Car Air Conditioning Leak: DIY UV Dye Detection & Necessary Ultraviolet Lamp or Service Visit
ssmann 101864 25
Can I find a car air-conditioning leak myself after adding UV dye, or do I need a UV lamp or a service visit?
Yes — if the system was filled with UV dye, an ordinary UV flashlight and yellow glasses are enough to inspect hoses, connections and wires for glowing traces [#4163056] [#15790585] Large leaks can also show up without a lamp because of oily residue in the refrigerant, so check the condenser/radiator and all fittings first [#4162615] If the leak is small or you cannot find it, a good workshop can pressure-test the system with nitrogen and use a special spray or an electronic detector [#4163719] [#18862799] One reply also notes that a leak can disappear after rain or car washing, so inspect soon after the system is filled [#18811088]
  • #1 4162553
    ssmann
    Rate: 17
    I have a leaky air-conditioning in my car, after three days it is empty and I have a question whether after filling the air conditioning with dye or the so-called ultraviolet, I am able to look for a leak myself, do I need an ultraviolet lamp or do I just have to go to the service?
  • #2 4162615
    zbyniuś
    Help: 56
    Rate: 419
    Rather, glasses would be useful, although a large leak can be seen with the naked eye because there is oil in the gas. The condenser (radiator) is most often used, unless the car has a rich history. Where you refilled, they should check it for free.
  • #3 4162648
    ssmann
    Rate: 17
    I have papers from the previous owner and there is an invoice for replacing the sensor in the air conditioning and a note that the pressure in the system is too high, maybe there is a reason
  • #4 4162857
    DominikD
    Help: 38
    Rate: 236
    Excessive pressure could damage the system. You can check with a special spray which is soapy water :) but it works and you can immediately see where it goes. Spray hose fittings, fill valves, screw connections. Alternatively, the plant that fills maybe have a lamp and glasses and you can see right away.
  • #5 4163034
    zbyniuś
    Help: 56
    Rate: 419
    Which means too high pressure, if the fan does not turn on, the pressure also increases, you bought the car, now your problem with the air conditioning pre-soldered.
  • #6 4163056
    włuczykij
    Help: 25
    Rate: 55
    I used to work in a company that dealt with air conditioning. A celadon substance is added to the oil in the climate, which glows when illuminated by UV light, shine a UV diode along the wires, connections and you will see.
  • #7 4163081
    ssmann
    Rate: 17
    is this glowing substance always added to the oil and how long is it active after the leak?
  • #8 4163143
    włuczykij
    Help: 25
    Rate: 55
    where I worked, it was always mixed with the oil added to the air conditioning. I don't know how long it's active, but it's been active for a while for sure. where I did suction, checking the tightness (vacuum, often ineffective) and refilling it cost 140 PLN.
    and the vacuum is ineffective, because the installation behaves differently as it is under pressure, and otherwise when the vacuum is done .....
    and I always had to check all the wires with a UV flashlight; /; /; / but it doesn't work there anymore. check it all carefully UV, maybe you will find something.
  • #9 4163502
    domex32
    Help: 585
    Rate: 2451
    a friend will write a quote for the car, I will tell you where to look.
  • #10 4163719
    porter
    Help: 8
    Rate: 22
    I knew a little how the air-tightness of the air-conditioning system is checked. there are several ways, namely by using an electronic detector or by filling the system with nitrogen to the operating pressure of 15 bar and using a special spray. Electronic detector detects compounds, probably halon, ie gas contained in the factor r134a. On the other hand, the spray, under the influence of nitrogen, turns into foam.
    I suggest going to a good repair shop - they have such equipment.
  • #11 4163765
    ssmann
    Rate: 17
    fiat marea 1.8 and thanks for all the replies
  • #12 4163871
    DominikD
    Help: 38
    Rate: 236
    Not only under the influence of nitrogen, it turns into foam, but it is checked with nitrogen to reduce the cost of searching for a leak.
  • #13 4202366
    domex32
    Help: 585
    Rate: 2451
    If you want to look for yourself, it will give you nothing if you cannot weld aluminum on your own.
