alarm control panel - guide
    How to connect the siren to the alarm control panel - guide
    Types of Integra control panel outputs that we use in home automation
    Central heating furnace - integration with alarm (e.g. Satel Integra)
    ETHM 1 Plus/ Integra Control. Selected Issues.
    We invite you to read other guides, highlighted topics and articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security systems guides
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Guides
  • #2 13026594
    Alberciak
    Help: 41
    Rate: 60
    Check the battery on the motherboard.
  • #3 13027871
    marszma4
    Rate: 11
    battery 3.3V
  • #4 13028051
    extremeee
    Help: 50
    Rate: 50
    And the keypads were identified and saved to Flash?
    After restarting, make an identification and save to Flash.
  • #5 13041343
    marszma4
    Rate: 11
    Everything was done according to the procedure and after disconnecting the power supply, there is no access from the keypad. The display shows asterisks instead of the password, but it still does not accept and does not allow entering the menu.
    Regards.
  • #6 13041683
    scooby117
    Rate: 58
    Read the "Emergency procedure for starting the control panel" in the manual - if it is performed, connect to the control panel using the Dloadx program and set the time, or do it manually from the keyboard.
    It`s the same in my Versa - after disconnecting the power supply (battery + AC) and restoring it, the system has a "Set clock" error. After the service entry and its setting, everything is OK.
    If the service password 12345 does not work for you (the asterisks are absolutely correct), you may have simply changed it.
    Do you use your own feed or someone else`s?
    Personally, I came to the conclusion that it is better to make my own - at least there are no problems with connection or `identification`.
    Regards
  • #7 13041913
    marszma4
    Rate: 11
    I don`t think we understand each other.
    Let`s say that I managed to start the control panel from the pins, reset all the settings to factory defaults, set the addresses and keypad identification, set the time and manufacturer`s passwords. When I leave the website, everything works fine. I can log in as administrator 1111, service 12345. After disconnecting all power supplies, i.e. the battery and 230V, and reconnecting them, the message "set the clock" appears, I cannot access any of the logins. I enter 1111# or OK on the display**** and no entry. 3.3V on-board battery.
    It was the first time I encountered such a symptom, usually the control panel reported automatically and asked me to perform the procedures, which I did without any problems and everything was accepted and it works.
    Regards.
  • #8 13041961
    scooby117
    Rate: 58
    Regards.
    As I mentioned - in my case, after disconnecting the battery and AC and reconnecting it, I also have the "set the clock" message.
    In this case, enter the code (administrator or service, I don`t remember now), but if you have the factory one, 12345 and confirm with an asterisk "*".
    Then dial 6 2 # (Settings --> Clock). Set the clock and leave - everything should be OK. The manual is from VERSA-LCD, so the menu may be slightly different, but the principle of operation is the same.
    For example, for INT-KLCDL it is CLOCK PROGRAMMING --> SET TIME --> SET DATE.
    Ew. if you use Dloadx and you get the "set clock" message, log in as service (12345*) select 0 0 # (Service --> Service mode) - for Versa-LCD.
    Similarly, in INT-KLCDL - after logging in as a service, select "Service mode". Then in Dloadx, after connecting, press "Clock programming" and that`s it.
    After setting the correct time, clear the alarms and everything should work fine. There is no backup for the RTC and this is apparently where the problems come from, but on the other hand the system is supposed to work continuously, after disconnecting the AC there is a battery, so you can somehow get over it.
  • #9 13042745
    fred4u
    Help: 94
    Rate: 198
    INTEGRA stores passwords in battery-backed memory, so the described symptoms indicate a dead or non-contacting battery or a damaged board.
    After checking the battery (is it inserted correctly??), if the problem persists, the board should be serviced.
    M
  • #10 13760411
    marszma4
    Rate: 11
The discussion revolves around issues with the Integra64 control panel, specifically regarding the inability to set the clock after startup and unresponsiveness of the keyboard to administrator and service passwords. Users suggest checking the motherboard battery, ensuring keypads are identified and saved to Flash, and following emergency procedures outlined in the manual. Some users report that after disconnecting power, the system prompts to set the clock, but passwords are not accepted. Solutions include using the Dloadx program for configuration and ensuring the battery is functioning properly, as symptoms may indicate a dead battery or a damaged board. One user resolved the issue by uploading new software.
