[Solved] Skoda Octavia 1.6 2000: Non-Functioning Analog Clocks & Turn Signals After Soldering
bodzio18121991 6033 7
  • #1 17355508
    bodzio18121991
    Hello everyone, I have a problem with Skoda Octavia 1.6 2000 I have stopped working for a few weeks. I have read on the Forum that it is necessary to improve 3 Cold February visible on the Photographer After soldering, the car immediately goes out and does not work. Turn signals.
    • zdjecie.pdf (124.05 KB) You must be logged in to download this attachment.
    piotrekwoj1
    Help: 947
    Rate: 3433
    When it lights up and immediately goes out, it suggests a problem with the immo, but this does not explain the lack of turn signals. Are they emergency?
  • #3 17355523
    szymitsu21
    Help: 343
    Rate: 1300
    Possible broken clocks.
    The controls all worked?
    Mistakes?
  • #4 17355535
    bodzio18121991
    the car fired normally and normally it was only after trying to fix the solders, the car will fire and immediately go out and the directions do not work
    • Skoda Octavia 1.6 2000: Non-Functioning Analog Clocks & Turn Signals After Soldering IMG_20180729_130225.jpg (3.88 MB) You must be logged in to download this attachment.
    piotrekwoj1
    Help: 947
    Rate: 3433
    Your soldering is a massacre. What did you solder it with?
    bodzio012
    Help: 161
    Rate: 780
    A nail heated on a burner :D
    And to the creator of the topic, you have a problem with immo, you did something wrong, how do we know what?
    Check the plug from the meter.
    robokop
    Help: 1763
    Rate: 6372
    A poker / kettler for gutters? The photo shows one kicked solder at once. And who knows how much of it is further.
  • #8 17414322
    bodzio18121991
    The blame was cold February in the counter Thank you all for your help :) :) :)
The discussion revolves around a Skoda Octavia 1.6 from 2000 experiencing issues with non-functioning analog clocks and turn signals after a soldering attempt. The initial problem was identified as potentially related to the immobilizer (immo) system, as the car would start but then immediately shut off. Various responses suggested that improper soldering techniques might have caused the issue, with one user humorously mentioning using a heated nail for soldering. The author later confirmed that the problem was indeed due to cold solder joints in the counter, indicating that the soldering quality was critical to the functionality of the vehicle's electrical components.
