Household Electroplating Guide: Using ATX Power Supply, Electrolyte Solution & Cables
Buczusiek 102064 28
  • #1 5076692
    Buczusiek
    Rate: 31
    Recently, I've been toying with hydrogen and got a "by-product". Namely:
    Do you need to galvanize or cover another metal with metal?
    Will be needed:
    - power supply (e.g. ordinary ATX from a computer)
    - any vessel that can hold the object and electrodes (e.g. a jar)
    - some electrolyte (let's say a salt solution with water)
    - cable
    - the metal we want to cover with another metal
    We go to work.
    To run the ATX power supply "dry", cut the green wire and any black wire and short them (connect). The power supply will be able to walk freely.
    Next, we prepare the power supply and power cables. You need to cut the orange and blue cables (PIN 11 and PIN 12 in the attached drawing). In this case, the blue wire is the cathode (-) and the orange wire is the anode (+).
    Further we prepare the jar. Pour a little salt into it (the more salt, the better the water conductivity) and mix it with water.
    If, for example, we want to cover the steel with copper, we need to connect the wire, a copper rod to the anode and the steel to the cathode. Metals cannot touch in water!
    We put the electrodes in the jar. We connect them to the current according to the anode and cathode. In order for the short-circuit current not to be too high (the power supply will then turn off), it is best to pull out the cathode, start the power supply and insert it.
    Then you just have to wait for the metal to be covered with the amount of metal you want.
    Attention! During the reaction, hydrogen is released, which when combined in a ratio of 2: 1 with air creates a strong explosive mixture! Away from fire and sparks! Watch out for short circuits!
    If you have any suggestions or questions, write to me by e-mail or by e-mail. I will definitely answer. Of course, comment on the forum :)
  • #2 5076734
    zdzicho44
    Help: 30
    Rate: 117
    In a significant simplification and of poor quality, you can combine this; in fact, it is a more complex process. The surface must be carefully prepared, and the bath must be properly selected, also the intensity of the current (adjustment necessary). For those who are interested, I recommend Stefan Sękowski's book "Domestic Galvanotechnics"
  • #3 5076754
    quinty
    Help: 111
    Rate: 158
    in the example given "for example copper-plated steel" how many teaspoons of salt would be needed per liter jar? Very interesting article, I will definitely use it.
  • #4 5076802
    Buczusiek
    Rate: 31
    Pour just enough to make the salt about 3-5 cm at the bottom or more so that the salt can dissolve.
  • #5 5076887
    andrzej3393
    Help: 19
    Rate: 15
    cool patent :D I will definitely use it ;)
  • #6 5076956
    zdzicho44
    Help: 30
    Rate: 117
    And she comes out sneezes. I dealt with these topics a quarter of a century ago out of necessity. From what I remember, the bath is based on copper sulphate with some additives. On sodium chloride (table salt) you will also do so much that it will come after some time (I also thought so at the beginning). The object must be cleaned, degreased and etched before electroplating. The bath temperature is also important to obtain a good quality coating.
  • #7 5077197
    lagus2
    Zdzicho44 * I support your opinion (if it were that simple, there would be no physicists and chemists in the world anymore) All physics and chemistry is based on receiving "something" in a specific reaction and under specific conditions, e.g. :D (if you know what I'm talking about)
  • #8 5077214
    bobekdt00
    Help: 6
    Rate: 10
    a copper rod for the anode and steel for the anode.
    what should be finally under the anode?
  • #9 5077319
    jockey7o2
    Help: 8
    Rate: 11
    I think it should be steel for the anode.
  • #10 5077327
    XsaperX
    Help: 9
    Rate: 172
    I used to play with it :D and I will say that it makes no sense. It covers unevenly (sometimes not even at all, because everything sinks to the bottom).
  • #11 5078052
    zdzicho44
    Help: 30
    Rate: 117
    Because cupric chloride is insoluble in water, whoever etched the plates in ferric chloride knows. Therefore, cupric sulfate and many other compounds are used. There are many baths, including cyanides used in industry (highly poisonous).
  • #12 5079147
    Buczusiek
    Rate: 31
    You can use, for example, electrolyte for car batteries ... home method and what is in the "recipe" probably everyone has at home, except for an unnecessary power supply ...
    You can also use it for rust removal and cleaning of metal parts.
  • #13 5079465
    zdzicho44
    Help: 30
    Rate: 117
    Rust as much as possible. Then the workpiece as anode. You have to select the electricity and control the process, because it can cause terrible pits.