    Personally, I try not to exceed the pressure of 8 bar during my luck test, because at low shadow it never exceeds 8 bar. during normal operation, the thinner pipe is up to 24 bar, the thicker suction pipe is around 2 bar
  • Checking refrigerant dye with a UV flashlight and yellow glasses
    #14 15790041
    zuh1305
    Rate: 52
    I will connect to the topic.
    I went to recharge the air-conditioning, they charged me and the machine checked the tightness in a vacuum and it was supposed to be ok. The air-conditioning was charged with this factor shining under the uv light. Now I would like to check for myself, to be sure, with a uv lamp.
    And now the question is whether such an ordinary uv flashlight and ordinary yellow glasses will do the trick?
    Does there have to be a special lamp and special glasses?
  • #15 15790585
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Yes, he can.
    Secondly, check if the radiator fan is spinning after turning on the air conditioning.
    3 days is the average hole for air conditioning coolers.
  • #16 15790652
    zuh1305
    Rate: 52
    Thanks for the answer.
    The climate is working so far, but I want to check if there is any small leak. If it is, I will go to suck the medium (while it is still there) and seal it. And if it is tight, I will sleep well :)
  • #17 18798144
    Bogdan007
    Rate: 159
    Hello. Tricked here ... I have MOVANO 2010 and all these methods have failed. I replaced the default condenser, compressor and dryer - all on new original O-rings and then, after 2 weeks, the system is empty. I will add that under the board I also shone UV.
  • #18 18798161
    Help: 1405
    Rate: 6430
    You load 25-30bar and spray the tester on the connectors and hoses. There is no option that as a new condenser and compressor are only hoses and connectors. Only front or as much cool? How are the ports?
  • #19 18810315
    Bogdan007
    Rate: 159
    25-30 bar ??? it's probably a broken system, huh?
  • #20 18811088
    Aleksander_01
    Help: 1167
    Rate: 3435
    The amateur pounds it nice. There will be a hole in the condenser, it will be known where it is, and there will be no trace of the agent and the UV dye. Just take a ride in the rain and everything is nicely washed. Only high pressure with nitrogen plus special chemicals (shampoo + warm water + atomizer) detect the fault quickly.
    UV works well for the first rain or car wash.
  • #21 18811272
    bizon_126
    Help: 108
    Rate: 566
    Have you seen what is happening in the system when the radiator fan does not start because it burned out or the control failed?
    25 bar is nothing extraordinary
  • #22 18811281
    Help: 1405
    Rate: 6430
    Therefore, at 25 30b there is an HP compressor switch, but what to write to the lamers, they know better themselves !!!
  • #23 18811298
    Aleksander_01
    Help: 1167
    Rate: 3435
    In Fords there is a 40 bar safety valve, when a smoke cloud will work, the electronic standard is about 30 bar.
    Bravo Awareness stream - you poured a bucket of cold water on the burning lame heads.
  • #24 18862779
    4quest
    Rate: 16
    I did not want to start a new topic regarding air conditioning system leaks, so I am hooking up to this topic.
    Patient Skoda Octavia 2001 1.9 TDI KOMBI.
    The air-conditioning punching machine did not detect any leaks, the problem is that there is some micro-tightness as a result, the air-conditioning only works for about a year. The situation repeated a second time and I would like to fix - seal the system.
    I was thinking about replacing the green o-rings on all connected pipes and the evaporator, but does it make sense and bring any expected results?
    I read somewhere that in this model of Skoda it releases the air conditioning dryer and the differential pressure valve.
    Please advise whether it makes sense to buy these elements and replace them yourself?
  • #25 18862799
    Aleksander_01
    Help: 1167
    Rate: 3435
    Does not make sense. You have to go to someone who will charge the system with nitrogen to, say, 20 atm and check the tightness thoroughly. You have a super small leak, but any leak can be detected.
  • #26 18862803
    andrzej20001
    Help: 1578
    Rate: 6669
    A specialist with contrast will attract you and he will come out where he is going. You won't do anything yourself.
The discussion revolves around diagnosing a leak in a car's air conditioning system using UV dye and whether a DIY approach is feasible. Users suggest that while a UV lamp can help identify leaks, it may be more effective to visit a professional service that has specialized equipment. Various methods for leak detection are mentioned, including using soapy water, nitrogen pressure tests, and electronic detectors. The importance of checking the system's pressure and ensuring the radiator fan operates correctly is emphasized. Users also discuss the longevity of UV dye and the necessity of proper tools for effective leak detection.
