Using supercapacitors to start a traditional car engine instead of a battery
1014 9
Can I start a conventional car engine with supercapacitors instead of a 12 V battery?
Yes, but only in limited cases: a supercapacitor bank can start a car once, especially if the engine is already warm, but it is not a practical full replacement for a battery on a cold start [#21685869][#21685870] To equal a 100 Ah, 12 V battery you would need about 360,000 farads, and with typical 5.5 V supercaps you would need three in series for 12 V, which makes the pack very large [#21685873] Unlike a battery, a capacitor’s voltage drops linearly, so at about 50% charge a mega-cap bank would already be around 6 V and not strong enough to crank the engine well [#21685873] The thread says supercaps are better used in parallel with a battery, for jump-start modules, low-temperature assist, or to keep critical systems alive during battery changes [#21685870][#21685871] So the practical answer is: possible for short-term starting, but batteries are still the better choice for normal use [#21685873]
  • #1 21685867
    John Curtin
  • #2 21685868
    Richard Gabric
  • Supercaps start warm engines but lack cold-start capacity
    #3 21685869
    David Ashton
  • Supercapacitor start modules for parallel or jump use
    #4 21685870
    Richard Gabric
  • #5 21685871
    David Ashton
  • #6 21685872
    John Curtin
  • Supercapacitors are far too large for car starting
    #7 21685873
    David Ashton
  • #8 21685874
    David Ashton
  • #9 21685875
    John Curtin
  • #10 21685876
    Keonte45
Supercapacitors can technically start a traditional internal combustion engine, but practical limitations exist. A small supercapacitor can provide enough current for a single warm engine start, as demonstrated in some videos, but cold starts require significantly more energy. To match the energy capacity of a typical 100Ah car battery, an impractically large volume of supercapacitors (on the order of several cubic meters) would be needed due to their lower energy density and voltage drop during discharge. Supercapacitors maintain voltage less effectively than batteries, dropping significantly as they discharge, which complicates their use as sole starters. However, supercapacitors excel in low-temperature performance and are often used in parallel with batteries to support critical systems during battery changes or to stabilize power in high-drain applications like powerful audio systems. Various commercial supercapacitor-based starting modules exist, some designed as full battery replacements, others as parallel supplements or jump-start aids.