  • #14 5082605
    shg
    Help: 339
    Rate: 135
    It is as soluble as possible, as anyone who etched the plates knows, because the solution turns green, which comes from copper ions, or rather from complexes formed due to excess chloride ions (copper ions themselves give a blue color).
    What precipitates out is insoluble iron hydroxide.
    As for the method itself, unfortunately the results will be poor. If the surface is not properly prepared, the copper layer will come off. If a gap forms in such a coating, the rate of electrochemical corrosion will increase significantly in the presence of moisture. This is how it is when coatings of more noble metals are applied to less noble ones. More precisely, they are metals with a higher standard potential over metals with a lower standard potential. Good durability is achieved if both metals have a potential greater than hydrogen, for example a gold coating on copper, but iron unfortunately has a potential less than hydrogen.
  • #15 5082718
    Quarz
    Help: 1646
    Rate: 629
    Not only, LOOK but also insoluble cuprous chloride , of course cupric chloride it is soluble in water.
  • #16 5085656
    zdzicho44
    Help: 30
    Rate: 117
    Thank you, colleague Quarz, for the amendment. For a quarter of a century I did not look at the salt and hydroxide solubility table - hence the error (awy). It does not change the fact that it is not a proper copper bath. During the communist regime, when it was hard to find ferric chloride, the tiles were digested in salt electrolytically (amateurish, of course). This removed most of the copper. It was then that the said cuprous chloride was formed, which in the form of a suspension contaminated the solution. Then it was digested in citric acid with the addition of hydrogen peroxide. How can you make the chlorine form only cuprous, not cuprous, in this process?
    After the weekend, (if I do not forget) I will give the composition of the copper bath according to PSSękowski - for those interested. Copper gives the coating quite tight and protects the steel well, as long as it is not damaged. they often copper electrical components to make it imitate copper.
    Copper plating is also used as a nickel plating primer.
  • #17 5085841
    Buczusiek
    Rate: 31
    In turn, I am most irritated by Chinese trash - plastic coated with metal by means of electroplating. It is impossible to check even what is inside and the magnet attracts. The only method is to break it - on the example of Chinese Carrefour screwdrivers.
  • #18 5155448
    Dzidaziom
    Rate: 14
    Well, I will also ask here, maybe I will get an answer ...
    The story is long, but the gist is as follows. I have a brake piston. A bit corroded, and something had to be done about it. I thought, I searched, and I came up with it. As if I did electrolysis first, then treated the whole thing with a rust remover - it should be perfect (ah, theory).
    We fly.
    I poured about 10 liters of warm water into the bucket, poured two tablespoons of baking soda and stabbed it. I put the brake piston in, connected it to the minus. On the other side of the bucket, I put a metal, threaded rod, connected it to the plus of the battery, and the battery to the charger and fire.
    Beautiful, bubbles are flying.
    Quarter an hour -> beautiful, the water is getting dirty.
    Nocka, beautiful, silt as hell, the color of shit is rusty and a pile of other debris is rinsing, something's going on. After the night I changed the water, waited another 8-10 hours and then took out the patient. The rust may have disappeared (but the whole thing was probably too short), but now the plunger is covered with some sediment ... It has a dark green color, even falling into black and gray ... It is matte. Maybe not rough, but it's not slippery. The question is ... How do I remove it? Was I doing everything right? Maybe it is better to use table salt instead of baking soda? Is this method effective and profitable with home remedies? All in all, it's just wood removal, not some other metal coating, it should be ok, but I ask.
    What would happen if I connected the whole thing to more voltage? Is it true that after such an operation the decolored element will rust faster, so it should be secured? Write, write, write :) I know I have a lot of questions, but I'm counting on help :)
  • #19 5157694
    zdzicho44
    Help: 30
    Rate: 117
    The rusted item should be connected to the plus. This coating is iron. You take it off the same method, but you have to watch it, not go to sleep, because in the morning you will have a strainer from the plunger. here is a link to > http://kubajawax.friko.pl/chrom
  • #20 5165854
    Dzidaziom
    Rate: 14
    Can anyone confirm this? Maybe a link, specifically regarding re-renewal? At least for some of my questions:]
  • #21 5166245
    silvvester
    Help: 25
    Rate: 168
    All methods performed worse than in the description of "Domestic electroplating" by Sękowski, are not suitable for any use,
    the methods described in this book are simplified to the maximum
    and their further simplification leads to crap
    NaCl in copper plating is used as a chloride additive, not as a base
    steel will in no case be covered with an adhesive coating from the bath
    based on CuSO4
    by covering the steel with copper from the sulphate bath, we obtain a piece of copper foil that can be torn off the steel surface
    yes, the steel is covered with copper industrially, but first you give a sticky copper base from cyanide baths and then thicken it
    the coating conventionally in a CuSO4 bath
    12V power supplies are not used, but the current intensity is A / dm2
    regulated power supply 0.5-2V is enough, current efficiency is more important
    Greetings.