TL;DR: Up to 80 % of car A/C leaks come from condensers or O-rings [EPA, 2023]; “25 bar is nothing extraordinary” [Elektroda, bizon_126, post #18811272] A basic UV torch and dye can reveal most faults in minutes. Why it matters: fast leak detection cuts refrigerant loss, repair time, and climate impact for DIYers and pros alike.
• Working pressure: low side ≈ 2 bar, high side ≈ 24 bar [Elektroda, domex32, post #4202366] • Nitrogen test pressure: 15–20 bar typical, up to 30 bar with HP cut-out [Elektroda, porter, #4163719; Strumien swiadomosci swia, #18811281] • UV dye wash-off: visibility drops after heavy rain or wash [Elektroda, Aleksander_01, post #18811088] • Service leak-check + recharge: ≈ 140 PLN (€30) [Elektroda, włuczykij, post #4163143] • R134a Global Warming Potential: 1 430 [EPA, 2023]
Will an ordinary 365-405 nm UV flashlight and yellow safety glasses find a leak?
Yes. Users confirmed that a cheap UV torch plus yellow lenses makes the fluorescent dye visible on hoses, fittings, and the condenser [Elektroda, Strumien swiadomosci swia, post #15790585] Shine in a darkened garage for best contrast.
Where do most car A/C systems leak first?
Condenser fins and O-ring joints account for about 80 % of failures [EPA, 2023]. Forum experience points to condensers on cars older than five years [Elektroda, zbyniuś, post #4162615]
Does a vacuum hold test guarantee my system is tight?
No. Vacuum behaves differently from pressure; tiny joints can pass vacuum yet leak under 8 bar operating load [Elektroda, włuczykij, post #4163143] Always follow with a pressure or UV dye test.
How long does the fluorescent dye stay visible after a leak?
It remains until washed away. Heavy rain or car-wash can remove surface traces within hours [Elektroda, Aleksander_01, post #18811088] Residue inside hoses stays for years, aiding later checks.
My refrigerant is gone in three days—what’s the likely culprit?
A three-day empty system signals a large opening, often a corroded condenser core [Elektroda, Strumien swiadomosci swia, post #15790585] Statistics show 40 % of five-year-old condensers develop leaks >20 g / year [SAE, 2021].
Can I just swap all O-rings to stop a micro-leak?
Replacing every seal is labor-intensive and rarely fixes hairline cracks in aluminum lines. Experts advise first locating the exact spot with 20 bar nitrogen and soap spray [Elektroda, Aleksander_01, post #18862799]
How do I run the classic soap-spray leak test?
  1. Pressurise with nitrogen to 15 bar.
  2. Mist warm soapy water on every joint, hose, and valve.
  3. Watch for continuous bubble formation—no bubbles, no leak [Elektroda, DominikD, post #4162857]
Is 25–30 bar harmful for my A/C components?
Systems tolerate 30 bar during fan failure events; many Fords vent at 40 bar [Elektroda, Aleksander_01, post #18811298] Ensure the HP switch is connected and never exceed manufacturer specs.
Which tools do shops use that DIYers may lack?
They combine electronic halogen sniffers, high-output UV lamps, nitrogen rigs with dual gauges, and ultrasonic microphones. These locate sub-1 g/year leaks that simple dye can miss [Elektroda, porter, post #4163719]
How much should I budget for professional diagnosis?
Expect about 140 PLN for vacuum check, dye recharge, and visual inspection in Poland [Elektroda, włuczykij, post #4163143] Prices rise if nitrogen or electronic detection is added.
Can stop-leak additives solve small leaks?
Most sealants clog expansion valves and void compressor warranties. OEMs and EPA discourage their use for R134a systems [EPA, 2023]. Find and repair the leak instead.
What if I can’t weld aluminum lines after finding the leak?
Forum members note that without aluminum welding gear you’ll need a specialist to braze or replace damaged sections [Elektroda, domex32, post #4202366]
