Open Office: Restoring Right Alt Functionality for Polish Characters
jacazwierz 53781 4
  • #1 4907823
    jacazwierz
    Rate: 14
    One of the ladies who supports Open Office asked so that you cannot write Polish characters - the right alt works like the left one - that is, it highlights the menu. Where to change it to return to its original form? I would like to add that, of course, Polish characters work in the notebook and other editors
  • #2 4907955
    xray81
    Help: 37
    Rate: 73
    Check if the language in the taskbar changes from Polish to English when you turn on Open Office.
  • #3 4908384
    xray81
    Help: 37
    Rate: 73
    Michal19881 wrote:
    Browse in the OO options.
    What advice is this in the Open Office options. Searching for nothing, as I wrote before, probably this lady, while using OO, changed the language on the taskbar to English and each time OO is turned on, the language automatically changes from Polish to English. Changing the language to English is manifested by the fact that you cannot write Polish characters - the right alt works like the left one - that is, it highlights the menu .
  • #4 4908516
    Michal19881
    User under supervision
    Help: 57
    Rate: 62
    Remove all languages except Polish from the language selection menu.
  • #5 7870315
    pyska222
    I also had a problem with it and I was overcharging. Only for me it was possible to switch Polish characters under; '[], / etc. The solution to this problem is Shift + ctrl and it works.
