Safe Long-Term Storage Temperature Range for 2.5 Laptop HDDs and Demagnetization Risk
gamemaniaco1987 831 5
  • #1 21586302
    gamemaniaco1987
    Do 2.5" laptop HDDs have a temperature range for long-term storage without risk of demagnetization of the platters causing data loss and corruption? Or does any temperature above 25C slowly cause the platters to demagnetize?
  • #2 21586507
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    Every drive has a different temperature, and there is always a risk regarding data storage.
  • #3 21586721
    gamemaniaco1987
    My HDDs 2.5" models ST500LM030, WD10JPVX-08JC3T5 and HGST HTS541010A99E662
  • Suggesting SMART checks for older WD drives
    #4 21586865
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    gamemaniaco1987 wrote:
    WD10JPVX-08JC3T5
    https://www.disctech.com/Seagate-ST500LM030-500GB-SATA-Hard-Drive
    WD10JPVX-08JC3T5
    https://smarthdd.com/database/WDC-WD10JPVX-08JC3T5/05.01A05/
    Regarding HGST, I can't find any information on temperatures. But I, for example, have 4 WD Purple 10 TB drives on the site and under load 35 degrees, but on the other hand the WD Gold 10 TB has 45/50 degrees under load. The fact that these drives you have are already quite old, show smart of these drives with CDI.
  • #5 21586942
    gamemaniaco1987
    What temperatures? For My models not Demagnetize?
  • #6 21587686
    gamemaniaco1987
    >>21586942 Are these temperatures related to demagnetization or just problems with the PCB, motors, electronic oil and mechanics?
