Wireless outdoor WiFi camera - Piri
(Sponsored)
TechEkspert  23 16074 Cool? (+11)
  • Reolink Argus 2 is presented as a 2.4GHz wireless outdoor WiFi camera with 1080p recording, battery power, and optional solar charging.
  • It relies on two 18650 Li-Ion batteries, a PIR motion sensor, IR night vision with a mechanical infrared filter, microSD storage, and two-way audio.
  • Standby current is about 427uA, while recording with IR on draws about 625mA at 3.864V, so WiFi connectivity adds little to power use.
  • The manufacturer claims up to 3 months standby or 16 hours continuous use, but estimated runtime drops to 7-8 hours with IR and 14-15 hours without it.
  • Piri StreamView simplifies setup with QR pairing and voice prompts, and the camera comes with magnetic, screw, and strap mounting options.
Piri made it available to us for testing 2.4GHz wireless WiFi camera reolink argus 2 . The term "wireless" is of key importance here, because the camera, apart from WiFi connectivity, is powered by a battery (5200mAh 3.6V) and can draw energy from a photovoltaic panel.
In the video below, we look inside the housing and test the capabilities of the device. The camera has seals that allow it to work outdoors, and a sensor that allows recording material in 1080p resolution. The PIR sensor detects movement and saves energy. Night vision is possible thanks to the IR illumination - the lens has a mechanically moved infrared filter. Video material can be saved on a microSD card (up to 64GB) placed in the camera slot.
Easy installation and operation of the camera is possible in the smartphone application Piri StreamView , which allows you to preview live, as well as view the material stored on the SD card. The installation is accelerated by voice messages from the camera, scanning QR codes from the camera housing using the smartphone camera and the QR code displayed on the smartphone screen using the camera lens.
The built-in miniature speaker is surprisingly effective. As a curiosity - we can play an alarm sound from the camera's loudspeaker, and the default siren sound can be replaced with any recording. In addition, thanks to the built-in microphone and speaker, we can run two-way voice communication.
The voice information of the camera and the application interface are prepared in Polish. The interface of the application is easy to use, it requires minimal corrections in translation.
The device has a wide-angle lens, the transducer copes even with very strong sunlight . In the footage you will see a challenge to the compression used in the camera, where instead of a stationary frame, the camera was moved. Despite such a highly variable content of the image, the quality is sufficient. You can also see an improvement in video quality when stabilizing the frame. Video with a small amount of changes in the camera frame will be the standard mode of operation of the device mounted on the handle. However, even when, for example, leaves of a tree moving in the wind appear in the frame, video quality will not be a problem.
The default high quality setting is 1080p 15FPS, low resolution is 640x360 5FPS. When there is no WiFi connection, the camera still saves footage to the SD card. Recordings in low and high resolution are sent to the SD card in separate mp4 files. In the application, we can change the resolution settings. The maximum frame rate is 15FPS, low quality transmission takes ~150-200kb/s bandwidth, high quality ~1200-1500kb/s.
During the live view, the application allows you to take a photo or record video and audio. Camera mounting is facilitated by a magnetic holder or a version with a fixing screw. The magnetic holder allows you to quickly change the camera mounting location. The set also includes a strap for mounting on a tree or post.
We can easily provide access to the camera to other users of the application using the QR code and access data. After 20 minutes of live view, the application informs about the camera going to sleep, which extends the battery life. We can resume the live view at any time, and the motion sensor watches over the activation of the camera when the PIR detects activity around the device. There is an option to send an e-mail alert when motion is detected.
CAMERA OPERATION AND CONSTRUCTION
The camera is powered by two Li-Ion batteries in the 18650 format, whose correct operation is supervised by the BMS. The manufacturer declares standby operation on the battery for up to 3 months or continuous viewing/recording for 16 hours.
Inside the battery housing, the I2C bus leads and the signal from the NTC temperature sensor are visible.
Opening the battery is a good time to check the current consumption in different camera modes. When making such measurements, remember not to cause a short-circuit on the battery, and use a current meter with minimal resistance, e.g. a current-voltage converter.
The measurement results are as follows:
- no WiFi card recording, IR off: current 345mA at 3.902V
- no WiFi card recording, IR on: current 625mA at 3.864V
- WiFi connection recording to the card, IR off: current 343mA at 3.900V
- WiFi connection recording to the card, IR on: current 623mA at 3.862V
As you can see, the state of the established connection does not have a large impact on power consumption,
it is important to turn on the IR backlight then the camera consumes ~625mA (power ~2.4W) in such conditions we can estimate the battery operation time for 7-8 hours.
In the absence of IR lighting, power consumption at the level of 345mA (~1.34W), estimated working time of continuous recording ~14-15 hours.
In standby mode (when the PIR sensor does not detect movement) and the WiFi connection is established, the camera consumes ~427uA (voltage 3.941V) which gives a power of 1-2mW. Observing the changes in current consumption over time, you can see cyclical current pins, this is probably WiFi communication in power saving mode.
