Changing the network from 100Mb to 1Gb, does the cable also need to be replaced?
bartekpl 44398 16
Do I need to replace the network cable when upgrading from 100 Mb/s to 1 Gb/s Ethernet?
You do not necessarily need to replace the cable, but it must be a cable intended for Gigabit Ethernet, such as Cat 5 or Cat 6 as noted on the insulation [#3930962][#3930899] Check the cable jacket for the category marking; one reply says it is usually printed there, and mentions examples like “4PR Cat. 5e IEC” or cables certified for gigabit Ethernet [#3930923][#3930977][#3930945] If the cable is only a 4-core / 2-pair cable, that is enough for 100 Mb/s but not the point of a gigabit upgrade [#3930923] Also remember that the switch and the rest of the equipment on the path must support gigabit too [#3930923] Even with gigabit hardware, 1 Gb/s is only a theoretical maximum and real throughput depends on cable length, equipment performance, and connection quality [#3930982][#3930991]
  • #1 3930886
    bartekpl
    Hello!
    I would like to speed up my network and go from 100Mb (Fast Ethernet) to 1000Mb (Gigabit Ethernet) ...
    Do I have to replace the network cable in addition to changing network cards?
  • #2 3930899
    szymon188
    Help: 50
    Rate: 39
    It depends on what cable you have currently used. CAT 5 or 6 cables are used for gigabit networks.
  • #4 3930914
    bartekpl
    How can I check? I have 8 lives, as probably everyone ... hmmm?
  • #5 3930923
    badboy84
    Help: 1197
    Rate: 1486
    it should be printed on the cable, otherwise you won't check it
    4-core cables (2 pairs) can also be used in 100Mb networks, but by the way,
    apart from the cable and cards, you have to remember about the rest of the equipment, i.e. switches, etc., everything that is on the way ...
  • #6 3930929
    bartekpl
    I have bought Swish ... SMC but what should be written on this cable? Exactly because there are a lot of these signs? What symbol should I pay attention to?
    So it doesn't matter if it will be cat 5 or cat 6?
  • #7 3930945
    badboy84
    Help: 1197
    Rate: 1486
    preferably cat6 or something like that
    For example, I have a YFC cable on the cable "certified for gigabit ethernet"
  • #8 3930951
    bartekpl
    It is true that the network is in the company and there are many computers, but when I checked how much it will take, it does not exceed 40% (I will check tomorrow) ... And the computers are strong ... 3Ghz processors, SATA etc ...
    There is some program to diagnose the connection, test the connection ...
    Is it possible to use a 1Gb network completely between computers connected by such a network when copying from disk to disk? Because it's hard for me to believe it somehow :) I do not know why... ?
  • #9 3930962
    szymon188
    Help: 50
    Rate: 39
    :arrow: bartekpl
    As my colleague badboy84 gigabit ethernet wrote, it will work on both cat 5 and cat 6 cables. cable construction for each category. Besides, there will be an imprint on the cable insulation of what category the cable is or in what technology it was made.
  • #10 3930977
    bartekpl
    I recall my earlier questions so that they would not be forgotten :)
    Is it possible to use a 1Gb network completely between computers connected by such a network when copying from disk to disk? Because it's hard for me to believe it somehow, I don't know why ...?
    I have something written on the cable at home:
    4PR Cat. 5e IEC
  • #11 3930982
    szymon188
    Help: 50
    Rate: 39
    1Gb / s is the theoretical speed of this connection so and only theoretically possible to achieve.
  • #12 3930984
    bartekpl
    Well, yes, but I will get 80%?
  • #13 3930991
    szymon188
    Help: 50
    Rate: 39
    It depends on many factors. Cable length, equipment performance, connection quality, etc.
  • #14 3931001
    bartekpl
    szymon188, if you can, go to the gg, I wrote to you from my number. I would be grateful if we talked about the network for a moment because I am exchanging the network in the company and I need to educate myself :)
  • #15 3931483
    kaczmi
    Help: 6
    Rate: 11
    I have a question: I have an Ethernet giga on my motherboard (the card can detect cable lengths and test them quickly). I would like to make a connection between 2 computers in one network, does the crossover cable differ from that on 100Mb ??
  • #16 3931500
    bartekpl
    and what program does it do?
  • #17 3932212
    jacekowski
    Level 19  
    Help: 13
    Rate: 10
    it is not a matter of the program, but the card's electronics and it is most likely a marvell card (if only it had TCP-Offloading - it would be an ideal card)
    and the crossover cable between the ordinary one differs only in that the ordinary one has the same order in both plugs and the crossover cable in one is changed
To upgrade a network from 100Mb (Fast Ethernet) to 1Gb (Gigabit Ethernet), the type of cable currently in use is crucial. CAT 5e or CAT 6 cables are suitable for Gigabit networks, while CAT 5 cables may also work but are less reliable. Users can identify the cable type by checking for printed specifications on the cable itself. Additionally, other network equipment such as switches must also support Gigabit speeds to achieve optimal performance. Theoretical speeds of 1Gb/s may not be fully realized due to factors like cable length, equipment performance, and connection quality. Crossover cables differ from standard cables in wiring configuration but are not specifically tied to speed categories.
