Mix of Copper and Old Aluminum Wiring in Flat—What Are My Options as New Owner?
polcia 43069 17
What should I do if I discover hidden old aluminium wiring joined to new copper wiring in my flat?
You should have the installation checked by an electrician and plan to replace the aluminium part, ideally the whole flat wiring if possible; at minimum, replace the heavily loaded circuits and inspect bathrooms, wet areas, and all socket grounding/zeroing arrangements [#4143302][#21368494] Do not leave a direct copper-to-aluminium junction in a concealed box unless it is made with proper Al-Cu adapters/spacers, because those mixed joints can lose contact and overheat with time [#4257960][#4254296][#4254361] If you cannot replace everything right away, some users recommend leaving healthy thick aluminium conductors in place for now and replacing them during a major renovation [#4246694][#4246611] Also check what the connecting cube/terminal is made of: brass (yellow, copper-containing) is a bad match for aluminium, while nickel-plated terminals are preferable [#4258220] In older block flats, the riser wiring may still be aluminium anyway, so replacing only the apartment wiring is often the practical part you can control [#4246611][#21368494]
  • #1 4142989
    polcia
    Rate: 11
    I have a problem with the electrical installation in my flat. Well, when I tried to replace the sockets, it turned out that the cables sticking out in the box are replaced (copper), while outside the box in the wall are old aluminium cables, connected by a cube. At first glance the old cables are invisible. In my opinion, the first owner of the flat replaced a piece of cable just to deceive the buyer about the replacement of the electrical installation. Has anyone encountered this situation? Please advise me what to do now, I am the third owner of the flat.
  • #2 4143302
    Bogdanor
    Help: 78
    Rate: 32
    You are absolutely right. You have to replace the entire installation (at least the part that is made of aluminum, and looking at what the previous owner did, it will probably be the whole thing). aluminum oxidizes very quickly. First of all, if you can't do the whole thing right away, do at least the part where the sockets will be most loaded, and pay attention to how the installation looks like, e.g. in the bathroom and other wet places, see also if the sockets are zeroed or grounded (is there a bridge to the pin) from the zero wire or also goes to the pin, a separate wire)
  • #3 4143534
    polcia
    Rate: 11
    thanks for the advice, I'll check the cubes and connections. I would like to "pursue" this previous owner for fraud, but he only verbally informed me about the replacement of the installation, I do not have it in writing. Do I have any chances for, for example, a reimbursement of the installation replacement costs, maybe someone had a similar situation, please contact me.
  • #4 4243725
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    And what are you able to prove to him? If nothing, you will get something only if his conscience moves him ...
  • #5 4244425
    lechm56
    Help: 112
    Rate: 368
    Moved from Other.
  • #6 4246574
    Popak
    Moderator on vacation ...
    Help: 97
    Rate: 270
    I do not know what the situation was, but I also encountered a situation that the owner had broken ends of the aluminum wires and replaced the part with a copper one (as the author describes)
    Regards
  • #7 4246611
    Jack14
    Help: 320
    Rate: 175
    I will join:
    I also had such a situation and I consider what my colleague above recommends "ripping" the entire installation redundant.
    I left all the sockets on the aluminum except for the washing machine and dishwasher, and I live to this day.
    ps
    moreover, like most people living in blocks built during the communist era ("skyscrapers" made of large slabs)
    Replacing the installation in the whole apartment will not help at all because the electrical installations in the risers remain aluminum anyway.
    (Unless it's a new free-standing house)
    Regards
  • #8 4246694
    ekwador
    Rate: 8
    polcia wrote:
    I have a problem with the electrical installation in my apartment, so when trying to replace the sockets, it turned out that the cables protruding in the box are replaced (copper), while outside the box in the wall there are old aluminum cables, connected with an ankle. old cables are invisible at first glance. In my opinion, the first owner of the apartment replaced a piece of cable only to deceive the buyer about replacing the electrical system. has anyone encountered such a situation? I am asking for advice what to do now, I am the third owner of the apartment.
    If the aluminum conductors are "healthy" (they are not oxidized, the insulation is not damaged by temperature, they do not break) then I would leave it. There is no point in replacing it, unless you carry out a major renovation, then replace it as much as possible.
    I am often surprised by people who install tiles in, for example, bathrooms and leave old aluminum wires :| Sometimes the walls are so crooked that you don't need to hammer anything because the wires will hide under the leveling mortar.
  • #9 4247101
    _jta_
    Help: 3212
    Rate: 4258
    Thick aluminum conductors when properly bonded (so that they do not come into contact with anything containing copper
    - because even traces of copper corrode aluminum), they are not a problem; prone to damage are thin, and with
    in contact with copper. I have already burned a few sockets - aluminum corrosion, resistance increases -> smoke from burning insulation.
