DIY wall microphone setup for eavesdropping: best sensors, amplifiers, and techniques
Dolby* 45223 3
  • #1 3522402
    Dolby*
    Rate: 18
    Hello...
    This morning, when I was lying and listening to the floor, hearing a chattering neighbor, I began to wonder if it was possible to eavesdrop through the wall ... as it happens with a glass ... or if, for example, :P I would put a semi-circular bowl with a microphone in the shape of a satellite dish, it would greatly improve the effect?
  • #2 3522433
    Cinek_as
    Help: 23
    Rate: 15
    You'd hear an echo :) I think so ;) but you can try because making the transmitter itself is not expensive and use a regular radio as the receiver ;)
  • #3 3522653
  • #4 3523457
    Dolby*
    Rate: 18
    You would probably hear an echo, I think so, but you can try it because making the transmitter itself is not expensive and use a regular radio as a receiver
    I mean that I would make a spotlight glued to the wall so as to pull from the largest possible surface ... no transmitter, clean headlight + microphone ... there is still the question of choosing a microphone and an amplifier