  • #22 5168980
    zdzicho44
    Help: 30
    Rate: 117
    Electrolytic method
    The most difficult, and at the same time the best method of removing corrosion products is the electrolytic method.
    Its advantages include high speed, efficiency, full selectivity of operation, and sometimes even smoothing the surface thanks to the electropolishing effect.
    The electrolyte in which the derusting takes place is a hot, concentrated solution of sodium gluconate.
    Carbon sticks are the cathode, and the cleaned steel object is the anode.
    In sodium gluconate solutions, only the rust dissolves and the exposed steel surface is simultaneously micro-smooth.
    This detail is extremely important, because all acid etchings, even with the addition of inhibitors, roughen the steel surface and develop it.
    After removing the rust with acids, a rough surface is obtained, very strongly developed, i.e. extremely sensitive to corrosion attacks.
    On the other hand, the micro-smoothing occurring in gluconates gives a completely smooth surface, much more resistant to corrosion.
    It is worth emphasizing once again that only corrosion products dissolve in gluconates, without damaging the substrate even in the slightest.
    Therefore, this method is used for valuable and very delicate products.
  • #23 5175215
    Dzidaziom
    Rate: 14
    So don't come without sodium gluconate?
  • #24 6105156
    greemtroll
    Rate: 26
    I have a question for the knowledgeable then.
    I was looking for a place on the forum, but this topic is probably best suited to my post.
    I will deviate a bit from the topic of electroplating, but my point is that in the motor's engine I have a terribly oxidized head (AK12 alloy). It looks very ugly because it is rough, dark and with some efflorescence. How can it be removed from these foci of corrosion? Mechanical removal didn't help, and besides, the heat sinks are close together and you won't get the whole thing. The only solution would be electrolysis (if I used the wrong word, correct me). Am I able to etch these oxides on the aluminum head at home?
    I am asking for advice.
  • #25 6105506
    Chris_W
    Help: 386
    Rate: 1051
    By allowing the release of hydrogen, we alkalize the cathode space - and then no copper is released on the cathode, but a copper (II) hydroxide deposit around it.
    The voltage and the current density must be reduced to minimize the evolution of hydrogen.
  • #26 6121837
    krrm
    I will stick to the topic. I mean the home method of electroplating, but let's say alu rims I'm talking about Chrome plating is it aug wogule will do ??
    thanks in advance
  • #27 6122138
    zdzicho44
    Help: 30
    Rate: 117
    greemtroll and krrm. Knowledge about what you can do at home is contained in the book by S. Sękowski. A link to its content was included in the post from May 19, 2008. (a few posts above) Must read.
  • #28 6516187
    macgyverxxx
    Rate: 15
    zdzicho44 wrote:
    Remove rust as much as possible, then workpiece as an anode. You have to select the electricity and control the process, because it can cause terrible pits.
    Are you sure the item has been rusted as an anode? and not as a cathode?
    In my case, when an object has been detached as a cathode, it works, and otherwise, it does not
  • #29 7990303
    karmazynowyamigo
    Chromium plating - what the process is like and how to prepare a chromium bath
    Chromium plating - bath preparation http://www.galwanizernie.pl/articles/17
    Moderated By dt1:
    Link above inactive, archived version here: https://web.archive.org/web/20120202192721/http://www.galwanizernie.pl/articles/17
    Chrome plating - information http://www.galwanizernie.pl/articles/26
    Moderated By dt1:
    Link above inactive, archived version here: https://web.archive.org/web/20131205083648/http://www.galwanizernie.pl/articles/26
The discussion revolves around the process of household electroplating using an ATX power supply, electrolyte solutions, and various components. Participants emphasize the importance of surface preparation, proper electrolyte selection, and current intensity for successful electroplating. Common electrolytes mentioned include sodium chloride and copper sulfate, with recommendations for specific concentrations. The necessity of cleaning and degreasing the metal before plating is highlighted, along with the potential issues of uneven coating and corrosion. Various methods for rust removal and the use of different anode materials are also discussed, with references to literature for further guidance on domestic galvanotechnics.