    Unfortunately, it is not easy to replace it: the wires are not in tubes, but embedded in them - you would have to hammer the wall to put new ones.
  • #10 4252103
    ekwador
    Rate: 8
    Think about what you wrote ...
    Aluminum must not corrode :!: Because it immediately becomes covered with an oxide layer, which protects the metal against corrosion :!:
    Another nonsense is that Al will corrode on contact with Cu :!:
    And your sockets burned because you joined two metals of different hardness. Al deformed and the contact loosened, causing excessive heating.
  • #11 4252950
    _jta_
    Help: 3212
    Rate: 4258
    Certain metals - I know about copper, mercury, and gallium - render corrosion protection ineffective
    an oxide layer covering aluminum (they taught about copper at school, about gallium in Tołłoczka's book
    - it has a great effect, aluminum reacts with water as vigorously as sodium, mercury also has nice effects).
    For this reason, special Kupal spacers are used to connect aluminum with copper.
  • #12 4254296
    ekwador
    Rate: 8
    Such spacers are used outside (overhead lines) where Al and Cu are exposed to water. In the absence of a washer on the connection of these metals, a kind of a link is created and the contact loses its parameters.
  • #13 4254361
    atlantel
    Automation specialist
    Help: 170
    Rate: 256
    Hello!
    My friend, Ecuador, also in closed rooms, aluminum cannot be directly joined with copper, and every electrician knows about it.
    Regards
  • #14 4254397
    ekwador
    Rate: 8
    Every electrician knows, and I've seen such flowers that my hands drop :| .
  • #15 4254414
    CISU
    Cramp, normally a man learns all his life :-) Honestly, it would not even occur to me to make such makeshift aluminum and copper.
    How to replace it all :-) well, although it is not always possible :-)
    But an interesting post :-) I will have this in mind when buying a flat :-)
  • #16 4257960
    marcino2000
    Help: 34
    Rate: 167
    I heard about such cases that an electrician came to replace the installation, took kasiore for material, sculpted everything in the way described here and disappeared.
    As for Al-Cu joints, this should not be done because electrolytic corrosion occurs, enough air humidity to damage the joint after a short time.
    So if I was the owner of such an aluminum-copper sculpture (and also connected at the ankles, in places not intended for it), I would definitely replace it as soon as possible. You probably know your friends, this textbook example about a washing machine, a broken eNie and a woman how the phase hits the casing ??
  • #17 4258220
    _jta_
    Help: 3212
    Rate: 4258
    I would suggest checking what these cubes are made of: is that piece of metal that connects them,
    and with which the wires are in contact, is it bare brass (contains copper) or is it nickel-plated?
    The difference is easy to see: brass is yellow, nickel white. And from brass, aluminum corrodes ...
  • Require landlord acknowledgment before patching old aluminum wiring
    #18 21368494
    nostromo
    Rate: 23
    >>4246611 In many old blocks of flats, the old wiring in the riser (aluminium with cotton insulation) is replaced by the administration with new cables with normal earthing. The flat owner has to replace the installation in the flat at his own expense. Combining aluminium with copper is not a very good idea (special adapters are available). If the landlord does not want to replace the installation, but only to "patch it up", I require him to sign a statement that he has been informed of the consequences of not replacing the old two-wire installation (aluminium with cotton braid) with a new three-wire copper installation. Obviously, only in cases where a new installation is pulled in the cages in the riser.
The discussion addresses the issue of mixed copper and old aluminum wiring in a flat, where aluminum cables are hidden in the walls and connected to copper wiring via junction cubes. Aluminum wiring oxidizes quickly and can cause safety hazards, especially if connections with copper are improperly made, leading to corrosion and increased resistance that may cause overheating or socket damage. Proper connection requires special spacers or adapters (e.g., Kupal spacers) to prevent electrolytic corrosion between aluminum and copper. Complete replacement of aluminum wiring is recommended, particularly in heavily loaded circuits and wet areas, but partial retention of aluminum wiring is sometimes practiced if the conductors are in good condition and not oxidized. Replacement can be difficult due to wiring embedded in walls. Legal recourse against previous owners for undisclosed wiring conditions is limited without written proof. In older buildings, aluminum wiring in risers often remains, and flat owners must replace internal wiring at their own expense. Verification of junction cube materials (brass or nickel-plated) is advised, as brass accelerates aluminum corrosion. Overall, the consensus favors replacing aluminum wiring or ensuring proper connections with copper using appropriate materials to maintain safety and reliability.
