Preventing Demagnetization of 2.5 HDDs Near CRT TV and DVD Drives
gamemaniaco1987 1791 14
Can a nearby CRT TV, DVD drives, room humidity, or room temperature demagnetize 2.5-inch HDDs stored in a cabinet?
No: a CRT TV, nearby DVD drives, and your listed room temperature/humidity will not demagnetize 2.5-inch HDD platters. The CRT’s field weakens quickly, and DVD drives do not generate major electromagnetic fields [#21435426] HDDs already contain very strong neodymium magnets in the voice-coil assembly right next to the platters, so outside magnetic sources 20–30 cm away are not the concern [#21426808][#21435899] Temperature around 36C and humidity around 58–68% do not perceptibly affect platter magnetism; humidity is more likely to damage the electronics than the magnetic media [#21435919][#21427340] Over long storage, the bigger risks are mechanical wear, electronics failure, and eventual data errors/bit rot, so the practical answer is to keep backups or use mirrored storage rather than worry about demagnetization [#21435919][#21435899]
  • CRT and DVD drives are unlikely to demagnetize HDDs
    #1 21426265
    gamemaniaco1987
    Is it possible to prevent the demagnetization of HDDs or is the demagnetization of HDDs an inevitable phenomenon caused by storage conditions (humidity and temperature of my room storage)?
    I store the 2.5" laptop HDDs + USB3.0 enclosure inside the original cardboard boxes and inside the cabinet drawer, but next to the cabinet there is a 29" CRT TV with a speaker and in the drawer above the drawer where the HDDs are, there are 4 internal SATA DVD burner units for PCs (I think they have magnets). Will the CRT TV and DVD drive cause disturbances and damage the magnetism of these 2.5" laptop HDDs?
  • Humidity not a magnetism risk for HDDs
    #2 21426808
    sylweksylwina
    Help: 1882
    Rate: 2355
    Humidity is not really a concern in terms of magnetism. HDDs are air-sealed so I would not expect that much humid air would enter HDD through breathing hole. Humidity can mostly affect only electronics, but overall you shouldn't store them in very damp environment.
    If HDD platter are not demagnetized by huge neodymium magnets that are part of voice coil assembly, they for sure won't be demagnetized by storing them next to DVD drives, and in some distance to CRT TV.
    I wouldn't recommend storing valuable data on some cheap 2.5 inch HDDs and stash them in the closet. Invest in NAS with mirrored array and then periodically back the data on external medium. The best thing you can do is to have backup in at least two different places.
  • #3 21427052
    gamemaniaco1987
    And temperature room storage hdd demagnetize influencie in HDD 2.5"?
  • #4 21427340
    sylweksylwina
    Help: 1882
    Rate: 2355
    Temperature does not have impact of platter magnetism, because it is far off curie point.
  • #5 21427604
    gamemaniaco1987
    In 2.5" and 3.5" HDDs stored and used once a year, the biggest cause of corruption, data loss and failures would be oxidation
    if humidity and storage temperature do not affect the magnetization of HDDs?
  • #6 21435210
    gamemaniaco1987
    >>21427340 In 2.5" laptop hdd and 3.5" HDDs, does demagnetization only begin above the Curie point? Usage temperature, storage temperature, humidity, age of the 2.5" HDD (example manufactured in 2010) do all of these have no influence on the demagnetization of HDDs, even in the long term?
    Bit rot, what is this phenomenon? Is it related to demagnetization?
  • Keep hard drives away from magnetic field sources
    #7 21435391
    gulson
    System Administrator
    Help: 150
    Rate: 6123
    The topic is in Beginners, but let's keep some level.
    Demagnetisation is not just related to the Curie point.
    The biggest problem is strong magnetic fields, neodymium magnets, electromagnetic radiation, some electromagnetic pulses.
    That's for sure.
    Thermal effects, in particular large temperature fluctuations, can weaken the magnetic carrier over a long period of time, but this has to be carefully referred to research.
    In my opinion, focus on ensuring that the disks do not lie close to any electromagnetic field sources.
  • #8 21435404
    gamemaniaco1987
    If my 2.5" HDD is 20 or 30 cm away from a 29" CRT TV or if my 2.5" HDD is close to 5.25" SATA DVD Drives, will this cause any demagnetisation of the 2.5" HDD?
    I had doubts about whether high temperatures (36C) and humidity (68%) would cause any demagnetization of the 2.5" HDD in the long term, and also the age of the HDD, for example, manufactured in 2010.
