Bosch Silence Dishwasher Not Filling with Water After Dish Soap Use
troja 65895 5
  • #1 4532443
    troja
    The Bosch Silence dishwasher does not fill with water.
    The problems started after pouring dishwashing liquid into it (yes, I know you are stupid).
    Could this be the cause of the failure?
    I will add that when you turn on the dishwasher, you can hear a hum (as if the pump is working, but it does not consume water)
  • #2 4532485
    Whirpool_Fcuker
    Help: 17
    Rate: 108
    pour a few liters of water inside and fire ... you won't hurt 100%.
  • #3 4532679
    bronek1806
    Help: 65
    Rate: 220
    Hi!
    the dishwashing liquid created a large amount of foam which poured through the door and activated the anti-spill system (aquastop), you must dry the bottom of the dishwasher or wait for it to dry by itself (a few days).
  • #4 4532692
    colcolcol
    Home appliances specialist
    Help: 100
    Rate: 341
    Unfortunately, it will not dry up so quickly, if the aquastop hose at the solenoid valve is "flooded", it should first of all be detached from the solenoid valve (it is neutral from which side) and even sometimes create a small vacuum on this aquastop (draw air :) ). If the liquid was poured into the dishwasher in a large amount, cleaning may take 20-30 washing cycles, non-stop foam control
  • #5 4543749
    wojcik wladyslaw
    Rate: 11
    you have to do as the predecessor writes, use dishwashing liquid for water when washing manually for dishwashers absolutely not allowed - best regards
  • #6 4544055
