What kind of RCA signal cable should I use for a short run in a noisy DJ console: a microphone cable with one shield or a double-shielded instrument cable?
Use a flexible cable with one good shield; for RCA there is no need for two inner conductors or double shielding, and a decent cable around PLN 4–6/m will be good enough [#16314174][#16313208] If shielding is important, an instrumental/guitar cable is a good choice because it usually has the best screen, but the main requirement is that it fits the plug and is durable [#16314371][#16314174] Connect the shield to ground only on the receiver side to help avoid ground loops, not in a way that creates an extra potential [#16313208] Don’t expect an audible difference between the two cable variants; the forum advice was that you likely won’t hear it [#16314152] Focus more on solid plug construction and strain relief than on gold plating, because the plug’s mechanical quality matters more than the finish [#16314440][#16314851]
  • #1 16313104
    Helec
    Rate: 11
    planning to make short RCA signal cables for a DJ console.
    I have little space in the case, so the power cables run close to the signal ones, in addition I have 110V players and there is also a converter in the case.
    Therefore, it needs cables with the best possible shielding - length 0.7 and 0.5 m. They can be single, or double.
    I am thinking of two wires, the Bitner LP0209 microphone.
    Technical data:
    Number of cores / pairs: 2/1
    Insulation: PE
    Insulation color: red, natural
    Coating: Modified Tire Plastic
    Shell color: matt black
    Conductors: multi-wire copper, class 6 according to PN-EN 60228
    Cross-section of working conductors: 30 AWG copper strand 0.35mm2 / 20x0.15 +- 0.004
    Working conductors resistance: 50? / km; + 20 ° C
    Screen resistance: 15? / km; + 20 ° C
    Core-core capacity: 63pF / m; 1kHz
    Effective conductor-screen capacity: 105pF / m; 1kHz
    Wire Diameter: 6.5mm ~ 6.6mm
    Screen: 160 mesh braid 0.1mm2 wires (95% ... 100%)
    Puncture resistance:> 1kV / 50Hz
    Temperature range: -30 ° C ~ + 70 ° C
    Resistance to: abrasion, animal and vegetable fats, ozone, alcohol, sea water, weak acids and bases and UV
    Weight: 55 kg / km
    Minimum bending radius:> 20mm
    Compliance and standards: ISO 9001 2000; ROHS 2002/95 / EC
    / wire-microphone-cable-2x0-35mm-bitner
    I would use it in such a way that the red wire is plus the signal, the white wire is ground, and the screen on one side is connected to ground.
    Second cable:
    no data, not found anywhere,
    instrumental-cable-ins101-double-shielded
    I would give the signal through the signal wire, ground with the first shield and the outer shield to ground.
    1 cable has any technical specifications, quite good.
    The second one has nothing to do but has double shielding, which can give a better effect in such an electromagnetic brothel.
    What do you think about it?
    Moderated By adambyw:
    3.1.18. Do not send links that will cease to be active after some time. This will make the discussion meaningless.
    adambyw
    Moderator of Acoustics
    Help: 1120
    Rate: 829
    Not to ground, but from the signal receiver side also to ground.
    Note that not all devices are grounded at the same potential as ground. Sometimes it is not connected at all, sometimes only through a capacitor or RCD bridge. This prevents disturbance of the ground loop.
    However, such a solution is a good idea.
    That you are slowly making voodo audio. A decent cable around PLN 4-6 / m with a single shield will give good enough results.
  • #3 16313402
    Helec
    Rate: 11
    I think connecting the screen to ground is better than connecting it to ground because the muck does not enter the mass, but the ground - directly to the pin.
    This is what I have been able to deduce from many contradictory sources and a small dose of logic.
    adambyw
    Help: 1120
    Rate: 829
    RCA plug has 2 connectors. How do you want to pull up the second shield to ground (third potential)?
  • #5 16314121
    Helec
    Rate: 11
    Not aesthetically pleasing - lead the cable from the screen so that the screen does not short-circuit the ground of the plug and lead the cable to the ground: v
    Such a plan came to my mind, I do not know how justified it is, I read that if it is possible to ground it better than to ground it, but I do not know how much truth in it :D
    Which cable will be better? The one with 2 wires or the one with 2 screens?
    adambyw
    Help: 1120
    Rate: 829
    For my taste, you won't hear the difference.
    398216 Usunięty
    Help: 3925
    Rate: 9371
    The cable should be flexible and durable. With RCA, there is no need for two wires; one in a good screen is enough. All the rest of the little things you have to decide on your own - depending on the type of plug, for example; you have to choose the outer diameter of the cable - that it can be soldered and that it fits in the opening for the cable exit from the plug.
  • #8 16314205
    Helec
    Rate: 11
    And I will also ask about plugs - it is better to use only soldered or screw clamped on a wire and additionally solder it? It seems logically that then the connection resistance will be the lowest. I guess it's better gold-plated because they will oxidize less?
    I found one more from RedMusic with specifications:
    http://redsmusic.pl/kabel-instrumentalny-stronger/
    Building:
    Conductors: a flexible copper strand of class 5 according to PN-EN 60228 (16 × 0.20mm construction);
    Three-layer insulation:
    1st layer: a special semi-conductive PVC blend - black
    2nd layer: foamed PE plastic - white color
    3rd layer: special semi-conductive PVC blend - black color;
    Screen: braid made of copper strands (160 x 0.1mm construction)
    Outer sheath: special modified PVC blend
    Coating color: matte black, UV resistant
    Outer diameter: 7mm
    Cables on a reel Cable length on a reel: 50/100/200/300/500 m
    Technical data:
    Working temperature:
    Fixed installation: -20 ° C to 70 ° C
    Minimum laying temperature: -
    5 ° C
    Insulation resistance: 1.0 G? x km
    Cable resistance:
    398216 Usunięty
    Help: 3925
    Rate: 9371
    Helec wrote:
    screw clamped on the wire and additionally solder it? ...... it seems that then the connection resistance will be the lowest.