  • CRT and DVD fields unlikely to demagnetize HDDs
    #9 21435426
    gulson
    Help: 150
    Rate: 6123
    The electromagnetic field of a CRT TV quickly weakens and will not cause demagnetisation.
    DVD drives do not generate major electromagnetic fields.
    The temperature of 36C is considerable for a room, but not perceptible to the drive.
    68% is a lot of humidity, but not noticeable to the drive.
    I guess you live in a warm country, which one? :) .
    2010 is already 15 years old, I guess sooner a given drive will have worn out mechanical parts than it will demagnetise.
    The electronics themselves are more likely to fail, for example if you live by the ocean and then have high humidity combined with salinity.
    And maybe think about additional backup?
  • #10 21435777
    gamemaniaco1987
    I have 4 2.5" HDDs with the same files
    Some people told me that high temperatures and humidity like mine favored the demagnetization of 2.5" HDDs and also generated bit rot. Other people told me the opposite, so I was confused
    A 29" CRT TV is big and has strong magnets, but I don't know how they would demagnetize a 2.5" HDD or a 5.25" SATA DVD drive. Are there any magnets?
  • HDD internal magnets outweigh external fields
    #11 21435899
    sylweksylwina
    Help: 1882
    Rate: 2355
    I will repeat that HDD platters are next to one of strongest type of magnets - neodymium magnets in voice coil assembly. This magnetic field is way stronger than anything from outside.
    Bit rot will naturally occur, but it will take way longer than you think, it may be like 15-20 years until HDD error correction mechanism will start throwing an errors of unreadable sectors.
    If you want to have permanent solution, try using M-Disc, or tape media. Recently I've had read over 30 year old DDT tape and it was almost fine, except broken leader that was easily fixable. But tape media is very demanding on how do you store it, especially in which humidity and temperature levels you are storing it. For HDDs just leave them as is, and stop overthinking and worrying about storing them for longer time. Just have a backup, on HDDs from different manufacturers or at least batches, and avoid media that are known to have high failure rates, like Seagate Rosewood family of 2.5 inch drives.
  • #12 21435919
    gulson
    Help: 150
    Rate: 6123
    Your temperature and humidity will not cause the disc platters to demagnetise. Nor will a CRT television cause it.
    The problem after a long time could be the mechanical components of the drive and the electronics themselves.
    Electronics do not like humidity. If someone lives near the ocean with high humidity, the electronics themselves often break down.
  • HDD platters are protected from demagnetization
    #13 21436130
    gamemaniaco1987
    Is it true that there is a magnet inside 2.5" HDDs?
    Is this magnet stronger or weaker than the magnets in 29" CRT TVs and 5.25" SATA optical DVD drives?
    If there is a magnet inside a 2.5" HDD, what protects the platters from demagnetisation?
    I have M-Disc DVDs for some files, but they are small, 4.7GB. M-Disc Blu-ray + drive and LTO tapes are very expensive at the moment, so I need other media for large files, 150 to 350GB, but they are good for long-term archiving. I do not use air conditioning, so the temperature here varies from 33 to 36C and humidity 58 to 67%, but I do not have the level of demagnetization in 2.5" HDDs. These conditions will generate demagnetization in the long term.
  • #14 21436215
    sylweksylwina
    Help: 1882
    Rate: 2355
    No those conditions will not generate demagnetisation in long term. Do you even read what we are writing about?
    Yes, every HDD has very strong neodymium magnets next to the platters. It's one of strongest magnets you can find. And it's only a few millimeters next to platters. That should be enough to rethink how CRT TV 30cm away will affect it.
  • #15 21436272
    gamemaniaco1987
    Yes, I read everything, thank you. If 2.5" HDDs have magnets inside them, why do manufacturers and other people recommend keeping them away from magnetic sources to avoid the risk of demagnetization? Is there any PDF article or study citing information about the demagnetization of 2.5" HDDs, how does it occur in which situations, and the influence of temperature and humidity?
Demagnetization of 2.5" HDDs is not significantly influenced by proximity to CRT TVs or DVD drives, as the magnetic fields from these devices are weak compared to the neodymium magnets within the HDDs themselves. Humidity and temperature do not directly cause demagnetization; however, high humidity can affect electronic components over time. The primary concerns for HDD longevity include mechanical wear and oxidation rather than magnetic interference. For long-term data storage, users are advised to maintain backups and consider alternative media like M-Disc or tape, especially in environments with high humidity and temperature fluctuations.
