What's the difference between digital coaxial and analog RCA (chinch)?
Rekmos 63471 15
What is the difference between a digital coaxial cable and an analog RCA (cinch) audio cable, and can I use an RCA cable instead of a digital coaxial cable?
The main difference is that digital coaxial (SPDIF) is meant to be a 75-ohm transmission line, while a regular RCA/audio cable is not guaranteed to have that impedance or the same electrical properties. [#4571898][#4575243][#4579925] A decent RCA-to-RCA audio cable can often work for a short run, and several users reported that a normal cable worked without problems. [#4571457][#4574243][#4582691] The risk is with cheap or poorly made cables, which can cause dropouts or intermittent sound, so they are not the best choice for digital audio. [#4571898][#4575243][#12508997] If you want the safest option, use a proper 75-ohm digital coax cable; one reply also suggested BNC as a better impedance match than RCA. [#4572327][#4579925]
  • #1 4570547
    Rekmos
    Rate: 11
    What's the difference between digital coaxial and analog chinch?
  • #2 4570576
    PAWEŁ74
    Help: 78
    Rate: 119
    You can expand the question because it is like "what is the difference between WHITE and BLACK" after all, the names themselves indicate the difference ... "digital" and "analog"
  • #3 4570681
    Rekmos
    Rate: 11
    I know the purpose of the chinche and coaxial cables. I am intrigued by the difference in the construction of these cables, because at first glance they look the same. Is it possible to connect a chinche cable instead of a coaxial because it is cheaper?
  • #4 4571457
    PAWEŁ74
    Help: 78
    Rate: 119
    You can, as long as you don't buy the cheapest "crap" ...
  • #5 4571898
    Pablo1964
    Moderator
    Help: 507
    Rate: 641
    You can, just like drive a car on "baptized" fuel. You can also omit the mains plug by inserting 2 wires directly into the socket. It will be worse and in a mess, but not everyone knows the difference. If you want to save on the cable in this way, better buy cheaper equipment.
    Coming back to the question from the first post - they differ mainly in impedance. The coaxial cable is exactly 75 ohms.
  • #6 4572327
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    But RCA doesn't have 75 ?, at least usually, so I wouldn't exaggerate if the cable impedance is really that important. I'm not saying it's irrelevant, but if we care about impedance compliance, let's take care of the whole thing. Therefore, I suggest replacing the chinch with the BNC, which fit better when it comes to impedances, but you need to check if it is 75? or 50?, because they are also like that.
  • #7 4574243
    PAWEŁ74
    Help: 78
    Rate: 119
    Taking this approach, it is better not to buy equipment below PLN 100,000 ... I connected the coaxial with a normal "audio" cinch-cinch cable (1m cable for PLN 35), everything was normal, and Nobel Prize to anyone who would hear the difference after connecting the allegedly special cable to the COAXIAL ...
    He writes about a normal cable, not a wire with electrical properties equal to a "wet shoelace" ...
  • #8 4575243
    Pablo1964
    Moderator
    Help: 507
    Rate: 641
    Coaxial cables have better electrical properties than regular audio cables. The best audio cables are similar to cheaper coaxial cables and have similar properties. However, not all audio cables are shielded and if someone unfamiliar with electronics asks if it is the same and you answer yes - he will buy the cheapest crap (because he asks to save money) and he will surely hear the difference. That is why I believe that we should also be precise in answering laymen.
  • #9 4576010
    PAWEŁ74
    Help: 78
    Rate: 119
    Quoting my first post ... It clearly says it's not the cheapest cable. Not all cables are shielded? I have never seen a cinch-cinch cable unshielded though the slightest degree, unless you mean speaker cables ... which requires no comment ...
  • #10 4579842
    ghost666
    Translator, editor
    Help: 157
    Rate: 10267
    PAWEŁ74 wrote:
    And I've seen a lot of unshielded cables. Not every rca-rca is shielded, not every coaxial is shielded as well (it's quite twisted, but the braid does not always shield - it depends on how to connect it).
  • #11 4579925
    djlj24
    Car audio specialist
    Help: 1104
    Rate: 1327
    Flatline cables, which were quite expensive at the time, were not shielded at all. Likewise, Kimbler Cable makes a braided line, not a shielded cable. Few people remember that the screen has one negative property - it increases the capacity of the cable. In the case of digital signal transmission cables (SPDIF) it matters - here you have to look at the matching and wave impedance of 75 Ohm.
  • #12 4582501
    chaka
    Help: 134
    Rate: 100
    The difference is that when I have a DVB decoder connected to the receiver with a good quality chinch audio cable, some channels catch their voice only after the 3rd attempt to switch. No problem with a dedicated digital cable.
  • #13 4582691
    PAWEŁ74
    Help: 78
    Rate: 119
    Then tell me, was I lucky it played ...?
    I have SPDIF pulled out on 2 wires from the sound card, the usual two lines. At the end of the cable there is a soldered cinch socket, then a normal cinch-cinch cable to the decoder ... and everything works without any problems.
  • #14 4592718
    chaka
    Help: 134
    Rate: 100
    And stereo or 5.1? :)
  • #15 4595993
    PAWEŁ74
    Help: 78
    Rate: 119
    And so and so. When I play a movie encoded in AC3, for example, in the card parameters I redirect to "SPDIF only", the "DOLBY DIGITAL" diode lights up in the decoder and the sound is 5 + 1. all I need to do is pause it immediately the "DOLBY DIGITAL" signal goes out. So I have no doubts that the signal is decoded correctly, and you can hear it perfectly in movies with a lot of sound effects ...
    The same applies to DVD playback.
    So I don't understand the ironic :D at the end of your speech.
  • #16 12508997
    jacek3
    I had a TV connected to the receiver via a regular chinch. The receiver reacted with a momentary lack of sound to each switching on, no matter what device in the apartment (even opening the refrigerator door). After replacing the chinch with a digital one, the problem is over, so the type of cable matters.
The discussion centers on the differences between digital coaxial and analog RCA (chinche) cables. Key distinctions include their construction and impedance, with coaxial cables typically having a 75-ohm impedance, which is crucial for digital signal transmission. While some participants suggest that RCA cables can be used in place of coaxial cables, they caution against using low-quality options, as this can lead to performance issues. The conversation also touches on the importance of shielding in cables, with some noting that not all RCA cables are shielded, which can affect audio quality. Users share personal experiences, indicating that using dedicated digital cables can resolve issues like intermittent sound loss, while others report satisfactory performance with standard RCA cables in specific setups.