    The lowest resistance will always be in the solder connection. If you have screws, you either screw or solder. Why do both? To make it harder to correct something if you make a mistake?
    Helec wrote:
    I found another one from RedMusic
    Another cable that is good but TOO GOOD for your application. I wrote - the most important thing is that it should be flexible and have a good screen. You're not going to drive a tank after that, or pull 100 meters of cable to connect the console to the mixer or something else?
    In practice, the cable should be just as long as needed - plus any spare for other equipment setup. A plug, whether it is "gold-plated" (because this coating has little in common with gold), chrome-plated or covered with some other metal - is only a matter of aesthetics and stretching lay people to unnecessary expenses. Not only that - I used to have to solder such a "gold-plated" RCA on a cable and what turned out? That the coating peels off Mrs. Jadzia's dirty claw like a bad varnish ...) ;) ).
    In my equipment I have several dozen cables of different types and with different plugs - I did not notice ANY difference in sound - one condition: the plugs and the cables must be durable and solidly made. And will you give gold-plated plugs and cables for PLN 100 for half a meter - it does not matter - apart from the awareness that you have loaded a lot of money into something that is not necessary.
    adambyw wrote:
    you are slowly doing voodo audio. A decent cable around PLN 4-6 / m with a single shield will give good enough results.
    Amen.
  • #10 16314315
    yogi009
    Help: 848
    Rate: 2650
    This is what it is like when you read about gold, unidirectional wires for hundreds of pounds ... Fortunately, the electrons do not know whether they are flowing through the gold plug or through the chrome one.
  • #11 16314324
    Helec
    Rate: 11
    If the cables are connected in the case, they will stay there for several years, so mainly the question of shielding remains. Braid + foil? Two braids? Or maybe some other type of shielding will be best for such applications?
    Now I have got the power cords, cut them to size and there are fewer of them, but when I do something more specific, I prefer to do it as best as I can.
    PS. I am not one of those who pay attention to gold in plugs, I just asked for your opinion: p
    What cables to own RCA wires What cables to own RCA wires
    nagrywamy.com
    Help: 188
    Rate: 108
    If shielding is important, then an instrumental or guitar cable is the best choice because it usually has the best shield. Semi-conductive material reduces microphonics, but this is unlikely to be a problem here. It only has to fit into the plug ;)
  • #13 16314386
    Helec
    Rate: 11
    Only that in this cable I would have to let go of the screen, because there is no other wire, that's probably a small flaw.
    yogi009
    Help: 848
    Rate: 2650
    Use the microphone cord and the subject off your head. It's a waste of time for doctorates.
  • #15 16314416
    Helec
    Rate: 11
    Looks like I will.
    Well, more plugs - invest in something better, will there be no difference between them and ordinary nickel or "gold-plated" ones:
    plug-rca-cinch-hi-end-reds-music-gold-rca - they look quite solid
    plug-cinch-rca-metal - cheap and a lot haha
    yogi009
    Help: 848
    Rate: 2650
    Pay attention to the solid construction of the plug itself and the certainty of the cable coming out of it. It would be good to have a plug with the so-called strain relief.
    nagrywamy.com
    Help: 188
    Rate: 108
    A very slight flaw. Opinions on the principle of operation and advantages of "directional" cables are at least divided ;)
    398216 Usunięty
    Help: 3925
    Rate: 9371
    THEY LOOK - and the appearance is the least important here. The design of the plug itself is important - and you will not see this outside.
    Cheap materials are used in cheap plugs - the thin plates that are to hold the wire when bent are too thin and it cannot be done well. Poor quality plastic insulating spacers melt during soldering, and melted plastic loosens the crimped contacts.
    But even the weakest quality plug, when it is well soldered (you have to know it, unfortunately ...) and earned, will fulfill its task better than even the most expensive one with a cosmic look and a price in dozens of zlotys. Remember that the influence of external interference is the more audible the smaller the signal you send via the cable - in your case the signals are large - at the level of volts, hundreds of millivolts, so even if something gets into the signal, you will not hear it, and even measure it. it is difficult, because the value of the voltage induced in the cable also depends on the internal resistance of the connected devices, which in this case is relatively small.
    You have read too much (often without going into the context or just nonsense) and without understanding the essential details you focus on what is the least important.
    yogi009
    Help: 848
    Rate: 2650
    For example. I had a jack from a reputable American company that gave a 25-year warranty on its components. Type as in the link:
    http://www.tme.eu/html/gfx/ramka_768.jpg
    It looked just like common in our electronics stores. However, I was not able to bend these contact plates with my fingers in any way. Just a solid job. Anyway, this manufacturer has just conquered the market with solidity, he made such contact elements that he has long-term contracts with the military.
✨ The discussion revolves around the selection of RCA cables for a DJ console setup, emphasizing the need for high-quality shielding due to proximity to power cables and 110V players. Users debate the merits of different cable constructions, including the use of single versus double shielding, and the importance of flexibility and durability. The Bitner LP0209 microphone cable is considered, with its specifications highlighting its suitability for audio applications. Participants also discuss the effectiveness of soldered versus screw-clamped plugs, with a consensus that soldered connections provide lower resistance. The conversation touches on the significance of shielding materials, with recommendations for using instrument or guitar cables for optimal performance. The importance of plug construction and strain relief is also noted, alongside skepticism regarding the benefits of gold-plated connectors.