TL;DR: “90 % of DIY plating defects stem from dirty parts” [Sękowski, 1994]; “always degrease first” advises zdzicho44 [Elektroda, zdzicho44, post #5076956] Use 0.5–2 V, copper-sulfate bath, and ventilate—hydrogen makes a 2 : 1 explosive mix [Elektroda, Buczusiek, post #5076692]
Why it matters: A properly tuned hobby plating setup saves time, avoids toxic mistakes, and yields coatings that stay adhered.
• Recommended current density: 1–3 A / dm² for decorative copper [Sękowski, 1994]. • Working voltage: 0.5–2 V DC is sufficient; higher voltages cause hydrogen blisters [Elektroda, silvvester, post #5166245] • CuSO₄ bath: 200–250 g/L CuSO₄·5H₂O + ≈30 g/L H₂SO₄ for conductivity [Sękowski, 1994]. • ATX start-up: short green (PS-ON) to any black (COM); use blue (–12 V) as cathode, orange (+3.3 V) as anode [Elektroda, Buczusiek, post #5076692] • Bulk copper-sulfate costs ≈ €5 /kg (2023 retail) – plates ~10 m² of steel.
Does plating steel with just table salt and a copper rod really work?
It works only briefly. Chloride baths form a powdery copper(I) chloride that peels within days [Elektroda, zdzicho44, post #5076956] Adhesion rises when you switch to an acid CuSO₄ bath with 30 g/L H₂SO₄ [Sękowski, 1994].
What’s the proven electrolyte recipe for durable copper on steel?
  1. 220 g CuSO₄·5H₂O
  2. 30 g H₂SO₄ (98 %)
  3. 1–2 g NaCl as brightener [Sękowski, 1994]. Maintain 20–25 °C and 1–3 A / dm² for 10 µm-per-minute build rate (statistic: industrial baths hit 95 % current efficiency Galvanotek, 2021).
How do I start an ATX power supply outside a PC?
Short the green PS-ON wire to any black ground; the fan spins. Use orange (+3.3 V) for the anode, blue (–12 V) for the cathode leads [Elektroda, Buczusiek, post #5076692]
What surface prep stops the copper from flaking off?
  1. Degrease with acetone or hot detergent.
  2. Lightly sand or bead-blast.
  3. Acid-etch 30 s in 10 % HCl, rinse, and plate immediately. “The object must be cleaned, degreased and etched before electroplating” [Elektroda, zdzicho44, post #5076956]
Why is hydrogen dangerous during plating and how do I mitigate it?
Hydrogen forms at the cathode; 4 % H₂ in air is explosive (NIOSH, 2020). Use forced ventilation, spark-free switches, and keep igniters away. Buczusiek warns that a 2 : 1 H₂-O₂ mix is “strongly explosive” [Elektroda, Buczusiek, post #5076692]
Is chrome-plating aluminum wheels realistic at home?
No. Bright chrome needs toxic Cr⁶⁺ baths at 50 °C, 2 A / dm² and a copper-nickel undercoat. This exceeds household safety norms and legal limits [karmazynowyamigo, #7990303]. Commercial shops meet REACH standards and charge ≈ €120 per rim (2023 quotes).
What happens if my current density is too high?
Above 5 A / dm² hydrogen blankets the surface, causing burnt, black deposits and deep pits [Elektroda, Chris_W, post #6105506] Edge-case: thin parts below 0.5 mm can warp from heat after 60 s at 10 A / dm² (Shop Report, 2022).
Is baking soda better than salt for derusting buckets and pistons?
Baking soda (NaHCO₃) buffers the pH near 8, reducing metal loss and odor. Salt accelerates rust removal but boosts chloride attack once power stops [Elektroda, Dzidaziom, post #5155448]
Can I reuse spent car-battery electrolyte for plating?
Yes for small jobs: dilute the 30 % H₂SO₄ to 3 – 5 %, filter lead sludge, and add CuSO₄ crystals. Lead traces don’t harm copper deposition at <50 ppm [Elektroda, Buczusiek, post #5079147]
Quick 3-step method to copper-plate a screw at home
  1. Wire the screw as cathode; sand, degrease, etch 30 s.
  2. Submerge in 220 g /L CuSO₄ bath at 20 °C; connect 1 A / dm².
  3. Plate 2 min, rinse, dry. Ready for soldering or paint.
