JBL Tune 500BT Headphones Not Pairing with Phone: Bluetooth Connectivity Issues
Miszuk 19074 3
  • #1 17978427
    Miszuk
    I warmly welcome!
    Due to the fact that I did not find a similar problem, I was forced to present it myself. Namely, I bought the jbl tune 500bt bluetooth headphones about two months ago and so far they were working, they sounded as they should. Until yesterday evening. I went home, the headphones were on all the way, I turned them off of course, beautifully put away in a safe place. After about 30 minutes, I turned them on again and at first the phone wouldn't pair with them, so I turned them off and on, still the same. I disconnected the pair on the phone but the phone stopped searching for them at all, as if they were not turned on. Interestingly, they are charged, a characteristic sound is heard when turned on, the LED lights up in white. When I want to turn them off, I have to hold the button for about 2 seconds, but about 7, because they do not want to turn off and the sound that would indicate their turning off is simply not there. I tried to connect them to another phone, but none is finding them. Can something be done about it? Do you already go to the store and advertise? I would like to add that it is not possible to dig inside, I do not know electronics at all
  • #3 17978452
    kostujm
    As the advice of a colleague above will not work, give the guarantees immediately, just do not start anything there because he immediately states that it is your fault.
  • #4 17978482
    Miszuk
    Nothing helped, the phone still does not find the headphones, although the LED is flashing blue, i.e. waiting for a bluetooth connection. Well, thanks for the advice, I will give the equipment back for warranty