TL;DR: Typical bit rot emerges after 15–20 years; “This magnetic field is way stronger than anything from outside.” Internal HDD magnets dwarf nearby CRT/DVD fields; room heat/humidity won't demagnetize platters. [Elektroda, sylweksylwina, post #21435899]
Why it matters: This FAQ helps 2.5/3.5-inch HDD owners store drives safely near CRT TVs/DVD drives and in warm, humid rooms without risking data.
Will a CRT TV 20–30 cm from my 2.5-inch HDD demagnetize it?
No. “The electromagnetic field of a CRT TV quickly weakens and will not cause demagnetisation.” A gap of tens of centimeters reduces it further. At that distance, the platters are safe. Avoid direct contact with strong magnets. [Elektroda, gulson, post #21435426]
Do 5.25-inch SATA DVD drives pose a magnetic risk to HDDs?
Storing HDDs next to PC DVD drives does not demagnetize them. The drives do not expose nearby media to strong fields. Normal proximity on a shelf or in a drawer is fine. Focus on backups rather than distance from DVD drives. [Elektroda, sylweksylwina, post #21426808]
Do 36°C temperature and 58–67% humidity demagnetize HDD platters?
Those levels will not demagnetize the platters. “Your temperature and humidity will not cause the disc platters to demagnetise.” Humidity mainly stresses electronics, not the magnetic medium. If you live near the ocean, salinity plus humidity can corrode electronics. [Elektroda, gulson, post #21435919]
Does temperature affect HDD magnetism, or only the Curie point matters?
Curie temperature is not the only factor. “Demagnetisation is not just related to the Curie point.” Large temperature swings over long periods can weaken the magnetic carrier. Keep storage temperatures stable and avoid strong electromagnetic sources. [Elektroda, gulson, post #21435391]
What is bit rot—is it the same as demagnetization?
Bit rot is gradual data loss as the recorded signal weakens below readability. It is not sudden demagnetization. Error correction masks it until sectors become unreadable. “Bit rot will naturally occur... it may be like 15–20 years” before ECC struggles. [Elektroda, sylweksylwina, post #21435899]
What actually fails first on old HDDs in storage?
Mechanical parts and electronics usually fail before magnetic media. “2010 is already 15 years old, I guess sooner a given drive will have worn out mechanical parts than it will demagnetise.” High humidity with salinity, such as near oceans, accelerates electronic corrosion. [Elektroda, gulson, post #21435426]
How should I store HDDs long term?
Follow a simple plan:
  1. Put your data on a NAS with a mirrored array.
  2. Periodically back it up to external media.
  3. Keep at least two backups in different locations.
This prevents a single device or site from taking all copies. [Elektroda, sylweksylwina, post #21426808]
Do HDDs have magnets inside? Why don't they erase the platters?
Yes. “Every HDD has very strong neodymium magnets” in the voice‑coil, just millimeters from the platters. They steer the actuator rather than erase data. Their proximity underscores why a CRT 30 cm away is not concerning. [Elektroda, sylweksylwina, post #21436215]
Why do vendors say to keep drives away from magnets?
Because very strong fields and pulses can harm magnetic media and electronics. “The biggest problem is strong magnetic fields, neodymium magnets, electromagnetic radiation, some electromagnetic pulses.” Keep drives away from industrial magnets and high‑energy emitters. [Elektroda, gulson, post #21435391]
Is age alone enough to demagnetize a 2010-era HDD?
No. Age brings mechanical wear and electronic risks before any demagnetization. “2010 is already 15 years old... mechanical parts than it will demagnetise.” Maintain backups instead of trusting a single old disk. [Elektroda, gulson, post #21435426]
Will oxidation from humidity cause data loss if I rarely use the drives?
HDDs are air‑sealed, so little humid air reaches the platters. Humidity mostly affects the electronics. Avoid very damp environments or condensation. For data safety, prioritize backups over climate worries. [Elektroda, sylweksylwina, post #21426808]
Should I avoid certain 2.5-inch HDD models for archival copies?
Yes. Prefer diversity and avoid families with known issues. “Avoid media that are known to have high failure rates, like Seagate Rosewood family of 2.5 inch drives.” Keep copies on different manufacturers or batches. [Elektroda, sylweksylwina, post #21435899]
What media are better than HDDs for 150–350 GB long‑term archives?
For permanence, consider M‑Disc optical or tape. “If you want to have permanent solution, try using M‑Disc, or tape media.” Tape survives decades but demands controlled temperature and humidity. M‑Disc offers smaller capacities but long retention. Maintain HDD copies as working backups. [Elektroda, sylweksylwina, post #21435899]
