Electrolux EWF 1030 Washing Machine: Resolving Error E20 during Rinsing Function
rafciobp 11018 5
  • #1 5576683
    rafciobp
    Hello all
    I am the owner of the washing machine as in the subject, she served all the time without charge. Recently doing the washing, during the rinsing function, the washing machine stops working, made a stop and the E20 error appeared on the display. Unfortunately, I do not have an instruction manual for this model of washing machine so I do not know what kind of fad it is ?? If someone knows what may be the reason, let him write. Thank you
    mrhari
    Help: 835
    Rate: 3239
    Pump and filter to check.
  • #3 5576747
    rafciobp
    the filter checked cleanly, so something with the pump, will give advice to check the pump yourself, or better check some service ??
  • #4 5576759
    mrhari
    Help: 835
    Rate: 3239
    If all hoses are unobstructed, the pump motor you have to replace. The topic has already been repeatedly rolled here, read the forum, you will find the address where to buy and probably the price of ;)
  • #5 5576781
    rafciobp
    Oh thanks a great one more time, I will check all the snakes, if they are ok, it will be necessary, as you write, replace the pump motor thanks again, best regards
  • #6 5577234
    artfik
    Help: 91
    Rate: 346
    You can check the pump directly, ie connect 220 v to the pump and it should walk, I do not know this washing machine model, but EW 1330 e 20 means that the lid is open, ie the door, check the door switch just in case
