How to Open and Destroy an Old Hard Disk to Ensure Data Can't Be Restored?
autokomputer 29182 19
How can I open and physically destroy an old hard disk so the data cannot be restored?
To make the drive unrecoverable, physically destroy the platters: hammer the disk, grind or cut it, or remove the platters and bend/warp them until they break [#5547225] [#5558421] [#5546942] [#5546920] One reply says a few hard hammer blows are enough, and another suggests two cuts with a large grinder without even disassembling the drive [#5547225] [#5547256] If you do open it, the practical target is the platters, not the case or electronics, because the goal is to break or deform the recording surface beyond use [#5546942] [#5546920] One poster also suggests erasing the disk or doing a pseudo low-level format first, but the thread treats physical destruction as the surest step [#5547148]
  • #1 5546737
    autokomputer
    Level 19  
    Rate: 45
    I have a very old hard disk, I would like to get rid of it, but first you have to destroy it so that the data cannot be restored in any way.
    Programmatically it is impossible, but mechanically also difficult.
    I unscrewed all the screws from the disk, and still I can't remove the case from it to get to its heart, I think they stuck it with something, what to do?
    I have corrected TONI_2003
  • #2 5546749
    Platon
    Help: 744
    Rate: 170
    It is programmatically possible - until you start up the disk.
    Did you unscrew the middle screw? Maybe there is a sticker underneath it.
  • #3 5546755
    Gregory_bg
    Help: 55
    Rate: 80
    I have unsealed the discs. A hole in the sticker and ready in the old ones will probably also give a roadstead. I do not know whether the data can be recovered after this, but after starting such a disk, the heads will not rise and mechanical damage is ready. I doubt anyone would want to play this; I mean in data recovery.
  • #4 5546815
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    > I have unsealed discs.
    Are you suggesting the drives are hermetically sealed?
    > after starting such a disk, the heads will not raise
    But why?
  • #5 5546829
    autokomputer
    Level 19  
    Rate: 45
    I got it now - but it took a lot of time and energy to devote to it :D
  • #6 5546838
    Gregory_bg
    Help: 55
    Rate: 80
    Hermetically, and yes, inside are the right conditions (probably negative pressure or something in this range). Under normal conditions, the heads would "run" on the plates, and it is known that during normal operation, the head does not touch the plate.
  • #7 5546848
    lukaszb-17
    "how to permanently destroy a hard drive" :)
    hammer!;]
    seriously, you can run the magnet over the plates and you will not regain anything (preferably neodymium)
  • #8 5546855
    matador123
    Help: 28
    Rate: 34
    Pour epoxy glue inside? ;-)
  • #9 5546857
    avatar
    Level 36  
    Help: 159
    Rate: 416
    You write nonsense oh and it's great
  • #10 5546858
    autokomputer
    Level 19  
    Rate: 45
    Is this disc bending enough:
    ?? Because she doesn't even go out to get them out to scratch. Is it enough to bend it?
  • #11 5546872
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    :arrow: Gregory_bg
    Nonsense! The disc is not hermetically sealed and the head floats on an air cushion. Once opened, the drive will be functional and data can be recovered from it.
    I advise you to read about the construction and operation of hard drives before you start thinking about it again.
  • #12 5546900
    autokomputer
    Level 19  
    Rate: 45
    And someone will answer my question above? :)
    Gregory_bg
    Help: 55
    Rate: 80
    Maybe this airbag confused me somehow ;) after all, Sory for my mistake.
    Warped platters will do the trick unless you had super top secret information on that drive ;)
    marcin1700
    Help: 15
    Definitely enough, and above that ;) .
    And join the discussion ... I used to have a 20GB drive, Seagate. As he had a few physical examinations at the beginning I didn't really care about him. I created partitions on the healthy surface of the disk, unscrewed all the screws from the case. I connected the computer, the disk to it, when it started, I carefully pulled off the casing. The disk worked without any problems - dust did not settle when the discs were spinning at high speed. I turned on the copying of some files and admired the instant work of the heads ...
    Still to the Author ... The plates can still be unscrewed and bent several times and then it breaks. Well, but let's not exaggerate too :)
  • #15 5546947
    autokomputer
    Level 19  
    Rate: 45
    thank you - I give you a helping hand;]
  • #16 5547118
    kuba989898
    Level 19  
    Help: 29
    Rate: 25
    But unproductive data destruction.
    I twist the plates and hang them on a thin thread under the lamp and they dangle.
    Simple and not bent, and no one can read the data because the rest of the disk is disassembled into the first parts.
  • #17 5547148
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    The whole discussion doesn't make much sense. It is enough to erase the data from the disk and save the entire disk with whatever or to zero its surface (the so-called pseudo low level format). I give a horse with a row to anyone who recovers the data. And all the stories about the recovery based on the magnetic residues, to any number of records backwards, please put between fairy tales. Isn't it better to do as I suggest and sell the disc?
  • #18 5547225
    wladek83
    Level 32  
    Help: 155
    Rate: 104
    There are no more hammers ?! Drive to the front sidewalk, bash a few times with a hammer and zeroed on amen. This and better bending can be achieved in 10 seconds. And yes - unscrewing, unsealing, magnetizing ... Brainstorming! Simple solutions are the fastest and least time-consuming in this case.
    Kisses
  • #19 5547256
    Ptolek
    Level 36  
    Help: 318
    Rate: 272
    You can always use the rest of the disk from another disk, if someone insisted.
    According to me, the most effective is what jankolo says + two cuts with a large grinder (no need to disassemble the disk).
    The magnetic residue is certainly not nonsense, but I do not know what erasing in hard drives looks like, but in tape recorders, despite repeated magnetization, erasing does not necessarily erase the previous record to absolute zero, but it is always a few dozen dB of attenuation (this may lower the level of previously recorded below the noise level of the cassette itself).
    Usually, I saw such topics in "Na wesół".
The discussion revolves around methods to physically destroy an old hard disk to prevent data recovery. Users share various techniques, including unscrewing the casing, bending the platters, and using a hammer or grinder for destruction. Some participants debate the hermetic sealing of drives and the effectiveness of mechanical damage versus data erasure methods. Suggestions include using neodymium magnets, epoxy glue, and extreme physical alterations to the disk. The consensus leans towards physical destruction as the most reliable method to ensure data cannot be restored.
