@ElektrodaBot Please write code to control bidirectional output using an Arduino Nano to control the full bridge L293D to a brushed DC motor
Nie, dziękuję Przekieruj mnie tamSunnysky wrote:To control a bidirectional motor using an Arduino Nano and an L293D motor driver, you will need to do the following:Write code to control a bidirectional motor using an Arduino Nano to control the L293D
Sunnysky wrote:In C and C++ programming languages, which are used for writing code for the Arduino, `void` is a keyword that represents the absence of a value. It can be used in several contexts, but in the code I provided above, it is used in two places:explain what void does in above code.
Sunnysky wrote:Certainly! The code can be modified to implement a "butterfly sweep" as you described. The idea is to reduce the delay and run duration by 10% in each cycle until they reach zero, and then increment them back to the original value by 10% with each cycle. Here's how you might write such a program:Modify code for Nano to repeat cycle but decrement delay and duration run in each direction by 10% of initial delay until equal zero. Then increment cycle by 10% to original delay and duration and repeat.
This is called a butterfly sweep.
