Can I Replace a 0.5W Resistor With Two 0.25W Resistors in Series or Parallel?
silat_ss 31976 30
Can I replace a 0.5W resistor with two 0.25W resistors in series or parallel, and how do resistance and power ratings combine?
Yes, if the resistors are equal and the circuit shares the load evenly, two 0.25W resistors can replace one 0.5W resistor; the usable rating depends on how the voltage/current divides and on the weakest resistor [#3833110][#4083072] In series, resistance adds and the voltage splits, so two 100kΩ/2.5W resistors can replace one 200kΩ/5W resistor [#3742173] Another example given was two 50Ω/0.5W resistors in series replacing one 100Ω/1W resistor, because each resistor then dissipates about 0.5W [#3742290] The thread also states that the dissipated powers add up regardless of whether the resistors are in series or parallel, but each resistor still must stay within its own rating [#3741914][#3833110] If the resistors have different values or power ratings, the smaller-rated part can become the limiting factor [#4083072]
  • #31 4083072
    zybex
    Helpful for users
    Help: 2094
    Rate: 2933
    So if I connect a 0.1W resistor in series and, for example, 10W, the power will be added? I wonder if this small resistor will cope with a circuit with significant power, or maybe we will only see smoke for a short while? :D
    My answer is that if we connect different resistors in series (when it comes to their power), the resultant power will be the same as the resistor with the smallest power. I write this as a practitioner, not a theorist.
✨ The discussion centers on the behavior of resistors when connected in series and parallel, particularly regarding their resistance and power ratings. When resistors are connected in series, their resistances add up, but the power rating of the combination is limited by the resistor with the lowest power rating. For example, two 0.25W resistors in series will not provide a total power rating of 0.5W; instead, they will effectively have a combined power rating of 0.25W. In contrast, when resistors are connected in parallel, their power ratings can be added together, but the total resistance decreases. The conversation also touches on practical applications, such as using multiple lower-rated resistors to achieve a desired resistance and power rating, and the implications for devices like light bulbs and high-voltage circuits.
TL;DR: Need a 0.5 W resistor? Using two 0.25 W parts in series or parallel gives the same 0.5 W rating—a 100 % increase—because, as one engineer states, "power is added"[Elektroda, CMS, post #3741568]
Why it matters: This lets you solve parts shortages without changing circuit behaviour.
• Two identical resistors (series or parallel) double the wattage; four quarters equal 1 W[Elektroda, kankan, post #3741584] • Series chains split voltage; parallel nets split current[Elektroda, szod, post #3741914] • Typical film resistors derate 50 % at 70 °C[Ohmite Datasheet, 2022]. • 3-resistor strings routinely handle ≥1 kV to cut cost[Elektroda, jony, post #3742173] • Two 230 V bulbs in series draw roughly 140-150 W, not 200 W[Elektroda, żarówka rtęciowa, post #3742158]
Can I swap one 0.5 W resistor for two 0.25 W in series?
Yes. Each half sees half the voltage, so each dissipates 0.25 W; together they handle 0.5 W[Elektroda, CMS, post #3741568]
How do voltage and current split between identical resistors?
Series: voltage divides equally, current stays equal. Parallel: current splits equally, voltage stays equal[Elektroda, szod, post #3741914]
What if the resistors are not identical?
The lowest-watt part limits chain power. One 0.1 W in series with 10 W still limits to 0.1 W[Elektroda, zybex, post #4083072]
How can I build a 2.2 kΩ 1 W resistor from four 2.2 kΩ 0.25 W parts?
  1. Make two parallel pairs (each 2.2 kΩ || 2.2 kΩ = 1.1 kΩ, 0.5 W).
  2. Connect the two pairs in series (1.1 kΩ + 1.1 kΩ = 2.2 kΩ).
  3. Combined rating: 0.5 W + 0.5 W = 1 W[Elektroda, Aleksander_01, post #3833048]
Is power always simply added, whatever the connection?
For equal-value parts, yes; total allowable dissipation equals the sum. Unequal parts need individual checks[Elektroda, emka371, post #3833110]
What happens during an overload edge case?
Exceeding the smallest resistor’s rating causes it to overheat first, often within seconds, leading to smoke or open-circuit[Elektroda, zybex, post #4083072]
How do I derate resistor power for ambient temperature?
Most carbon-film parts drop to 50 % power at 70 °C and 0 % at 155 °C[Ohmite Datasheet, 2022].
Is there a quick rule for N identical resistors?
Total wattage = N × single-wattage. Total resistance: N×R (series) or R/N (parallel).
How do I estimate power dissipation fast?
Use P = V²/R or P = I²R. Measure voltage across, or current through, the resistor with a DMM; plug into formula[Horowitz & Hill, 2015].
