Keyboard issue: lowercase l not typing, only works as uppercase with Shift – Suzuki Swift
MR.PB 28100 3
  • #1 3999403
    MR.PB
    I have a problem with my keyboard. It's about the letter l. When I want to write it with alt it doesn't work. Only in combination with Swift does it get the expected letter, but of course a capital one. I write other letters without any problems. How to solve this problem?
    "SWIFT" is such a car model. Suzuki, by the way...
  • #3 3999465
    MarekPPN
    Help: 245
    Rate: 154
    User statement Kolobos
    A: The shortcut (hotkay) he reserves is responsible for this state of affairs
    download the Intel graphics card driver to solve the problem
    you should follow the advice described below (there are two to choose from):
    1) disable the hotkey function in the driver settings
    graphic card 845G-"Graphics Properties | Hot Keys | Disable". Shortcuts
    Keyboards are enabled by default.
    2) alternatively, on the above-mentioned website there is a "launch" to the register available, which
    must be uploaded. It allows you to use shortcut functions simultaneously
    keyboards of the graphics driver, as well as the Polish language
    ftp://download.intel.com/support/graphics/fix-polish.reg
  • #4 3999470
    DJKompot
    Help: 40
    Rate: 30
    I think it's enough to go to the language bar ---> Settings ---> Everything is written there :D You still have language settings.
    Regards
