DIY Galvanizing Bath: Tub Material, Acid Choice, Transformer Specs, Voltage for 3x2x1m
mara165 33135 19
How can I build a home zinc electroplating bath for galvanizing metal parts, including the tank material, bath chemistry, current, and voltage?
Use a plastic tank, not metal, and provide separate anodes and a cathode arrangement; plastic tubs “work great” for home plating setups [#17657422][#19230554] For a simple zinc bath, the thread recommends a low-acid solution based on zinc chloride, potassium chloride, boric acid, and gloss additives, rather than using plain acid [#18337188] Before plating, the parts must be thoroughly degreased and etched: one recipe uses 10% NaOH at 70–80°C for degreasing and 10% HCl at room temperature for etching [#19230554] The important electrical parameter is current density, chosen by surface area of the part; values mentioned are about 1 A/dm² and, for coating, 2–6 A/dm² [#14384301][#19230554] The coating voltage is not critical and will usually be only a few volts, up to around a dozen volts at most, because the bath has high conductivity [#19232660] For a larger setup, the replies also suggest using a ready-made electroplating guide or buying prepared bath/passivation chemicals if you want better results [#145?][#18337188]
  • #1 14384022
    mara165
    Recently, I have been thinking a lot about the galvanization of metal things, filter baskets to be exact.
    I would like to make a home-made galvanizing bath.
    Namely, I'm interested in how to go about it.
    The question is whether the bathtub can be made of ordinary sheet metal or plastic? What acid should be in the bathtub for the electrolysis to take place?
    What transformer power (with what current) should I use in a 3x2x1m tub?
    Does the voltage value matter?
    The previous design of the machine was successful and thank you all for helping with the previous design. :)
    I would like to ask for your help in this project.
    Regards.
  • #2 14384301
    bambus94
    Help: 243
    Rate: 711
    If possible, do it with plastic, but you will have to use the second electrode.
    Instead of acid, in my opinion, you should use a salt of the metal with which you are coating the element. So in your case, salt containing zinc.
    And the value of the current is selected according to the surface of the element, probably 1A / 1dm ^ 2
  • #3 14384510
    jarek_lnx
    Help: 4183
    Rate: 6067
    Get the electroplating guide, there are various recipes for galvanizing baths, they also differ in what is the optimal current density and the quality of the coating obtained, some technologies (e.g. cyanide baths) are unavailable to amateurs, and they are said to give the best results. If you have little, it may be worth looking for the services of professionals.
  • #4 14389480
    mara165
    Listen, the idea is to make a small factory galvanizing plant for your own products because it takes a long time to do it by the company and you have to drive a car and a maximum of 350 cars will be available on the car. With a larger order, if the customer is in a hurry, having 3 bathtubs at the time of processing. And I have such a question. How is it with the liquid with metal elements, is it disposable or what? I am very weak on this subject because I have never had contact with such a thing. You have to take a risk. Oh and one more thing. How long does such a galvanization last?
    Regards
  • #5 17657422
    pawelek2501
    Rate: 15
    A bathtub made of plastic, but not softening above the bathtub, two rails to which you attach ANODE AND SECOND KATODE from the power supply - rectifier. To one rail you give a container with zinc balls in the other basket attached to the other rail, something that you galvanize. . I also assemble a small galvanizing plant, but with the difference - I have to get to all acid polishing solutions, etc. I am at the stage of assembling the rectifier - power supply. Apparently, the current, the less important, is important. Regards
  • #6 18085160
    zamela
    Rate: 55
    Pawełek and how is the galvanizing plant?
    I have some very effective cult lures that are gnawed by the tooth of time and water, so I would like to effectively protect them against corrosion and I just thought about a tiny galvanizing plant for home use because protecting such elements with varnishes does not work at all.
  • #7 18085246
    pawelek2501
    Rate: 15
    Very good idea
  • #8 18214785
    miroslaw wielki
    Conditionally unlocked
    Help: 148
    Rate: 359
    What are the best salts for galvanizing?
  • #9 18214876
  • #10 18214887
    miroslaw wielki
    Help: 148
    Rate: 359
    Thanks for the info. I have the entire collection of Sękowski from my childhood.
  • #11 18337188
    Barnab
    Galvanizing from Sękowski's books is ok if you want to do it as an experience. You will not get good quality coatings.
    Alkaline and slightly acidic baths are the easiest to use. - they are most often used in industry.