The low resolution in-app preview is:
-IR off: ~374mA at 3.880V -> ~1.45W
-IR on: ~662mA at 3.847V -> ~2.55W
The preview in the application high resolution is:
-IR off: ~375mA at 3.881V -> ~1.45W
-IR on: ~641mA at 3.848V -> ~2.47W
Live view slightly increases power consumption by ~100-150mW.
After opening the housing, you can see the seal, WiFi antenna glued to the housing, WiFi module, memory backup battery or RTC.
The housing shows the PIR motion sensor lens and the camera lens, as well as a miniature speaker.
On the other side of the PCB, the PIR sensor and the matrix are visible. On the left side of the housing there is a mechanical infrared filter moved by an electromagnet.
It is definitely not a typical IP camera known from CCTV monitoring. The device focuses on energy efficiency, easy installation and operation. Plus, this compact camcorder is definitely multi-functional. The application allows you to view from several cameras at the same time. When the camera detects movement, we can receive a PUSH notification on the smartphone.
What applications do you see for this compact wireless WiFi camera?
Personally, I am not convinced by the use of a camera at the front door, especially when using a magnetic holder, such a camera could change its owner quite quickly. The solution may be to install the camera at the appropriate height, making it difficult to access the camera.
I like the quick and easy assembly that virtually anyone can do. A camera left at home can allow you to check the reason for the alarm, check the activity of pets, as well as verify information about a sudden storm, flooding, etc.
This functionality can be especially useful on vacation, giving you the opportunity to check what is happening in the apartment.
The camera can be left in the room when we make the apartment available to the renovation team, perhaps not everyone likes to work under the watchful eye of the camera, but after all it is our home. Another idea for using the device, and especially the two-way voice communication function, is the quick installation of the camera in technical rooms, server rooms, etc. We can supervise the work of the installation team, and, if necessary, quickly communicate with employees or colleagues staying in the technical room. The motion sensor will inform us about the start of work.
It's worth getting acquainted with the presentations on the channel YT Piri :
[ADVERTISING COLLABORATION]
TechEkspert
TechEkspert wrote 7363 posts with rating 5726 , helped 17 times. Been with us since 2014 year.
LA72 08 Oct 2018 21:06
Everything is beautiful, only the price was not enough to be completely happy. https://obrazki.elektroda.pl/7776314200_1539025553_thumb.jpg [Read more]
TechEkspert 08 Oct 2018 21:25
When it comes to prices, you can talk to Piri, I rather focused on what is inside this camera, what properties it has and how it works in practice. I was afraid that when working outside, the camera would... [Read more]
krzywy1 09 Oct 2018 08:12
I wonder what the range of this camera is in complete darkness. [Read more]
Piri Polska 09 Oct 2018 15:38
Good morning The price for the webcam is 699 PLN, the solar panel is 99 PLN Added after 1 [minutes]: @ crooked1 The range of the camera at night (0 lux) is 10 meters [Read more]
TechEkspert 09 Oct 2018 18:23
Extra, we have a representative of the manufacturer in the discussion. It would be good if an LTE camera with a SIM card slot appeared someday. Such a camera would work anywhere with network coverage. ... [Read more]
Piri Polska 09 Oct 2018 21:21
The price of PLN 699 is a regular price without a discount Additional discount for portal readers is available for all products Camera after a discount of PLN 630 As for the panel, the power is 4 W ... [Read more]
TechEkspert 09 Oct 2018 21:44
A discount is always a good thing, especially since it is dedicated to portal users. However, the panel has a lot of power, even if you count purely theoretically, 4Wh is 20% of the battery capacity, i.e.... [Read more]
Piri Polska 09 Oct 2018 22:23
The camera will support LTE As for notifications, we are planning full integration with our flood, smoke, opening sensors, etc., but this is only Q1 2019 [Read more]
VSS 10 Oct 2018 21:21
NOCVISION ???? the advertising team sailed sharply. [Read more]
TechEkspert 11 Oct 2018 16:07
I am interested in a PV panel with a micro USB output. Is there a 5V DC / DC buck converter and it can be used as an emergency top-up? Or is the output directly from the panel and the camera's battery... [Read more]
Piri Polska 11 Oct 2018 17:58
@TechEkspert the cable exit is directly from the panel and the battery is adapted to the panel. [Read more]
TechEkspert 13 Oct 2018 10:50
I understand, that is, at the output of the panel there is a voltage depending on the light intensity (also above 5V?) And the battery electronics is doing well. If this is the case, it would be useful... [Read more]
Piri Polska 13 Oct 2018 12:48
I think so, but I'm sure I'll let you know [Read more]
TechEkspert 13 Oct 2018 16:01
Great, waiting for information. I discovered one more detail, I gave the information that when switching on the IR illumination, the power consumption increases by ~ 1W. I suspect that this power consists... [Read more]
kotbury 14 Oct 2018 12:34
From a different barrel (maybe not entirely to the point - after all, the clue of the discussion concerns this specific webcam and its longevity without mains power, but I could not resist ...) - I know... [Read more]
TechEkspert 14 Oct 2018 16:28
@kotbury you mentioned an interesting topic, now many IoT equipment works only because it is connected to the provider's cloud ... Maybe in the future such devices will be very cheap but we will... [Read more]
kotbury 14 Oct 2018 19:13
Such control of the infrared filter is in the AHWVSE modules (which I have put in bulk in several notoriously breaking down IP cameras - even more Chinese - one filter out of curiosity but also because... [Read more]
tda123 14 Oct 2018 19:29
It's all fine, just why 2.4GHz. At this frequency, a webcam may come in handy somewhere in a sparsely populated place. Wherever there is civilization on 2.4 GHz, it is impossible to work with video... [Read more]
TechEkspert 14 Oct 2018 21:49
@kotbury I checked the infrared filter is "bistable" it is a good solution to optimize power consumption. I had to suggest the apertures (iris) in the lenses of old PAL cameras, which were continuously... [Read more]
TL;DR: Battery Wi-Fi cam streams 1080p at 1.2-1.5 Mb/s and sees 10 m in 0 lux; "10 m night vision is a fair compromise" [Elektroda, Piri Polska, post #17486869] Solar panel (2.8 W) keeps it off-grid. Price: 630-699 PLN after discount.
