Skoda Fabia Combi 1.4 16V 2003: User Manual & Clock Setting Process (No Knob Near Tachometer)
plablo69 93022 10
How do I set the clock on a 2003 Skoda Fabia Combi 1.4 16V if there is no separate knob near the tachometer?
Set the clock with the instrument-cluster button/knob: turn it to the right to change the minutes and to the left to change the hours [#5059341][#5059373] The same control is also used for resetting the daily mileage and for service-inspection reset functions [#5059373][#5062408] One reply also notes that you hold the button with the ignition off to bring up oil/service messages, then turn it clockwise to clear them [#5062408]
  • #1 5059041
    plablo69
    Rate: 21
    He is looking for a Skoda Fabia combi 1.4 16V 2003 user manual.
    How to set the clock in this car? In this model, what I have, there is no knob to set the clock near the tachometer .. :cry:
    ptaszek1975
    Level 30  
    Help: 121
    Rate: 444
    Try this to delete kilometers left in hours and right in minutes.
    luckylukas81
    Rate: 27
    You have to turn the knob to delete the daily mileage to the right, you set the min. and to the left of hours and it can also be used to cancel service inspections :D
  • #4 5061941
    plablo69
    Rate: 21
    I checked the works .... Then please expand the topic of deleting the service inspection. I am also green in this matter ....
    luckylukas81
    Rate: 27
    I do not know what set of indicators you have, but do so turn off the ignition, press this button and hold it on while holding this button, the ignition will show you oil or service (I don't remember anymore) then release the button and turn it clockwise (as you would like to set the minutes on the clock) then it should will be displayed ------- oil cleared then press it but only for a second will be displayed service turn right and it will show ---- cleared turn off the ignition and it's ready
  • #6 5072938
    plablo69
    Rate: 21
    That's right, everything works. So maybe someone knows how to choose the antenna installation, or the antenna amplifier itself. It suppresses the signal very much. The radio worked basically because of problems in the previous car, here it loses the RDS signal, it does not cope as it should.
  • #7 5072989
    mariusz1176
    Help: 7
    Rate: 25
    i.e. the radio is not original ... if so, you will need an antenna separator. Look for a lot of it on the Allegro
  • #8 5073095
    plablo69
    Rate: 21
    That's right, the radio is not original. And the separator is even connected to the cube, it is 12V on it, I checked. Without that, only the radio is playing.
  • #9 5073147
    ptaszek1975
    Level 30  
    Help: 121
    Rate: 444
    The antenna amplifier is at the antenna and it's broken.
  • #10 5073362
    plablo69
    Rate: 21
    How to get to him ???
    mariusz1176
    Help: 7
    Rate: 25
    you unscrew the side panels in the trunk, the straps of the handle to hold.
The discussion revolves around setting the clock in a 2003 Skoda Fabia Combi 1.4 16V, specifically addressing the absence of a knob near the tachometer for this function. Users suggest using the existing buttons to adjust the clock settings by turning the ignition off, pressing and holding a specific button, and then adjusting the time. Additionally, there are inquiries about deleting service inspection notifications and issues related to a non-original radio and antenna signal problems, with suggestions for troubleshooting and component checks.