    For a simple home electroplating plant - I would suggest low-acid baths based on
    - zinc chloride - bath conductivity
    - potassium chloride - provides metal ions
    - boric acid - is a pH buffer
    - gloss additives - regulating depth and shine
    they work at a pH of 4.5-6
    But what about sewage? The element must be degreased and etched to make the surface chemically clean.
    If you do it in the proverbial jar - it's ok
    But if you are going to run an electroplating plant, I would start with sewage management.
    The book is better: Galvanotechnics Guide
    Regards
    Barnabas
  • #12 18337323
    pawelek2501
    Rate: 15
    Passivation can also be added as a galvanizing stage. Leakage is the base fact, I have a problem with this conundrum
  • #13 18337410
    miroslaw wielki
    Help: 148
    Rate: 359
    In general, I use mostostal but I thought that I could have a shine on my own. There, the weight is every 20 kg at receptions. This is a lid, I will get a galvanized 6.
  • #14 18337481
    pawelek2501
    Rate: 15
    It's a fact better by yourself Some plastic tank, solution a few balls of zinc in baskets with a stainless steel rectifier and only go with galvanization. Of course, etchants before galvanizing
    To degrease the material, I use acid diluted with water, and if it does not work, then ELECTROCHEMISTRY IN MOTION GOES
  • #15 18465772
    tomchlop
    I zinc as below. Maybe someone will need it:
    www.youtube.com/watch?v=7bnaXxt8J04
    If someone was looking for a homemade galvanizing method:
  • #16 18465856
    pawelek2501
    Rate: 15
    The first fundamental mistake. Copper cannot come into contact with the solution and here I see a copper hanger. The solution and zinc should be done professionally. But for the galvanization of hooks and keys, it will not work. And where is the brightener?
  • #17 18467526
    pawelek2501
    Rate: 15
    Where the Potassium chloride where the zinc chloride The basic ingredients, and this time is not compatible eh
    DIY Galvanizing Bath: Tub Material, Acid Choice, Transformer Specs, Voltage for 3x2x1m DIY Galvanizing Bath: Tub Material, Acid Choice, Transformer Specs, Voltage for 3x2x1m DIY Galvanizing Bath: Tub Material, Acid Choice, Transformer Specs, Voltage for 3x2x1m DIY Galvanizing Bath: Tub Material, Acid Choice, Transformer Specs, Voltage for 3x2x1m
  • #18 19230554
    monoceros
    The easiest way is to buy a ready-made bath, passivation, rinse aid, anodes, eg GALW IMP in Warsaw, for steel, brass, copper, DIAMOND, for ZnAl, alu a bath based on NaOH (you can do it yourself, steel can also be coated). Plastic bathtubs (e.g. building casters - they work great). Degreasing: 70-80 ° C, NaOH, 10%, as an electrode, an ordinary steel sheet (anode and cathode can be used), I recommend the same or higher current as for coating. Etching with HCl 10%, room temperature. Covering 2 to 6 A / dm2 of the coated material. Passivation 5 - 10 sec. Rinsing and drying. The coated details are better to move in the bath while coating. Cycle: degreasing (about 10 minutes), rinsing, etching (depending on the cleanliness of the detail a minute or longer, springs as soon as possible because they will hydrogenate), rinsing, coating, rinsing, passivation, rinsing, drying.
  • #19 19232660
    monoceros
    I forgot to add that due to the high conductivity of the bath, the coating voltage will be in the range of a few V max. parunastu V.
  • #20 21139117
    avamax390
    Homemade galvanization involves coating iron or steel with zinc to prevent rusting. Steps:
    1. Clean metal surface thoroughly.
    2. Prepare a zinc solution (zinc sulfate or chloride).
    3. Dip or brush metal in solution.
    4. Allow to dry and repeat if https://apkmodbit.com.
    5. Zinc layer protects metal from corrosion.
✨ Homemade galvanization involves creating a galvanizing bath to coat metal items, such as filter baskets, with zinc to prevent corrosion. Users discuss the feasibility of using plastic or metal for the bath, with recommendations leaning towards plastic to avoid corrosion. The galvanizing solution typically includes zinc salts, such as zinc chloride or zinc sulfate, and may require additional components like potassium chloride and boric acid for optimal results. Current density is crucial, with suggestions of 1A per dm², and the importance of maintaining proper voltage levels is noted. Users emphasize the need for thorough cleaning of the metal surface before galvanization and discuss the potential for creating a small-scale galvanizing plant for personal use. Concerns about waste management and the longevity of the zinc coating are also raised.