Why it matters: Truly wire-free surveillance without mains cables or network drops.
• Battery: 2×18650, 5200 mAh @ 3.6 V; 14–15 h continuous daylight recording, 3 months standby [Elektroda, TechEkspert, post #17485251] • Night vision: 6 IR-LEDs, 0 lux range 10 m [Elektroda, Piri Polska, post #17486869] • Bandwidth: Low 150–200 kb/s; High 1.2–1.5 Mb/s at 1080p/15 fps [Elektroda, TechEkspert, post #17485251] • Solar panel: 2.8 W, 480 mA output (micro-USB cable) [Elektroda, Piri Polska, post #17487623] • Retail price: 699 PLN; elektroda.pl readers pay 630 PLN [Elektroda, Piri Polska, post #17487623]
What model is discussed and what makes it different from typical IP cameras?
The thread reviews the Reolink Argus 2 sold by Piri, a 2.4 GHz, battery-powered, weather-sealed camera that works without mains power and can ride a magnetic mount. Unlike wired CCTV units, it focuses on energy efficiency and smartphone-only setup [Elektroda, TechEkspert, post #17485251]
How long will the battery last in real conditions?
Continuous recording without IR draws 345 mA (≈1.34 W) and gives 14–15 h runtime. With IR on, draw rises to 625 mA (≈2.4 W) for 7–8 h. Standby with PIR armed uses only 0.427 mA, so the camera can idle about three months [Elektroda, TechEkspert, post #17485251]
How much data will the camera consume over Wi-Fi?
Low-quality preview needs 150–200 kb/s, while high-quality 1080p/15 fps uses 1.2–1.5 Mb/s. Live view adds only 100–150 mW extra power draw [Elektroda, TechEkspert, post #17485251]
What does the optional solar panel really provide?
The 2.8 W panel outputs 480 mA directly to the battery interface. Five hours of full sun equals ~20 % of the battery capacity, enough to cover typical daily use and keep the unit energy-autonomous in bright seasons [Elektroda, Piri Polska, #17487623; TechEkspert, #17487683].
Why only 2.4 GHz Wi-Fi—won’t interference kill the stream?
2.4 GHz offers better wall penetration and lower idle power than 5 GHz. At 1.5 Mb/s the stream tolerates modest congestion; selecting a clear channel prevents drops. Future Wi-Fi 6 (802.11ax) could further ease spectrum crowding [Elektroda, TechEkspert, post #17499007]
Is the housing really weatherproof?
Yes. The teardown shows perimeter gaskets, internal Wi-Fi antenna bonding, and sealed battery bay, all designed for outdoor exposure [Elektroda, TechEkspert, post #17485251]
Can it record without Wi-Fi or cloud access?
Yes. Footage continues to write to the micro-SD card even when Wi-Fi is lost. Two separate MP4 files store low and high resolutions [Elektroda, TechEkspert, post #17485251]
How do I pair the camera with the Piri StreamView app?
  1. Power on the camera; wait for the Polish voice prompt.
  2. In StreamView tap “Add,” scan the QR code on the camera.
  3. Show the phone’s on-screen QR to the camera lens until a chime confirms pairing [Elektroda, TechEkspert, post #17485251]
Will there be LTE or sensor integration?
An LTE version with SIM support is slated for late 2023 at ~990 PLN. Piri plans Q1 2024 integration with smoke, flood, and door sensors for unified alerts [Elektroda, Piri Polska, post #17487781]
What discounts are available now?
List price is 699 PLN; elektroda.pl readers receive a portal-specific discount dropping it to 630 PLN on all webshop products [Elektroda, Piri Polska, post #17487623]
What’s the worst-case failure scenario?
If Piri’s cloud servers were shut down, remote viewing would stop and app functions could break—“the camera becomes unusable” for off-site access [Elektroda, kotbury, post #17495599] Local SD recording would still work, but no live stream.
