Mass Effect on Free Fall: Debunking Weight's Impact on Falling Speed & Time, V = g * t
Soohy_tm 55233 12
Does object mass affect how fast and how long it falls in free fall, assuming no air resistance?
No—in an ideal vacuum, mass does not affect free-fall speed or fall time; free fall depends on Earth's gravitational acceleration, not on the object's weight, so you can use v = g·t [#3963889] In normal air, you cannot measure pure free fall because air resistance is present [#3963889] In air, falling is influenced by gravity (m·g) and drag from air particles, which depends on speed and shape, so different objects can behave differently there [#3964070][#3965889] A CO2 balloon goes down because CO2 is heavier than air, while a hydrogen balloon rises because hydrogen is lighter than air [#3964070]
  • Question about air resistance and mass during free fall
    #1 3963861
    Soohy_tm
    Hello everyone!
    I am writing this post because I have quite a dilemma ... Well, all my friends, family, etc. say that body weight affects the speed and time of falling (free, of course). I am trying to disprove this theory, I even made a bet with a few people :P , but the formula V = g * t alone does not give anything, and the example of throwing objects into the abyss and measuring the speed after time t, e.g. 3sec, 5sec etc. does not result in: / It is about ideal conditions, so no air resistance, or exactly equal resistance. I am begging you, help me convince them that it is as I say. :) Oh, of course, I am asking for answers only from those whose information comes from a reliable source, and not from "peasant reason" :P Thanks in advance to everyone :)
    PS You can explain why the hydrogen balloon will go up despite gravity and the CO2 balloon will fall ...
    And of course, so as not to be accused of it, I did a test with beer cans :D one empty second full - they fell the same, but everyone said that the distance was too short ... I'm broken! I'm throwing from the 3rd floor tomorrow :D
    Free-fall speed depends on g, not body mass
    #2 3963889
    karlos79
    Help: 254
    Rate: 77
    Free fall:
    http://fizzyka.webpark.pl/kinematyka/spadanie/index.htm
    Under normal conditions, you will not determine the free fall velocity of the bodies, because you do not have a vacuum.
    Free fall only occurs in a vacuum.
    For the calculation of the free fall velocity, the body mass is not taken into account, but the accelerations due to Earth, which depends on the height above sea level and latitude.
    Mass-independent free fall with air drag and buoyancy
    #3 3964070
    werpa_29
    Help: 20
    Your test with beer cans confirms that the weight has no effect on the "free fall", however when you throw from a greater height there may be a difference in speed but not due to the difference in mass only by friction between the body and air particles.
    A balloon filled with CO2 flies down for a simple reason - CO2 is heavier than air, and a hydrogen balloon rises because hydrogen is lighter than air.
  • #4 3964670
    Soohy_tm
    Come on thanks guys!
    I hope it is enough, although there is never enough opinion :)
    Buddy werpa_29, then a balloon with CO2 and He in a vacuum ... well, they would burst :D :D
  • #5 3965470
    staszeks
    Help: 84
    Rate: 81
    I hope it will be enough, although there is never enough opinion :)
    you're right.
    If they are tight and strong enough, they will fall equally.
  • #6 3965889
    Paweł Es.
    Help: 1236
    Rate: 693
    The weight affects the falling, but only in the air!
    Two forces act on a body falling in the air:
    - gravity force Fc = m * g
    - air resistance force Fo = 0.5 * ? * Cx * A * V * V; [N]
    Cx - shape factor
  • Explaining terminal velocity and longer fall time with air resistance
    #7 3966432
    czucz
    Paweł Es. wrote:
    As the speed is steady and does not increase continuously as it would in the absence of air resistance, the fall time will be longer than in a vacuum.
    Just when the forces balance each other, according to Newton's First Law of Motion, the body moves with a uniform motion.
    Soohy_tm, you must have mistaken the example that the schools usually give that a kilo of feather drops as quickly as a kilo of steel in a vacuum where there is no resistance. Two kilos of feathers in a vacuum will drop faster than a kilo of steel.
  • Combining equal masses does not change free-fall acceleration
    #8 3966917
    qrdel
    Help: 100
    Rate: 71
    And they explain, explain, and somehow they have not internalized this knowledge.
    If a kilo of feathers (under ideal conditions, in a vacuum) drops at the same speed as a kilo of steel, then the next kilo of feathers next to the first one also drops so, but if we combine them together (these feathers in 2 kilos), it will accelerate it?
    As a reward for such theories, I suggest dropping a kilo of feather on one leg and a kilo of steel on the other.
    PS Of course I know you should write a kilo.
  • #9 3967182
    czucz
    A kilogram is a kilogram, no matter if it is feather or steel, it will hurt the same. Unless, according to you, a kilogram of feathers weighs less.
    If you drop 2kilo on one leg and a kilogram on the other leg, you will feel the difference.
    Ps. kilo - kilo my mistake, I confused it with the prefix 10 ^ 3
  • #10 3968625
    staszeks
    Help: 84
    Rate: 81
    And I would also consider the buoyancy
  • #11 3968922
    jiwaniuk
    Help: 142
    Rate: 145
    staszeks
    If you want to be exact, you would have to consider the frictional force and the viscous force and maybe a few others. But let's not go to extremes. I think that the author has already received the answer to his doubts and there is no need to pursue the topic further.
    I greet everyone
    jjanek
  • #12 3968923
    BolzZ
    Help: 56
    Rate: 67
    you guys have something else wrong, or rather you have forgotten something - about thinking ;) read this topic from the beginning to be sure :D
    and a kilogram is just a thousand grams, "gram" with the prefix "kilo".
  • #13 3971172
    Soohy_tm
    Buddy qrdel ... you impressed me :D
    Paul Es .:
    Disregarding air resistance, possibly considering two balls - one with air and the other with lead :) with the same sizes:
    gravity is the same, air resistance is the same, so according to I will fall equally ...
    As for qrdel's statement: A good example, if we consider it correctly, we will come to the conclusion that in the end the bodies will not fall, but float :D
    czucz:
    Has a colleague checked it? :) because something seems to me that they will fall together after all. Such an example is given in schools (I have heard myself), but certainly not by physics teachers :) Don't you think there's not enough data to judge it? Oh, and that washes it in the pillow or what? :)
    I talked to a friend who is very good at this topic. Below is his statement:
    ... and this comes from the fact that:
    F = G * m1 * m2 / r ^ 2
    a = F / m1
    that is, m1 shortens
    m1 - mass of the object
    m2 - the mass of the land
    r- distance from the center of the earth
    G - the constant of gravity
    a - acceleration
    and so
    a = G * m2 / r ^ 2
    r ^ 2 - this is obviously r to the power of 2
The discussion centers around the misconception that body weight affects the speed and time of free fall. Participants clarify that in a vacuum, where air resistance is absent, all objects fall at the same rate regardless of mass, as described by the formula V = g * t. The impact of air resistance is acknowledged, indicating that weight does influence falling speed in non-vacuum conditions. The behavior of balloons filled with different gases (CO2 and hydrogen) is explained through buoyancy principles, where CO2 is denser than air, causing it to fall, while hydrogen, being lighter, rises. The conversation emphasizes the importance of ideal conditions for free fall and the role of forces acting on falling bodies.
